Projects new member. watch me section my Desoto.
Discussion in 'The Hokey Ass Message Board' started by rytang, Jun 29, 2016.
  1. gimpyshotrods
    gimpyshotrods
    Is that one of the years that has RH and LH threads, depending on what side of the car you are on?
  2. rytang
    rytang
    from Arizona
    Correct. I'm almost thinking this car will never have mag wheels by the way it's going.
  3. gimpyshotrods
    gimpyshotrods
    Skirts on the rear, with trim rings only on the wheels. Cadillac sombreros on the front.
    100% Kustom.
    brEad, belair, kidcampbell71 and 2 others like this.
  4. BJR
    BJR
    Can't you just screw in hardened studs with lock tight into the hubs. That's what we do with the 70's Airstream trailers to convert the old ones to the new "mag style" wheels.
  5. rjones35
    rjones35
    Cragers didn't have the oval indent, Keystones did, and maybe others. Crager just used a thick offset or centered washer depending on bolt pattern.
  6. rytang
    rytang
    from Arizona
    I'm sure I could on the driver's side, the p***enger side is a whole nother story.
  7. Gerrys
    Gerrys
    You could drill and use press in studs.
    rytang likes this.
  8. rytang
    rytang
    from Arizona
    That sounds doable... What would I need to do?
  9. Gerrys
    Gerrys
    RockinRivi likes this.
  10. gimpyshotrods
    gimpyshotrods
    Here is a copy of the Dorman catalog, that has wheel studs in it: http://www.billavista.com/tech/pdf_...Tires/Dorman Wheel Studs and Nuts Catalog.pdf
    That shows the specs (scroll down to section 10, page 142).
    I would recommend that a machine shop drill out your current holes, and cut a flat on the back side for the head to sit on. That catalog should contain studs that will make it all the way through your hubs/drums/etc., and have enough to get through the wheel. A good machine shop should be able to help you select the right ones.
    Unilug mag wheels do not require special studs, as long as they are long enough (and not too long). They require special nuts and washers.
  11. rocketbob
    rocketbob
    from West Texas
    Previous owner of my 47 Plymouth Conv had done the front hubs as Gerrys suggests. I've since changed to a Nova subframe, but it worked very well.
  12. choptop40
    choptop40
    Nice polish on that pair...the 51 I had went to a fellow in south houston...yours is so cool....keep up the posts
  13. Big_John
    Big_John
    from Upstate NY
    McMaster-Carr has B7 Grade right and left hand 1/2-20 threaded rod.
    https://www.mcmaster.com/#standard-threaded-rods/=173pagd
    BTW, p***enger side is right hand threads, driver side is left hand.
  14. uglysteve
    uglysteve
    I did that on my Plymouth. I think I used ford explorer studs. Got them at Napa. Drilled out the threads and I think I just used in impact to pull the studs through the hub.
    rytang likes this.
  15. Gerrys
    Gerrys
    Would still have to find a source for the left hand thread lug nuts.
  16. greybeard360
    greybeard360
    Suthunman, George and kidcampbell71 like this.
  17. CURSED GEARS
    CURSED GEARS
    Those wheels cleaned up great! What you use?
  18. rytang
    rytang
    from Arizona
    Did you take any photos??
  19. rytang
    rytang
    from Arizona
    SOS pads and water. Then Nevr-Dull to polish.
  20. CURSED GEARS
    CURSED GEARS
    Looks like $50.00 well spent.
    brEad likes this.
  21. rytang
    rytang
    from Arizona
    Well I got some studs made to mount wheels... Found out 14s won't fit over the brakes. So now I'm looking for 15s. Anyone have any cragar ss for sale? Or a similar wheel?
  22. rytang
    rytang
    from Arizona
    Well yesterday I scored on craigslist. I found (2) 15x7 Cragar SS wheels and 5 caps. (I still need to find 2 more 15x7) I met with the guy and bought them right away. The 2 used cragars, had never been used. And the 5 caps were all still in the plastic, in the box. (I got the caps for $5 each)
    20170416_104928.jpg 20170416_105519_HDR.jpg 20170416_111703.jpg So I went home to see if the drivers side stud set my friend made (still making them for p***enger side) will work. They will, but 6 out of the 10 he made were bent. But I still put the cragars on to see how they look. Then I got excited and lowered the rear down. 20170416_121715.jpg 20170416_175919.jpg 20170416_180905.jpg 20170416_181126.jpg I love the cl***ic look of these on the car. I think after I find 2 more wheels I'm gonna get the 3 bar spinners for them. I think that will look awesome! If anyone has 2 nice cragar ss they would like to get rid of, please let me know!!
  23. Johnboy34
    Johnboy34
    from Seattle,Wa
    Good score!
    rytang likes this.
  24. brEad
    brEad
    Great score on the wheels and center caps!
    rytang likes this.
  25. gimpyshotrods
    gimpyshotrods
    Still unsure why you want to put muscle car wheels on a kustom.
  26. rytang
    rytang
    from Arizona
    For the 60s era I'm going for, I can't think of a better wheel. Cragars and Supremes are my absolute favorite.
    13lav, RockinRivi, uglysteve and 6 others like this.
  27. kidcampbell71
    kidcampbell71
    ..... so a sectioned, diced and sliced, light hooded, and leaded 50's era, wild, Valley Kustom inspired roadster sled, was discovered in '68 and splashed with Cragar S/S's. Hmmm'. Maybe it was '78.
    Your car. So talented ! So Kustom. Man, those wheels though. Too smooth and statement making to just up and chonk some 1979 air shocked Z28 Camaro wheels on it. Apologies ahead of time, but yikes man !
    I keep waiting for a "pull my finger" sound effect joke. Like your f#ckin' with us, or sometin'. <ferrrrrttttttt !> Gseundheit !!!!
    tb33anda3rd likes this.
  28. tb33anda3rd
    tb33anda3rd
  29. El Caballo
    El Caballo
    from Houston TX
    Like Burger King, have it your way.
    Get the tri-bar spinners for those Cragars and put some pinner whites on; no apologies necessary.
    Jrs50, Sancho, slv63 and 2 others like this.
  30. brEad
    brEad
    Good idea. Make it look like you were the first guy in town to get Cragars.
    RockinRivi and rytang like this.
