Projects Filling in lots of tiny holes
Discussion in 'The Hokey Ass Message Board' started by A_Burly_Wind, Apr 5, 2017.
  1. A_Burly_Wind
    A_Burly_Wind
    So Ive gotta question for the body work gurus on here. My cars done body work wise as far as rust repair and all that, however somewhere in its life time and owner decided that 37 fords needed body t******* and has drilled 38 holes into it for mounting said trim. Whats the best way to go about filling these up so that i dont warp or distort the body, Im not a body man by any means and only had to fix a few small issues on the car so Im pretty new with all this.
  2. How big are the holes? like 1/4"or ?????
    Small holes I take a piece of copper and hold it on the back side of the hole then weld it shut. The copper will fall loose when you are done and you can move to the next hole.
  3. A_Burly_Wind
    A_Burly_Wind
    Id say theyre 1/4" or slightly smaller
  4. Yep weld 'em. Don't get in a hurry and move around a lot, don't start at the end and go straight down the side. With my method you won't get it really hot, you are on it and off. if it has a dimple a little body filler will work fin to finish it out. And don't pay attention to the metal finish freaks, professional body men and customizers have been using filler since the beginning, first lead then plastic. ;)
    Binger and A_Burly_Wind like this.
  5. Crusty Chevy
    Crusty Chevy
    If the body is stripped, use ******s technique but weld from the inside with copper flush on the outside, less to grind that way.
  6. A_Burly_Wind
    A_Burly_Wind
    Thanks sir Ill do just that, and its no show car by any means, there are a few places that i left untouched just because its 80 years old and I intend on driving it alot in any weather so she doesnt have to be quite the polished diamond
  7. cshades
    cshades
    from wi
    If you can access the back of the holes I have used steel nails to fill in trim holes. Just pull them in from the rear, weld them, cut off the shaft and grind them smooth.
  8. Damned good idea never thought of that. ^^^^^^
    39custom and A_Burly_Wind like this.
  9. koolkemp
    koolkemp
    You should not need a copper backer for holes that small, just mug them closed, I cool them with the air gun immediately, virtually eliminates warpage, quick sand with a 2inch disc. Make sure to treat the backsides with paint.
    Hollywood-East likes this.
  10. trad27
    trad27
    The copper is more than just a backing in my opinion. I like to get the copper in tight and acts like a good heat sink to absorb the heat from the panel too.
  11. wojojo
    wojojo
    I used that technique on my OT bug. Worked just fine, no warping, and I didn't even "air cool' them.
  12. A_Burly_Wind
    A_Burly_Wind
    WOW now that is a fantastic idea sir!
  13. SEAAIRE354
    SEAAIRE354
    I like the nail idea welded tons of holes with the copper backer trick. If you don't have copper aluminum will work but the copper is a better heat sink. When you grind the welds pay attention to how much heat your creating,I've seen guys use a worn out sanding disc on a grinder and turn the steel blue and warp the hell out of it.
    A_Burly_Wind likes this.
  14. manyolcars
    manyolcars
    If you have trouble burning thru thin sheetmetal, weld on the nail and allow the melted metal to attach itself to the sheetmetal
  15. A_Burly_Wind
    A_Burly_Wind
    Im going to give this nail method a go tonight. Hopefully i get the hang of it quick and can get this thing in paint, been staring at a bucket of blue paint for too long.
  16. gene-koning
    gene-koning
    Find nails that are not galvanized (or have any other coating on them) if you can. The coating causes problems with the welding and leaves voids in the weld because it won't get hot enough to burn the coating away. You will want the nail heads to be bigger then the hole is. Also, if possible, clean the back (and of course the front) of the panel around the holes to bare metal, or the welds can be contaminated. Experience is a tough teacher...Gene
    porknbeaner likes this.
  17. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yep this is the trick of you can get at em. And once your done I would get a can of cavity wax and spray the backsides down . 3M 8851 and 8852 wand kit work awesome for this
  18. cshades
    cshades
    from wi
    Can't take credit for this I actually got the idea from another hamber- Larry who owned a body shop out by my house. It really helped when I filled a 140 trim holes in my 41 chevy coupe.
  19. slowmotion
    slowmotion
    I used the nail trick recently on an OT truck bed. Worked slick as chit!
  20. leon bee
    leon bee
    I like this topic. Are we talking MIG welder here?
  21. gimpyshotrods
    gimpyshotrods
    I would not use an air gun on a sheet metal weld.
    I have a former boss who has a whole lot of really pissed off customers with cracks all over their bodywork, all in the metal.
    I will give you three guesses how that happened. I tried to warn him, but I am just an engineer, and he was the boss, so he went with his technique.
  22. 39wagon
    39wagon
    Another idea for your consideration: take a 3/8 bolt and grind the threaded end down to a point making it look kind of like a center punch. Take it and LIGHTLY tap each of the holes so they are slightly concave. Then take a piece of sheetmetal (or nail head) and solder it into the concave hole. Make sure that you use enough solder so that it is higher than the surrounding metal and then just file or ground it down. It's sort of like using lead from back in the day. Make sure that you clean the area well to get any/all flux off (I would use solid wire rather than rosin core solder). Doing it this way insures that you won't warp the metal. And yesa I've done it many times and it works.
    Just a thought.
  23. Mike Miller
    Mike Miller
    I've used the nail method with good results. Don't get carried away with heat.
  24. graveyardsledder
    graveyardsledder
    I use a copper paddle, works like a charm and it was only a few bucks off one of the tool trucks.
  25. spooler41
    spooler41
    A few years ago I scored 2- 3/8" x2" copper buss bars from an old industrial
    electrical cabinet, I've made have more
    copper backers than I ever thought
    possible. Some are hand held tools,
    some are clamp on and a few I've made
    magnetic holders for, but the real deal is they all have worked well.
    .......Jack
    gimpyshotrods likes this.
  26. XtechX
    XtechX
    from Edmore, MI
    Before I got my Harbor freight copper backer tool. LOL.
    I had a piece of soft 1/2" copper line that I beat flat a few inches up the tube and used it to back my welds. Works great and can be reshaped to fit any contour your dealing with, and the rest of the round tube( say 6-8") makes a great handle. So I say just use the copper backer, go slow, jump around, use a light gauge wire so there is less material to grind smooth, I don't suppose a wet rag would hurt to keep the temp down, just slap it on the weld, to cool it as soon as you stop your weld each time.
  27. southcross2631
    southcross2631
    Harbor Freight copper paddle weld em up. If you can get to the back spray some weld through primer on the back for rust protection in the future.
  28. Dirk35
    Dirk35
    As long as you can get to the back of the panel to hold the heat sink, using a copper or br*** backer is the way to go. It makes a heat sink and it makes for a clean fill on the parent material. You'll also want to ensure to put some paint on the inside of each spot to protect it from rusting from the inside. You don't need to buy an expensive copper heat paddle. Just go to your local Lowes or Home Depot and get a short piece of copper tubing. You can hammer one end to be totally flat, and you can hammer the other end to have a slight curve shape.
  29. 1-SHOT
    1-SHOT
    from Denton
    You can use copper penny just clean the back side and use some 70/30 and your done not much to sand off and no distortion. Frank
  30. A_Burly_Wind
    A_Burly_Wind
    Didnt have very much chop time last night, but I did try out about 3 hole with the nail idea and Im very pleased with the results. Oh and Im using a Hobart handler 130 for welds.
