Hot Rods What do you use for a radiator overflow bottle?
Discussion in 'The Hokey Ass Message Board' started by 29StudeDude, Apr 9, 2017.
  1. 29StudeDude
    29StudeDude
    I have converted the triangle shaped GM "Optikleen" gl*** bottles to radiator overflow bottles on some of my last few builds, but have wondered if anyone has ever had these explode due to the hot coolant? What other ideas have you guys and gals used for this purpose?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I've seen lots of soda & beer bottles used with no problems. HRP
    29StudeDude likes this.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I use a radiator overflow container, I'm not very clever!
    KK
    Woogeroo, Texas57, flatter230 and 3 others like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Your a step up on me,I'm not much of a environmentalist,any overflow runs down the rubber tube and to the asphalt. HRP
  5. squirrel
    I use an old 16 oz Schlitz can on my "race car", and none at all on the other ones, because they never had them in the first place, and they survived all this time without them. So my guess, is that they are really not needed.
    (the NHRA requires a 16 oz catch can)
  6. drttrkcwby
    drttrkcwby
    I named my build after types
    of alcohol so my 63 Bel Air wagon is named Cuervo. I have a chrome Cuervo bottle for an over flow tank.
    38 mopar_fan and 29StudeDude like this.
  7. ZAPPER68
    ZAPPER68
    from BC
    I use the Moon tank as depicted in my Avatar....
  8. You and me both. The rad just ends up being an inch or so low when it's cold. No problem at all
    HOTRODPRIMER likes this.
  9. vesaku
    vesaku
    from FINLAND
    I use Grant's whiskey bottle, it is triangle and looking good.
    Woogeroo and 29StudeDude like this.
  10. I use a one gallon plastic gas can if it'll fit. I got Stanley Stainless thermose that I'll probably use on my next disaster. Neither is too high tech but all it has to do is catch coolant.
  11. Special Ed
    Special Ed
    Aluminum 1950's era Polish army canteen.
  12. 29StudeDude
    29StudeDude
    Cool.
    Atwater Mike likes this.
  13. thunderplex
    thunderplex
    Overflow??? Catch can???
    None of my cars run hot. And, if one did "wanna puke", it would do it the old fashoned way.
    Sent from my SM-N910V using The H.A.M.B. mobile app
  14. 29StudeDude
    29StudeDude
    I have one of these I ordered from a guy that makes them in the UK for my next project.
  15. 29StudeDude
    29StudeDude
    But if you have ever pulled into an event leaving a trail, or puddle of coolant under the front of your car you have to walk in, you don't want to repeat it!
    05snopro440 and Mr48chev like this.
  16. thunderplex
    thunderplex
  17. If my over heats it pukes on the ground, but I run it an inch low so I haven't had any over heating problems..LOL.Bruce.
  18. Blues4U
    Blues4U
    from So Cal
    I use an aluminum insulated bottle for cold/hot drinks, converted to serve as a catch can. I use it not just to be environmental, but a properly filled radiator should have a reservoir for expansion, to hold the coolant until it cools and draws it back into the radiator. Sure, old cars didn't have one, but they also had more over heating problems. IMG_7053b.JPG
    Alienbaby17, Paul, Woogeroo and 4 others like this.
  19. GTS225
    GTS225
    Would that be the can or the strap and mount tabs?
    Roger
    05snopro440 likes this.
  20. 29StudeDude
    29StudeDude
    He sends you everything pictured with either a polished or painted mount, black or brown strap, with or without decal.
  21. GTS225
    GTS225
    Hmmmm. Care to share the cost and supplier contact info?
    Roger
  22. 29StudeDude
    29StudeDude
  23. dirty old man
    dirty old man
    On the street, all I use on either hot rod is a rubber hose. Don't race the '40 coupe, but on BGII, my hiboy '31 roadster, when I go to the strip I usually zip tie a drink bottle to the lower right hand headlight bracket and insert that rubber tube in it. Think I'm going to keep an eye out for one of those extruded aluminum beer cans with the twist top and hang on to it for use. Not too concerned about the NHRA requirement of 16oz. because if they get that strict I'm not going to be allowed to run a ******* roadster with no roll bar anyhow :eek:
    I bought one of those stainless puke tanks Speedway sells and replumbed it to work like the one Blues4U posted, but it looks so klunky I never installed it as I never lose any coolant from my Walker radiator.:cool:
  24. GTS225
    GTS225
    Thanks, 29Stude; I don't do the F-book thing, but I do know how to Google.
    Roger
  25. 59Apachegail
    59Apachegail
    from New York
    JW blue bottle I got free (empty) at a party. It matches my paint pretty nicely and a little irony in my old tired truck.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I used a hunk of O/T Corvette aluminum driveshaft with hammerformed ends. Adding an overflow bottle adds about 10% to the cooling efficiency of your system.
    And like my Granny said just before she fell off the Harley, "Its like a seven figure bank account, 500 HP under the hood, or a .45 strapped to your hip. You may never need it...but isn't it nice to know it's there."
    05snopro440, Montana1 and 29StudeDude like this.
  27. c322348
    c322348
    I user an antique gl*** embalming fluid bottle.
    indyjps and deadbeat like this.
  28. LOL I sometimes go really fast for a very short distance in my old junk and they guys who rent me the asphalt really want me to have a can. :D
    XXL__ likes this.
  29. Chaz
    Chaz
    A hose that dumps on the ground would be traditional AND period correct.
    FishFry, buddyamigo and jeffd1988 like this.
  30. Special Ed
    Special Ed
    I know it's kinda funny to some of you, after reading your posts about letting coolant run onto the asphalt, but some of us actually have to swim and surf in your carelessness. If a dog slurps up some antifreeze, he's dead. If you live in a state near the ocean, that **** eventually flows into the sea. If you live inland, that **** eventually feeds into your well. Think about it .... you want your kids or grand-kids drinking it?
