Projects 351W/FMX into '58 Edsel Corsair (big body)
Discussion in 'Traditional Customs' started by Dixon Bastie, Apr 7, 2017.
  1. Dixon Bastie
    Dixon Bastie
    I'm building a "refined" rat rod/mild custom, and am wondering what issues I may encounter. New running gear is out of a '70 Mustang. The Edsel frame is same as '58 Merc. Anyone know what motor mounts would work best? I also want to swap original "TeleTouch" column for a Fomoco column to get the shift lever - any suggestions? The goal is to keep the car 100% Fomoco, and traditional with no billet or aftermarket bling parts. Thank you !!
  2. Futura63
    Futura63
    from N/W ohio
    Small block Ford mounts are easy to fab, 2 bolts on the block ..... Truck mounts have 1 stud out the bottom and might be a good place to start , then you just make a place off your frame to land them
  3. bobss396
    bobss396
    The RR word again.. 2nd one today... gasp... and a FNG with no intro... place is going to poopie....
    Lots of same-year Ford parts swap right in and I see steering columns on evilBay all the time.
  4. Dixon Bastie
    Dixon Bastie
  5. Dixon Bastie
    Dixon Bastie
    "FNG"??? My car is not going to be a "RR" in appearance. Will be smoothed, lowered, on moon's and painted steelies, with a full interior that doesn't resemble a barnyard. Exterior will be tinted primer with a painted roof/quarter panel inserts.
    Not a surprise, but the market sources are VERY limited when it comes to columns to fit this car due to overall length, mount configuration, and starting box shaft size. This me for your reply and you suggestion. Good luck with your projects.
  6. Dixon Bastie
    Dixon Bastie
  7. Dixon Bastie
    Dixon Bastie
    I dropped a '78 Lincoln 400/C6 I to my '56 Merc several years ago and used combined 400 and factory '56 lowers. The engine dropped right in, sat right, with minor clearancing of the driver side exhaust fold for upper A-frame clearance.
    Thank youfor the reply and suggestion.
  8. Oldmics
    Oldmics
    57-59 Merc steering collums did not have a gear selector mechanism for the automatic trans. The automatic selector was "push ****on" and mounted on the left side of the dash.
    The 60 Mercs had a collum shift selector but I"m not sure of how that would fit on your 58.
    I have a standard shift 57 Merc collum if interested.
    Oldmics
  9. FNG is basic designation when you are new out of the box here and you were the one who called it a "rat Rod", not us. We don't do rat rods here, and don't drink with the girls who do.
    you are on the right track upgrading that old heap and ford truck mounts will probably be your best bet. You will have to fab some pieces but that what building is all about.
  10. Rusty O'Toole
    Rusty O'Toole
    It would be really cool if you could keep the push****on drive. Wonder how hard it would be to rig something up or if someone makes an electric gearshifter. Do you have the old trans or electric shifter?
  11. Surfcityrocker
    Surfcityrocker
    from Austria
    Reminds me of:
    Did you say Jehohva?
    turboroadster likes this.
  12. Dixon Bastie
    Dixon Bastie
  13. Dixon Bastie
    Dixon Bastie
  14. Dixon Bastie
    Dixon Bastie
    Yes, am aware of the Merc push****on selectors. My car has the complete TeleTouch, but I want it to be more reliable by dumping he ****ons. Have thought about the '60 Merc column becuz it has a dual range quadrant, so it might work with the FMX's "P-R-N-D-2-1" pattern.
  15. Loosing the tele-touch is a wise decision, two things killed the Edsel, the price was one, but they could have survived the price because the styling was excellent. The tele-touch was the other and not being reliable is one thing that no new car could survive back then.
  16. Dixon Bastie
    Dixon Bastie
  17. Dixon Bastie
    Dixon Bastie
    The TeleTouch was definitely a weak spot. Have a stock '58 Citation with a perfectly operating TeleTouch, but that took all new relays and a former Edsel mechanic to get it right. For the Corsair, I want modern power and h***le free driving.
  18. RmK57
    RmK57
    I totally agree with this idea. If you could retain the push ****on part of it but update the shift motor mechanism to something modern and dependable. It really is what makes an Edsel such an anomaly.
    I had a 58 Villager with the teletouch trans and had the shift motor rebuilt. It worked pretty well when the temps were cooler but on a hot summer day it would act up.
  19. Dixon Bastie
    Dixon Bastie
  20. Dixon Bastie
    Dixon Bastie
    The TeleTouch in my Citation always draws a crowd, and works fine. I have thefactory heat shield on it, and we routed all motor wires in looms away from exhaust and trans case. Am going to get the TeleTouch from the Corsair rebuilt and get new relays to keep as spares for the Citation. As for the Corsair, I want to twist the key, grab the shift lever, pull it into Drive, and go. Tho k the 351/FMX will move it down the road just fine, but I do enjoy punching the E475 in the Citation, though.
  21. bobss396
    bobss396
    A few things killed the Edsel, the '58 grille was not well received, problems ***ociated with the tele-touch and it came along at the wrong time, the 1957-1958 recession. Also competed with the Ford and Mercury lines at the time. Ford in general was plagued with quality issues across all their product lines.
  22. xpletiv
    xpletiv
    from chiburbs
    Although I'm trying to pay attention, the "quoting" is throwing it off.
    Coffee!!
