Projects Desoto Airflow Tail lights
Discussion in 'Traditional Hot Rods' started by HopUp, Apr 5, 2017.
  1. HopUp
    HopUp
    from Denmark
    I have these NOS tail lights parts and are looking for the jewelry lenses anyone that can help [​IMG]
    kiwijeff likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    If your not stuck on purestock,make them. There just red 1/2 ball stock,but ya could make blue,look around for some plastic light cover with shaped part ya can cut out.
  3. lothiandon1940
    lothiandon1940
    Cool-*** tailights by the way. What are they going on?:)
    lothianwilly71 and HopUp like this.
  4. 31Dodger
    31Dodger
  5. HopUp
    HopUp
    from Denmark
    lothiandon1940 likes this.
  6. Really liked those lights for some time.
    Finally picked up a pair at Chickasha Swap meet last year. Just have the lenses and not the buckets. Will have to fab something. Hope to use them on a 34 coupe were collecting parts for. I'm thinking you could find something for the center. Plastic (?) or gl*** blue dot might even work...
    If you use these, will you mount them flush or use a bucket????
  7. mgtstumpy
    mgtstumpy
    Something like these centre jewels? Airflow tail lamp ***emblies are not cheap
    PS. HITCHIKER here on the HAMB had a pair in 2011 with jewels.
    kiwijeff and Hitchhiker like this.
  8. Hitchhiker
    Hitchhiker
    Still got em. Been offered 800 for them a few times. Probably ahould have pulled the trigger. But can't bring myself to sell them. I put two singles together for about 125.00 if I remember correctly.
    Sent from my SM-G900T using The H.A.M.B. mobile app
  9. Hitchhiker
    Hitchhiker
    HopUp likes this.
  10. Elrod
    Elrod
    I love mine. Sorry that I don't have any spare jewels.
  11. HopUp
    HopUp
    from Denmark
    Thanks guys I got NOS buckets as well but don't know if I will use them - how did you guys mount them flush ? thank you
  12. HopUp
    HopUp
    from Denmark
  13. Elrod
    Elrod
    Mine are not flush. Mine have the full buckets behind the panel and the bezel is perpendicular to the ground. You see some of the bucket at the top, but none at the bottom.
    But you can cut the ring off the bucket and weld that to the panel and put small backing buckets from any car behind the panel.
    HopUp likes this.
  14. HopUp
    HopUp
    from Denmark
    Then are going on a 32 roadster with out much space behind the panel so I must cut the nice buckets :) if you here of any jewels for sale let me know - consider to put gl*** blue dots until I find the right lenses
  15. rusty valley
    rusty valley
    the jewels that hitch hiker showed look like the same ones used in old road signs. you can find them on ebay. most have a brand name in the cast pot metal housing
  16. sloppy jalopies
    sloppy jalopies
    They look to be about 1" diameter, memory says i have seen those jeweled lights in 50's and 60's box van dashboards...
  17. I have been down this road. Send me a PM, I have some spares and also know where to find more. Here are just a few pairs I have had.
    oliver westlund, HopUp and Hitchhiker like this.
  18. For information there are two different types of the reflectors. There are ones with a spring and washer and a threaded style. There are also 2 different diameters. see pictures below.
    [​IMG][​IMG]
    HopUp likes this.
  19. rusty valley
    rusty valley
    yup, they sure look like the old sign reflectors. more common than you would think. search marble reflectors, gl*** reflectors, etc. keep in mind, they are reflectors, and do not p*** light thru due to the cast body, meaning if you want blue dots you need a different plan
    HopUp likes this.
  20. sloppy jalopies
    sloppy jalopies
    I use "dy-kem" red to turn clear, harley, soft tail, front, fender lights red...[3rd brake]
    wonder how "dy-kem" blue would work making blue dots ?
  21. milkweed
    milkweed
    from SLC UT
    Dont cut them buckets... I have some you can cut up that are good donors... I think i have some centers.. PM me..
  22. brigrat
    brigrat
    from Wa.St.
    I like these type tail lights but lets be honest how many can afford them? Wonder if you could find a Stainless cup as the "grill" bezel, have it water jet any of the styles and find a gl*** lens of some sort?
  23. stanlow69
    stanlow69
    I watched these for a long time when they were in the cl***ifieds.
    Items like these set one car apart from another. When people talk about parts that are on a car more than a car itself. You know you did a good job.
  24. Runnin shine
    Runnin shine
  25. brigrat
    brigrat
    from Wa.St.
    "Items like these set one car apart from another. When people talk about parts that are on a car more than a car itself. You know you did a good job.[/QUOTE]"
    If it only takes a set of rare tail lights to set my car apart from others I have failed the build! They certainly make a great build better but IMO it's the sum of the parts as hole. Will be heading down to the local Water Jet wizards on Monday to "Brainstorm".........................................
  26. stanlow69
    stanlow69
    That's what I was trying to say, as I said in parts. The famous painter (Hollenbeck) had them on his Oakland Roadster winning 32. The door handles were a standout as well. There was a set on the Hamb cl***ified a few weeks prior to him winning the big prize.
  27. rusty valley
    rusty valley
    yeah sure id like to have some too, but realisticly speaking nobody in the 50's was looking for art deco tail lights. thats a current fad, i like em, but who cares
  28. desotot
    desotot
    Wow, I just realized I need some Desoto taillights . They are cool.
    46international likes this.
  29. 383deuce
    383deuce
    I like the hell out of them also, but could never swing the big $$ out lay for a set. So I just made some that are not the same style, but give that look. IMG_2101.JPG
    Hamtown Al, telekenfun and i.rant like this.
  30. 4woody
    4woody
    Every time I park my '38 Chrysler somewhere I worry about somebody stealing my tail lights.
    [​IMG][​IMG]
    stanlow69 and telekenfun like this.
