Projects Dragmaster Dragster Found Hanging On A Wall.
Discussion in 'Traditional Hot Rods' started by 1947knuck, Mar 30, 2017.
  1. 1947knuck
    1947knuck
    I bought a Stewart Warner military oil pressure gauge on e-bay. It's the same as a civilian gauge except the bezel is military green instead of chrome. The gauge was sealed in it's original packaging and the box was dated June 1960. I couldn't resist mounting it with a zip tie just to get a look. I like the green bezel. IMG_2065.JPG
  2. 1947knuck
    1947knuck
    That is such a nice offer, especially when you see what they cost. When I dropped the engine off at Dodes on my second trip he had the guide plates, rockers, pushrods and screw in studs. I appreciate the thought and your offer. Charles.
    Spoggie, TBirdGirl26, loner2 and 6 others like this.
  3. DDDenny
  4. brad2v
    brad2v
    And in the same spirit, in the event you do need v/c spacers, I have a set that I don't need, you can have 'em. I'll even pay the freight
    Spoggie, 1947knuck, Mtn Goat and 5 others like this.
  5. rgdavid
    rgdavid
    I would like to see that please.
    This dragster build is amazing, really enjoying it.
  6. 1947knuck
    1947knuck
    John made the bracket for the Moon gas pedal, and these are the seat belts we're using. IMG_2075.JPG IMG_2068.JPG
  7. 1947knuck
    1947knuck
    The side view with the new rear wheels. You can just make out in this picture the top left frame rail has three small guide tubes we're guessing were for a cable support. We're using them for the Enderle
    thumbnail_20160226_151713.jpg fuel shut off cable. Check out the number of holes in the front engine mount plate, and the rear bell housing plate. It looks like it had some different combination's in it's life.
  8. Kan Kustom
    Kan Kustom
    It is packed away from when I moved to my new shop. I haven't unpacked everything yet but when I do I will try to remember to post it. I cant bring myself to build it since its been untouched for so long.
  9. 1947knuck
    1947knuck
    The Moon pedal's in place. The on-off switch and pull cable for the fuel shut off fit the holes in the original bracket perfect. The seat and head rest were built to fit the snap fittings that were original to the frame. When you look at the pictures when the frame was at Turners Salvage there is one piece of headrest material still snapped to the frame that was black, so we went back with black. IMG_2079.JPG IMG_2097.JPG
  10. This is my favourite thread at the moment, I'm loving it all.
  11. 1947knuck
    1947knuck
    At the same time we were building the engine mounting plates a friend of Dodes sent a picture to my son's phone of the blower and related parts. Don Hampton built the blower with the correct end plates, Verne Tomlinson got all the Hilborn pieces including the original vintage pump seen in the plastic bag. A friend of Dodes, Jay Carpenter found the correct intake for the build, and Dode told me he replaced the gold anodized bolts on the blower end plates with bolts that had a regular finish. thumbnail_IMG_0351.jpg
  12. 1947knuck
    1947knuck
    We had a Wedge M/T scatter shield and an old distributor on this engine block to use as a measurement guide when we made the front and rear engine mounts. IMG_2095.JPG
  13. Runnin shine
    Runnin shine
    Are you kidding me? You guys have a board tracker too! Anything over there I shouldn't be jealous of?[emoji19]
    Spoggie, 1947knuck and loudbang like this.
  14. 1947knuck
    1947knuck
    It's a 1916 Indian board tracker. Since this picture I've finished the two drive chains, mounted the rear bobbed fender and most of the linkage for the controls. It's close to finished. IMG_1854.JPG
  15. flathead_10
    flathead_10
    from Kansas
    Must be nice having money.
    As soon as I got a race car, I never saw another hundred dollar bill.
    mad mikey and Kan Kustom like this.
  16. 1947knuck
    1947knuck
    We made a firewall out of poster board for a guide to where the engine would mount in the frame. IMG_2109.JPG
  17. 1947knuck
    1947knuck
    We decided at this point to have the driveline built to line it up before bolting the engine mounts to the frame. I wanted to modify a PTO, I discussed my ideas with a company that builds driveshafts and decided on this. I had a PTO built with a hardened shaft and had the standard driveshaft face left on until everything was measured. IMG_2105.JPG IMG_2106.JPG
  18. 1947knuck
    1947knuck
    With the PTO in place we used it's centerline along with the centerline of the pinon shaft to set the rear height and also center the engine in the frame then bolted the rear mounts in place with just one bolt in each mount to allow the engine to pivot if the front needed to be raised or lowered to set the final angle of the driveshaft. IMG_2108.JPG
  19. UK Slingshot
    UK Slingshot
    How is that PTO drive work? Looks an interesting idea [emoji1303]
  20. 1947knuck
    1947knuck
    I first saw one 30+ years ago on an irrigation engine, their used to engage and disengage the pump drive using a hand lever. It simplified the work for our direct drive. Here's a picture of an irrigation engine with a PTO. 7d195f_96f78738eed8474c9be37386f42646a6.jpg
  21. 1947knuck
    1947knuck
    While the PTO was being modified and the driveshaft built, we moved to the front engine mount. We were going to use what I suppose is a fairly standard front sbc mounting plate except the arms going to the frame were too high. We made a design using the standard plate as a partial pattern to build one with lower arms that better fit the frame. All we had left to do was tig the angled ends to finish the mounting plate. IMG_2110.JPG IMG_2111.JPG
  22. Runnin shine
    Runnin shine
    Are you and your son both going to politely share driving duties? Or will there be arm wrestling, coin flips, calling shotgun, pulling seniority, tests of ones love/respect for the other, and outright not getting out of the seat?
    winr, 1947knuck, OahuEli and 3 others like this.
  23. 1947knuck
    1947knuck
    That issue was laid to rest just after we got it. It was so tight when I wedged down in the seat back in the roll cage, legs over the rear end that John had to help me get out. My exact words to John when I got out, "To Hell With That". It fits him perfect, so the gas and clutch pedal were mounted to fit him.
    TBirdGirl26, loner2, Stebo27 and 8 others like this.
  24. 1947knuck
    1947knuck
    While we were waiting for the driveshaft and PTO, Dode sent us a picture of his progress on the engine. The picture was taken by his friend and although it's blurry I thought I should still post it. I called Dode the same day and he told me everything was going good at his point, that the rockers were just sitting in place while he tried to work out a way to fit all this under the stock corvette valve covers. thumbnail_IMG_0348.jpg
  25. dreracecar
    dreracecar
    from so-cal
    Better to bolt the plate to mounts on the frame itself, welding onto 6061 alu draws the heat treat down and you are dealing with a part thats loaded
    Spoggie, chryslerfan55 and loudbang like this.
  26. 1947knuck
    1947knuck
    The Driveshaft builder called our parts were ready to pick up and check the fit. They machined the driveshaft side of the PTO to fit the yoke flush. Because of length restrictions the driveshaft at this point was basically a slip yoke. It was left that way so if we made any minor changes and it needed to be a little shorter or longer we could adjust it. Once the exact length was set they would weld a small diameter tube between the yokes keeping the slip joint in place. IMG_2112.JPG IMG_2113.JPG
  27. 1947knuck
    1947knuck
    We explained how the engine plate was going to be used with the welder so he welded the ends on the plate using 4043 filler wire and then we had the piece heat-treated.
    Spoggie, TBirdGirl26, loner2 and 5 others like this.
  28. 1947knuck
    1947knuck
    This is the shield for the driveshaft. The plate is the same shape as the PTO so it is held in place bolted to the scatter shield. The round plate with the lip bolts to the face of the M/T third member. We cut the tube in half with a plasma cutter tacked the brackets on either side and clamped it in place. Using the rear end plate as a guide we lined it up and tacked the ring to the plate bolted to the scatter shield. With all the pieces lined up and tacked in place we took it apart and welded everything up. IMG_2125.JPG IMG_2132.JPG
  29. 1947knuck
    1947knuck
    Well my wife is giving me the look, she say's I've been on the HAMB long enough. I'll try and sneak back here later. tumblr_mdp6ejDjxJ1rwsq0no1_500.jpg
  30. hotrodfords
    hotrodfords
    What a bitchin' thread! Thanks for taking us along for the ride.
