Hot Rods I need a brake pedal ~ UPDATE
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 10, 2017.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Anyone know of a vendor that will sell just the pedal for a hot rod,I am still working on the brakes and have determined the major problem is the sever modification that was made when it was shortened.
    Needs to be the type that's mounted under the car.
    All the vendors I am aware of want to sell me the entire ***embly which I don't need, I have posted a photo of what I need,if all else fails I can purchase the entire ***embly from Ch***is Engineering,HRP
    ladyhrp and chryslerfan55 like this.
  2. Torana68
    Torana68
    from Australia
    If no one else closer can help I think I have one here somewhere , free but + post (and Id have to go search for it)
    ladyhrp and HOTRODPRIMER like this.
  3. Pete Eastwood
    Pete Eastwood
    from california
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    Pete & Jake's X 2 OR Cut it and fab a piece to put it back where it should be, bevel, weld, grind and done.
  5. nunattax
    nunattax
    cant you make another,thats what hot roddings about.buying stuff isnt the only way.i admire the aussies ans the swedes esp who despite being far away from the source of parts in us make the stuff themselves to a high standard.
    ladyhrp, Cooon, Avgas and 2 others like this.
  6. Atwater Mike
    Atwater Mike
    I cut one from a 3/8" plate of steel for a customer...Made a cardboard template and flame cut it (just as Jake used to do when he and P-Wood were designing the original Pete & Jakes hardware for the new 'P&J Hot Rod Repair' venture)
    The steel's cheap, plasma cutters are common as oxy-acet rigs, and the top tapped loop for brake pedal can be a 1/2" SAE nut welded on 'outrigger style'.
    You can get specs right where the template was, and not be confounded by 'adjustments' to someone else's 'fits-alls'.
  7. 34toddster
    34toddster
    from Missouri
    Just call Jason at Pete & Jakes he'll get you what ever you need, has for me several times. I bought one without the tube welded in so I could position it where I wanted it.
    ladyhrp, HOTRODPRIMER and da34guy like this.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Which facility is Jason employed? HRP
    ladyhrp likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    This is not my first rodeo and I was fabricating parts log before the advent of 1-800 parts but time is of the essence and there is already too many irons in the fire,I have tried to make the existing pedal work but it's still not right. HRP
    hotrodharry2 and ladyhrp like this.
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
  11. HOTRODPRIMER
    HOTRODPRIMER
    Thanks man. HRP
    ladyhrp likes this.
  12. krylon32
    krylon32
    from Nebraska
    I just looked and P&J's has the pedal priced separately.
  13. stillrunners
    stillrunners
    from dallas
    think you'll do better with the 816 758-4504 number......
  14. HOTRODPRIMER
    HOTRODPRIMER
    Pete & Jake on line catalog does list the pedal separate but they don't show a price, HRP
    ladyhrp likes this.
  15. 26hotrod
    26hotrod
    from landis n c
    Call P&J and you will be happy. Always been helpful to me...........
  16. Welders Series sells separately, as well.
  17. dirty old man
    dirty old man
    Danny, if you need to woory about the price, just dig up one of those fruit jars you have buried!:rolleyes:
    ladyhrp and rfraze like this.
  18. deucetruck
    deucetruck
    from Missouri
    The last one I bought - about 2 years ago - was $69.00.
  19. KENDEUCE
    KENDEUCE
  20. Gman0046
    Gman0046
    Danny, ECI has a pedal for $40. No cutting, welding, grinding or painting..
    Gary
    ladyhrp, 39cdan and HOTRODPRIMER like this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    Very generous and I appreciate the offer but I've wasted too much time trying fabricate the pedal and I'm trying to get the car ready for a road trip next month.HRP
    ladyhrp likes this.
  22. Gman0046
    Gman0046
    A new pedal to me is so cheap its the way I'd go. Maybe I just work slow as it would cost me much more in my time then its worth.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Dave,it's not that I fear the price but if it's close to the price of a complete pedal ***embly I can buy that locally. HRP
    ladyhrp likes this.
  24. deuceman32
    deuceman32
  25. HOTRODPRIMER
    HOTRODPRIMER
    Called Pete & Jakes and talked to Jason,very helpful.
    I have a pedal on the way,thanks for all the information.HRP
    ladyhrp, 34toddster and Johnboy34 like this.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Talk about fast customer service,when I stopped by the shop today I was told UPS left something for me,I honestly didn't expect to get the new pedal this week.
    Thank you guys. HRP
    ladyhrp likes this.
  27. 325w
    325w
    Well heck! They know who you are. Everybody knows you!
    ladyhrp likes this.
  28. HOTRODPRIMER
    HOTRODPRIMER
    ****,if they know anything about me it would have to be that I have a vivid imagination and can provide hours of unadulterated banter that can be amusing but lacking in meaningful content! HRP.
    ladyhrp and 48stude like this.
  29. HOTRODPRIMER
    HOTRODPRIMER
    Well guys I have installed the new brake pedal and although it helped a little the brakes still leave a lot to be desired.
    I have installed the adjustable proportional valve and I didn't see any difference/
    To refresh the memory disc front/drum rear non power brakes and I still have a extremely hard pedal and about 2" travel. HRP
    ladyhrp likes this.
  30. Johnboy34
    Johnboy34
    from Seattle,Wa
    Well, if now you know the pedal ratio is right.....Next on the list ( because it would be easiest ) would be to pull the master cylinder and drop it one bore size. That is if you have had the wheels off and checked the brakes themselves. Did you ever check pressures, front and rear? It really sounds like the master is too big, ( interweb diagnostics ) at least that is where I would go next.
