Projects AWB Chevy II build
Discussion in 'The Hokey Ass Message Board' started by Doctorterry, Apr 10, 2017.
  1. Doctorterry
    Doctorterry
    My journey through turning a heap into an altered wheel base drag car.
    turboroadster likes this.
  2. Doctorterry
    Doctorterry
    I got this Chevy II from a man in Tulsa Oklahoma. We drug it home probably 6 months ago. Finally decided to pull it into the shop today and start tearing it apart. There are no floors in it due to rust. It needs rear quarters bad, but that all can be fixed. It's gonna get a straight axle with a Ford 9 inch, and a 400 SBC. Today I got the front clip pulled, I have good sheet metal for the front clip.
  3. Doctorterry
    Doctorterry
  4. Doctorterry
    Doctorterry
    Runnin shine likes this.
  5. squirrel
  6. OK.I don't even try anymore. Have fun!
    hotroddon and X38 like this.
  7. 1965L79SS
    1965L79SS
    Looks like it may take alittle elbow grease but the end product will be well worth it!
  8. chevy57dude
    chevy57dude
    Well, the trunk looks a little drafty! A vote here to shove the rear axle forward oh, 8'' should do it.
    Great project.
    mad mikey and Doctorterry like this.
  9. 56sedandelivery
    56sedandelivery
    I like the little, boxy, 62-65 Nova's/Chevy II's; you've got your work cut out for you. I would't have thought an Oklahoma car would have had that much rust. Follow squirrels' and White Noise builds for ideas; there are a few more here on the HAMB also. Good luck. I am Butch/56sedandelivery.
    r@tt3r and mad mikey like this.
  10. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Just a simple Q? Is it going to be an AWB, or a G***er? 4 lugger.....63 i'm thinking.....
    but , with zero trim, and a sedan, possibly a 62. enlighten us a lil.......
    greybeard360 and squirrel like this.
  11. Ford Freak
    Ford Freak
    Looks like it will be a very early funny car STYLE Nova . Should be fun , either way !
    powrshftr and Gary Reynolds like this.
  12. KoolKat-57
    KoolKat-57
    from Dublin, OH
    A pile of sheet metal, a couple of large rolls of mig wire, and a large bottle or 2 of argon, and it's off to the races!
    Have a lot of fun with your project, looking forward to progress reports!
    KK
    enloe likes this.
  13. Doctorterry
    Doctorterry
    Can't an altered wheel base be a g***er? And it's a '62 or so I was told. No ***le. I plan on moving the rear axle about 8 inches and the front axles around 2 inches. I did look at squirrels build and it was very inspiring when it came to my mental planning. Have any of you seen the Clark speed special? John clark's altered Chevy II? I see his car a lot and I crawl under and around it every chance I get to take mental notes
  14. squirrel
    Yeah, I saw John at the Meltdowns 2015.
    G***er cl*** did not allow altered wheelbase cars like mine. Look up the rules, if you want to learn the history...
    I posted a few pages from the 1966 AHRA book, I think you can find the NHRA online if you search?
    http://selectric.org/ahra/1966rules/index.html
  15. Boyd Wylie
    Boyd Wylie
    Alter the wheelbase and you have an Altered. Not a G***er.
  16. squirrel
    If you build a car like mine, you have a match racer....don't fit in any cl***.
    BradinNC, hotroddon and Larry T like this.
  17. Doc, The AWB cars are the descendants of the Funny Car.
    A straight axle is not what makes a car a g***er , (Gas Coupe and Sedan)
    I'm not sure whether you knew that.
    (Should have said precursor,forerunner, predecessor, forefather, , antecedent)
  18. squirrel
    Ancestors, not descendants? One way or the other, they're related :)
    oneratfink57 and belair like this.
  19. Oh yeah ! Thanks. I was writing in reverse gear ,I guess.
    Max Gearhead and squirrel like this.
  20. TFoch
    TFoch
    Looks like a project car to me! Can't wait to see where it goes.
  21. Doctorterry
    Doctorterry
    I thought g***ers had the front end raised to help with weight transfer, and an altered just took that concept to the next level... guess I should do some more studying
    Gary Reynolds likes this.
  22. rusty rocket
    rusty rocket
    Man it looks like you had better get some bracing in there to hold what left of it.
  23. squirrel
    The raised front end was not something that was specific to Gas cl*** cars. It was the way to get more weight transfer, and was used in other cl***es, as well.
    The altered wheelbase thing was a wild idea to get even more weight on the rear tires, and it didn't take long for the rule makers to ban it in just about all cl***es. But the cars put on a good show, so they ended up in match races in many cases. I don't know nearly as much of the history of this as several other folks here...if you do some research, you can find a lot written on the subject.
    Of course, to most folks today, the history is not important...what is important is how neat the cars look, and how fun they are to race
    RICH B, 62hotcat and Doctorterry like this.
  24. Doctorterry
    Doctorterry
    [​IMG][​IMG]
    Last pictures from last night. I stopped to finish wiring the lift. I'll be back at it after work.
    powrshftr likes this.
  25. Well it could be a Gas Altered as opposed to a Fuel Altered.
    **/GA instead of **/FA
    But it is not likely that they would have allowed it to run in altered cl*** either, most likely as Jim ( @squirrel ) says a match bash car. I am not an expert but I am not sure that Novas ( chevy IIs ) ran I AWB cl***.
    never the less they are fun and fun is what its all about right?
    lawman and Doctorterry like this.
  26. Doctorterry
    Doctorterry
    [​IMG][​IMG][​IMG][​IMG]
    I plan on building the frame out of 2x3... does anyone have an opinion on what gauge I should use? I plan on setting down inside the original subframe, and sliding it forward into the pockets shown in the last picture and welding it in.
  27. Doctorterry
    Doctorterry
    I'm not going to do any more rust removal from the Fire wall until I get it braced up a bit
  28. 51box
    51box
    from MA
    Man that's an ambitious project, good luck with it.
    Doctorterry likes this.
  29. Doctorterry
    Doctorterry
    Well I plan on putting aluminum floors in it, and I have to do frame work anyways, and quarters aren't the most difficult thing.... maybe all the rust saved me time cutting [emoji23]
  30. Doctorterry
    Doctorterry
    [​IMG][​IMG]
    Sub frame is cleaning up nicely... I cut these end pieces out so my new frame rails can sit down in there.
