Hot Rods The ALTERED thread
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 3, 2016.
  1. Roothawg
    Roothawg
    What's the wheelbase on your car Pnevells?
    els likes this.
  2. pnevells
    pnevells
    125, we did this ch***is from a project startedby another Hamber, we hung our own ladder bar suspension off of a frame that started as a Speedway T, the wheelbase was unknown until we got it built, a little long for some purists ,but drives well and hooks eveywher we have raced it,
  3. loudbang
    This series is of a "home built" early altered. I don't know who owed it or anything about it found on the web.
    Yes two guys are lifting the ch***is up in the air
    At Pomona in the staging lanes
  4. loudbang
    Bad Habit GREAT SHOT
    LIL Screamer
    again
  5. Here is my Dad Gary Essman in the blue shirt with the Black Magic car he only drove the Black Magic for a short time . This is the car they made after the purple Magic Muffler that my Dad was the main driver for after Jim Miles the owner raced it for a short time. I'm going to the Texas LONESTAR ROUNDUP today . I will share some pictures of any old altered's in the upcoming days unnamed (1).jpg
  6. els and loudbang like this.
  7. loudbang
    Great shot of the black MM car
  8. c-10 simplex
    c-10 simplex
    i'm not protesting that the 55 in post #889 and the fairlane in post #893 (which, to me, if anything looks more afx.....) ARE NOT altereds. But if they ARE altereds, then how are altereds defined?
    els likes this.
  9. mohead1
    mohead1
    Sounds like one of u guys need to sell me a car if yall aint runnin em, hehehe [emoji41]
    Sent from my SM-G900V using Tapatalk
    els likes this.
  10. Junior Stock
    Junior Stock
    I guess in a nut shell it's simply a cl*** based on weight per cubic inch.
    chevy454 scanned the rule books for 1958-1968 a couple of years ago.
    http://www.jalopyjournal.com/forum/threads/nhra-rule-books-1958-present.870742/
  11. Junior Stock
    Junior Stock
    Kay Sissell's altered when it was GMC powered.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    There are a number of modifications that would put a full bodied car into the Altered cl***, and they varied somewhat depending on the time period. Removal of front end sheet metal, excessive engine setback, wheelbase changes, driver relocation, etc. Even something as simple as deleting the headlights can do it. Often times full-bodied cars that would normally be placed in a /Super Stock or /Gas cl*** would make some subtle change to run in the Altered cl*** if the Altered cl*** records or indexes were more favorable. Or maybe a big shooter in the same cl*** as you would show up at a race and be faster than you. You could change to an Altered cl*** so you would not have to run him in cl*** runoffs. Running as an Altered may also put you in an eliminator bracket that pays out more money, or has fewer entries.
    So when folks say they long for the old days of drag racing when the guy with the faster car wins, well, they really don't understand all the intricacies of what it took to field a compe***ive drag car. Juggling cl***es along the way was one tool the racer had to achieve success.
    els, stillrunners, t-rod and 4 others like this.
  13. loudbang
    They are altereds because that is the cl*** they are running. In both these case PROBABLY engine set back.
  14. Roothawg
    Roothawg
    Although, technically I could see how they were accepted, if I were setting up a racing org it would have to be fender less. Otherwise, you would end up with a bunch of rat rod 4 door Plymouth Valiants with no front sheet metal.
  15. loudbang
    Ron Ellis Instant T
    just the engine
    Russel & Rice
    Rapp Chevrolet Thunderation Vette running C/altered
  16. saltflats
    saltflats
    from Missouri
    Info I just heard about the vet ( The Rapp Chevrolet is from Thunder Valley Dragway in Marion, South Dakota.
    Glenn Rapp is still the owner and operator of the dragstrip. )
  17. loudbang
    Dukes Automotive AWB running altered
  18. Junior Stock
    Junior Stock
    If you make a center steer rule that would keep it what most consider to be a traditional altered.
    els likes this.
  19. Roothawg
    Roothawg
    Meaning center steer only? That might be the ticket....
    els likes this.
  20. ididntdoit1960
    ididntdoit1960
    from Western MA
    Then you would miss out on the early coupes with the motors under the cowl and the driver in the back as far as he could go (but still LHD).....the genesis of the cl*** in my mind.....
    els likes this.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I run in a Nostalgia Comp cl*** at a few races during the year with my old Logghe altered, when my racing schedule for my Super Pro (avatar) altered has an open date. It is set up on an index basis - 10.50, 10.0, 9.50, 9,0...7.50 - and is open to all altered roadsters and front engined dragsters. The cl*** only draws about six or eight cars usually. It has a $50 entry fee, and the promoter loses money at every race because his purse payout exceeds the entry fees. The purse encourages guys to spend the resources - time and money - to get the car to the track. In order to increase the car count and try to keep the track out of the red they are considering letting full bodied altered cars run this summer.
    I bring this up because I've seen how easy it is to so narrowly define the type of car that you are going to allow that you severely restrict the number of entries. This does not make for an exciting cl*** nor a profitable one for the strip owners.
    An example of this would be the HAMB dragsters. While I think it is laudable to try to garner interest in a low cost, traditional type of drag car the rules are so narrowly structured that one almost has to build one from scratch to comply with them all. When was the last time you saw more than a few HAMB dragsters race at the same venue?
    So if you want to create a cl*** / club / organization for trad altereds that will actually race each other down the track then think inclusive, not exclusive.
    els and NHRANUT like this.
  22. Old6rodder
    Old6rodder
    from SoCal
    Actually, building it your self from scratch was the intended pathway to a HA/GR. So yes, it was self limiting in the long run, as very few folks capable of the work're content with a 12.00+ car (the targeted ET, for cost reasons). The SDRA & NWVD spin-offs're doing a bit better, as they're easier to build & drive, and are quicker. But they still suffer from the same problem, albeit slightly less so. It helps that they don't care about the work being done by a shop.
    And as others've noted, when the rules're loose enough, someone'll spend the money for even the most obscure win.
    els likes this.
  23. old sparks
    old sparks
    when the rules are to strict, the cl*** eventually dies because both the racers and spectators lose interest. even anra with its open wheel cl*** 10.00 or slower is used to prep the track and spectators don`t watch it any more than they watch the throttle stop cars at a national event. the best thing about anra`s open wheel is you don`t have to jump thru the certification hoops and it`s bracket racing which requires more out of the driver
    els likes this.
  24. loudbang
    Posted by tommyd in the in motion thread
    Maffia Mouse
  25. saltflats
    saltflats
    from Missouri
  26. loudbang
    Keep The Faith Baby vette running altered
    Jim Milligan
    Rat Poison
  27. Junior Stock
    Junior Stock
    An updated older car that I saw at the races yesterday at the fuel altered races in Okla. City.
  28. mohead1
    mohead1
    Nice shot of Pure Heaven II at Cecil....i grew up there, raced that track many times
  29. quicksilverart46
    quicksilverart46
    I was fortunate to be asked to do all the Pinstriping and 23k gold leaf Lettering on the restored Mondello /Matsubara AA/FA a few years ago ..[​IMG][​IMG][​IMG]
  30. mohead1
    mohead1
    Very cool....where is this car now that Joe is gone? Is there still a facility in Tennessee?
    els likes this.
