History Flathead V8 in old farm equipment
Discussion in 'The Hokey Ass Message Board' started by gtcook63, Apr 5, 2017.
  1. Atwater Mike
    Atwater Mike
    Just imagine! ...Right in my own back yard...
  2. gtcook63
    gtcook63
    Yes I grabbed the radiator - My son even grabbed the instrument gauges... He said take anything you want so we did.
    patmanta likes this.
  3. alchemy
    alchemy
    What were the gauges? They might be more valuable than the flathead.
  4. cooki3mnster
    cooki3mnster
    Hey All, here are some pics of the gauges we pulled from the old forklift. They almost remind me of some old Stewart Warners. Not sure if they even work anymore but they are still a really cool piece to hang in the house.
    bct, patmanta and kidcampbell71 like this.
  5. tubman
    tubman
    I don't know about the other two, but the ammeter and temp gauge look real good. I think the panel is the real gem here. I'd like to have something like that for my "T".
    clem likes this.
  6. k9racer
    k9racer
    Not a flat head but story from around 1951. A man named Tritton from around the Kansas area owned roadster race cars that raced on dirt, He had 3 they had straight 8 Buick engines of 320 plus cubic inch. He used his race engine on his portable grain milling machines. He said that way they were broken in by race time. His cars were fast and one is still around. I guess his farm machines were fast also...
  7. Okie Pete
    Okie Pete
    Great find and the dash looks cool.
  8. Corn Fed
    Corn Fed
    That gauge panel is Stewart Warner. Cl***ic hot rod stuff. Good find.
  9. Cool. I'll be sure to watch.
    For some reason that is way beyond my comprehension I have always been a fan of the V-8 60. If I was a rich man I would have one just to play with. ;)
    I got an SW tach that would work real well in that center hole. Now if I just had the panel. :D
    Cool find for sure ;)
  10. Bird man
    Bird man
    from Milwaukee
    Years ago I tried to buy a running 348 that was in a hay chopper. Figured I could pay a max of 650 for it and come out OK.
    He would not give me a price & would not take 700 for it. He sold it to the s****pers some time later for likely 150-200 bucks & I know the buyer came out pretty sweet when they sold that mill.
    Ya win some & loose some...
  11. BamaMav
    BamaMav
    from Berry, AL
    I used to work at a wood yard that bought pulpwood in 5" lengths. We had some old cable loaders built by Taylor in Louisville MS that were based on Ford truck parts. Flathead 6's and 8's, 4 speed truck transmissions, 1.5 ton truck rear axles. Some of them even had hoods that looked like they might have been reworked F1 or larger truck hoods, narrowed to fit the loaders. These things were purely mechanical, no hydraulics at all except for the steering. Had two huge winches, one to raise and lower the load, the other to raise and lower the boom, both driven off a pto on the trans. The newer ones had OHV Ford sixes and Y blocks in them.
    Taylor is still in business, everything they build now is hydraulic as far as I know, and diesel powered.
    Another company that built forklifts from Ford truck parts was Windham. Most of theirs were either flathead 6 or OHV 6, but I saw one or two of those with Y blocks in them, too. All the Windham's I have seen were full hydraulic.
  12. RaginPin3Appl3
    RaginPin3Appl3
    At least they knew not to s**** it
  13. steinauge
    steinauge
    from 1960
    Going to antique engine and tractor meets in rural florida I have seen quite a few old tractors sitting in fence rows with flathead fords and occasionally mopar flat sixes in them.It was always a case of whatever anyone had laying around that could be made to work.
  14. stimpy
    stimpy
    yep taylor lift makes some of the biggest lift trucks in the world , we used them to move 45K coils of steel in the shipyard .and had a few that could lift 100K containers or equipment flats
    my grandfather who was a farmer and grew up during the depression , remotored farm equipment with car engines if needed , if the car or truck wouldn't p*** the safety check and cost too much to make roadable he would part it and use the parts in other things . nice thing aboug some of the older motors was the removable bellhousings so he would redrill them , but he had a couple of hay rakes and movers that were pick up trucks with the beds and cabs removed and you drove them backwards ,
  15. BamaMav
    BamaMav
    from Berry, AL
    Went to a local car show yesterday, and ran into this, a flathead powered Ford tractor:
    And it had this hooked to it, an A banger converted to an Air Compressor:
  16. metalman
    metalman
    30 years ago a friend had a compressor/ sandblaster he picked up that was used in mining. The compressor looked like a small Caterpillar, Kinda like the tractor above but smaller, towed the sandblaster behind it. Had a flathead V8 in it, the front four cylinders ran the motor, the back 4 pumped the air. Had 2 air motors that would drive the tracks. Other then some odd manifolds it sure looked like a standard Ford V8 to me. I seem to recall it even had a V8 distributor, just missing 4 plug wires.
    drylakespeedshop and Hudson31 like this.
  17. khead47
    khead47
    I have heard of Hemis 30 ft in the air in orchards for wind machines. Is this true ?
    henryj1951 likes this.
  18. rusty1
    rusty1
    ...here's a couple more 8n's...one with a turbine..
    Okie Pete, catdad49 and 47ragtop like this.
  19. Last edited: May 1, 2017
  20. tubman
    tubman
    I seem to remember that someone posted some pictures of hemi-powered wind machines or maybe air raid sirens on here. I do remember that they were mounted on towers. A search should find some examples. (I'm too lazy.)
    C. John Stutzer likes this.
  21. UNSHINED 2
    UNSHINED 2
    Wish i had taken a photo of it. But there was a rock crusher in a junkyard in my area that had an 8RT flathead in it and it looked like a factory job. It had a grille surround on the radiator that was the same style as the 48-50 F1, but it was a purpose made radiator surround, not a modified truck frontend.
    I wanted to get the engine and grille surround out of it, but i made the mistake of ***uming it would be there forever since its been there this long.....now gone....
  22. George
    George
    Yup, industrial ones. The Garlits museum has one. photo in the Hemi threads
  23. railcarmover
    railcarmover
    That crawler aint no ford,its a Cletrac HG42..they came with Hercules bangers from the factory...a common hack on those was to stick a model a trans between the clutch and final drive to gear them down
  24. railcarmover
    railcarmover
  25. railcarmover
    railcarmover
    Cletrac was bought by Oliver..Cletracs HG42 design was marketed by Oliver as the OC-3...the track frames,final drives and steering levers are Cletrac,basically everything but the engine and hood is Cletrac..they had an SAE bell housing,lashing up a V8 wouldnt be hard,you'd have to modify the front frame some,and extend it to mount the radiator...I restored an HG42 and owned an OC-3..I know abit about them..
  26. cb186
    cb186
    That right there is on my list of completely unnecessary things to own/build some day.
    greasemonkey54 likes this.
  27. catdad49
    catdad49
    Ah the Gerlinger aka Yellowbird, by the time I started working at the local foundry, the flatty had been replaced by a Y-block running thru a gl***pack. Spent some time behind the wheel (not fast but reliable). Did you notice the exposed chains driving the front wheels? Yikes! Nice score.
