Features Gmc blowers
Discussion in 'Traditional Hot Rods' started by coopsdaddy, Sep 1, 2012.
  1. glempan
    glempan
    from Sweden
    Its for a boat and its like a regular 6-71 blower it just has water channels in it. Nowdays they use the superchiller to cool the fuel. It has never been used, N.O.S . I dont have any pics yet but will soon when i get it home from USA. I have a picture of a similar blower.
    This is not mine.
    1947knuck and Deuces like this.
  2. glempan
    glempan
    from Sweden
    I will ask the guy i bought it from. :)
  3. Mooneyham
  4. DDDenny
    Very COOL!!!
    Never seen one of these before
  5. wheelguy
    wheelguy
    PG SHIFTER  RAT ROD AC 160.JPG Johnny Lightning 41 Willys 013.JPG Johnny Lightning 41 Willys 015.JPG 471 with Cragar/Weiand intake and Cragar rear cover plate. All Cragar 2 inch drive
    Chrome plated (including intake)> "Chrome won't get you home" but if it blows up I can sell the blower and get home on a bus.
  6. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    For the Holley guy's......Boost referenced? Yea/Nae/converted yourself,or bought/or just stuck one on and are running with it? If so- notice anything? performance? Mechanical secondaries? Tough to stab 2 fours,and the info could be helpful to the post....... Enlighten us..........
  7. paul55
    paul55
    from michigan
    Have had this 4-71 more than 25 yrs. Was on a T roadster. Weiand intake and carb adapter, with M/T drive. Probably put it on the Nomad this summer. 471 blower 001.JPG 471 blower 002.JPG 471 blower 003.JPG
  8. JimSibley
    JimSibley
    Here's a few of mine. The polished one is a complete cragar kit with a wiend intake.The satin one is a ho
    Rebuilt setup also with a wiend intake. ImageUploadedByH.A.M.B.1427856914.715609.jpg and just for fun I included a pic of my baby nailhead with a manga charger. ImageUploadedByH.A.M.B.1427856989.934827.jpg ImageUploadedByH.A.M.B.1427857022.901372.jpg
  9. JimSibley
    JimSibley
    Hers a few more. ATTACH=full]2871740[/ATTACH] ImageUploadedByH.A.M.B.1427861523.510054.jpg
  10. mad mikey
    mad mikey
    Gary Dyer built 471, with 950 cfm Quick Fuel blower racing carb. WIN_20150308_151735.JPG
    Deuces and 1947knuck like this.
  11. 4thhorseman
    4thhorseman
    from SW Desert
    Mine are Holley boost referenced, blower, mechanical secondary carbs. Twin 950's. Its a stroked big block so lots of cubes in a 2400lbs. car. I ended up plugging off the power valves and not using the boost referencing. The engine was just not liking it in traffic. Temp was creeping too fast with the smaller primary jets. I fattened up the primaries, plugged the power valves and the engine is happier. Squared jetting all the way. Sometimes you have to give it what it asks for regardless. Something I would not recommend unless -like me- you are interested in racing it.... I have 1:1 linkage on each carb between the primaries and secondaries, and both carbs operate 1:1. So when I whack it, all 8 open completely simultaneously. Holy HIT with the roots at 7psi! Light switch throttle response like an alky injected. I can be rolling along in high gear at 50mph, nail it for just a second and the slicks light off instantly. Evil.
    neverdun, swade41 and loudbang like this.
  12. digaribay
    digaribay
    Just finished building my intake manifold to mount a 6v-71 roots blower on my 330 Desoto Hemi since the originals are as rare as hens teeth and worth a pot of gold! image.jpg
    1947knuck, Deuces and loudbang like this.
  13. roseville carl
    roseville carl
    Garage built 471
  14. Paul
    Paul
    Editor
    sold this one before I had a chance to get it on the road
  15. Paul
    Paul
    Editor
    sold this one too, went to Vegas, changed hands again, now in Iowa
  16. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Hey Carl-I'm gonna have to see you pilot that thing in person.......Either it's a ****ting your pant's session,or a ****ting your pant's session! Either way,you've succeeded! Very Well Done!
  17. roseville carl
    roseville carl
  18. baldwinc
    baldwinc
    from Alaska
    Just picked up these 3 beauties! Already torn 2 of them down and have new bearings/seals on order-
    Deuces and enloe like this.
  19. roseville carl
    roseville carl
    Run at the 5.18 mark
    Deuces and moparmuscle1 like this.
  20. 550Coupe
    550Coupe
    Deuces, 1947knuck, powrshftr and 2 others like this.
  21. Saxxon
    Saxxon
    Converted GMC 6-71
    30dodgeboy, 1947knuck, Deuces and 2 others like this.
  22. tricky steve
    tricky steve
    from fenton,mo.
    I have a 10-71 on a 354, that big thing on top, is what break A LOT OF PARTS> DOH!!
    1947knuck, Deuces, hipster and 6 others like this.
  23. Elco Heads
    Elco Heads
  24. thunderbirdesq
    thunderbirdesq
    Hey @fonti look at that blower top just above, pretty neat!
    While we are here...
    1947knuck, Deuces and Runnin shine like this.
  25. Wally Elder
    Wally Elder
  26. Kan Kustom
    Kan Kustom
    It always amazes me that I have been on this forum for years and miss threads like these.
    hipster likes this.
  27. wuga
    wuga
    My 6-53 on an aluminum Buick.
    Warren
    1947knuck, Deuces, RichFox and 2 others like this.
  28. swade41
    swade41
    from Buffalo,NY
  29. Paul
    Paul
    Editor
    I have one waiting in the wings,
    for some future project.
  30. dfriend
    dfriend
    from B.C.canada
    Hi
    I have a 454 chev with a 6-71 blower with 2 Holleys that I referenced my self. I plugged the va***n port under the carb base and then drilled from the va***n side of the power valve into the va***n port for the dist. va***n advance. The I hooked a hose from there to the manifold under the blower with check valve and a bleed off in the hose.
    Regards
    Dave
