Hot Rods 455 Olds help.
Discussion in 'The Hokey Ass Message Board' started by Fire Fox, Apr 10, 2017.
  1. Fire Fox
    Fire Fox
    Picked up a car today from an elderly gentleman and it came with this 455. It's all new from top to bottom, Offy 2x4 intake, edelbrock carbs, new comp cam, pistons, crank, the whole nine yards. It hasn't been fully put together, we just mocked everything up to got a look at it but my question is what is the market value on this engine and are there any major concerns with them? [​IMG][​IMG][​IMG]
  2. Jalopy Joker
    Jalopy Joker
    so, know what year it is, etc? what car did you get?
  3. sunbeam
    sunbeam
    If you like 500 ft.lbs of torque you are in.
    51 BIRD and Fire Fox like this.
  4. ZAPPER68
    ZAPPER68
    from BC
    Your rear tires will definitely be a concern... :)
    Fire Fox likes this.
  5. Fire Fox
    Fire Fox
    It's a 32 3 window. It's a gl*** body car. It has a lot of nice parts on it, ugly yellow but that will change soon!
  6. 51 BIRD
    51 BIRD
    Yep! And all of it comes in right off idle. They're brutal.
  7. OLDSMAN
    OLDSMAN
    My 48 Olds has a 455 in it plenty of power for that big car when I first built it I had a 2:56 rear gear and it was a dog I put 3:08 gears in the car and made a big difference I love that big engine
  8. oldolds
    oldolds
    As others have said, lots of torque with a fair amount of H/P. The heads are a bit restrictive in an Olds motor. Don't try to twist it like a small block Chevy. Most are built for about a max of 5000 rpm . In a gl*** car I doubt you will need more engine
  9. Meltkamp
    Meltkamp
    Poor oil return from the top end. Don't sling it over 5k. Make gobs of torque right off idle. I'm not sure market value on them. I'd say 2-3k but I'm just throwing a number out there.
  10. Allegedly those heads are really good castings. You probably already know the following information so sorry if I'm covering familiar ground once more.
    http://www.442.com/oldsfaq/ofhed.htm
    C '67 - '69 425 80 394548 A/C '68 H/O's. Toro's and 442's got big.
    455 valves. Rumored to flow the best of all BB
    heads. Can still be found.
    kidcampbell71 likes this.
  11. RR
    RR
    Yep- don't rev it much or it will dump all the oil to the top of the engine and eat the crank- like mine did! And that was at just 3500RPM for a few minutes (and a high volume oil pan and pump). Value will depend on the rotating ***embly- new as in reconditioned or new as in aftermarket? The C heads flow better than most stock heads but Edelbrocks flow as good or better. To me the intake is where most of the value is at. I would say $2-3 K if you want to hold on to it for a while to the right buyer. Otherwise, $1200-2000. I virtually gave all my Olds stuff away and went back to Chevy.
  12. Bandit Billy
    Bandit Billy
    I run a Mondelo 455 in my 68. Stump puller! Put it in a Cutl*** or a speed boat, nail it, hire a chiropractor.
  13. Bandit Billy
    Bandit Billy
    Oh, if you sell stuff off of it, interested in the valve covers! I have chrome ones I can send to you.
  14. Fire Fox
    Fire Fox
