Technical Is anyone still using 4 speed transmissions?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 13, 2017.
  1. DDDenny
    Planning on using this Hurst shifter for the Nova.
  2. Zippi
    Zippi
    Still r DSC01550.JPG DSC01551.JPG unning the Saginaw 4-speed that came in my 37 Ford pickup.
  3. burl
    burl
    from Minnesota
    4 speed.jpg Volvo 4 speed going behind my ford banger in a 28 mopar
    UNSHINED 2 and HOTRODPRIMER like this.
  4. LAROKE
    LAROKE
    Same Muncie in both pics. Linkage was mocked up on the bench but I haven't cut the floor to make it fit yet so It's missing from the second pic. I haven't even pulled the side plate for inspection.
    HOTRODPRIMER likes this.
  5. DDDenny
    I've been a 4 speed guy since swapping out the Fenton shifted 3 speed in my 57 BelAir in high school with a T-10 in 1971. Replaced it with another that had been built for drag racing with a Ford input shaft.
    Many to follow.
    65 El Camino with Muncie M21.
    64 Malibu 2 door wagon, 425 Olds/Muncie (by previous owner).
    65 Malibu drag car, BW Super T-10.
    64 Impala, converted oem 3 speed/tree with Muncie, also later Muncie with earlier side cover to use correct oem shifter.
    67 Nova in prevous post.
    This is the Richmond Super T-10 for my roadster.
  6. dirty old man
    dirty old man
    BGII, my '31 Hiboy roadster runs a Ford Top Loader behind an SBC engine and they are mated with a McLeod safety bell housing. Those who know it will agree that it's an "In your face" hot rod, loud and obnoxious.:eek:
    The '40 coupe runs a 5 speed behind SBF. She's sorta sedate and a cruiser.:cool:
    Personalized tag on BGII reads "3 PEDLS" tag on '40 says "3PEDLS2":D
  7. Corn Fed
    Corn Fed
    Yep. Toploader behind the 312 Y-block in my '28 PU. Muncie behind the 327 SBC in my 32 Coupe.
  8. uncleandy 65
    uncleandy 65
    All we had were 4 speeds back in the 60's and really that's all I need today in my 62 Impala 409 and a m-21 with Hurst shifter.
      179.8 KB
  9. gearheadruss
    gearheadruss
    from Seattle
  10. vtx1800
    vtx1800
  11. Jimmy2car
    Jimmy2car
    from No. Cal
    I use a Jeep 4 speed case & shifter (T-176) in my 32 Tudor sedan. I removed the goofy Jeep gears & replaced with Ford Toploader gears. Then I have a Gear Vendors OD behind that. Best of both worlds.
    Racerex and HOTRODPRIMER like this.
  12. metalman
    metalman
    4 speeds have always been the ****** of choice for my own cars. I still like running thru the gears with a good Hurst shifter. A Hurst stick bolted to a 5 speed isn't the same.
    Just got my latest project running last week, it's ot by a year (66 Nova) with a Sag in it, made me smile to slide the shifter into first for it's maiden run.
    HOTRODPRIMER and lothiandon1940 like this.
  13. OL 55
    OL 55
  14. 327Eric
    327Eric
    50 dollar saginaw in the Elcamino for 14 years, 80 dollar pick n pull saginaw in the Stude for 9 years, and a 50 dollar spare. Not cost effective to change, and more fun to bang shifts in.
  15. Deuce Daddy Don
    Deuce Daddy Don
    You bet!!!----B/W T-10 for 300,000 miles to date, with hyd. slave cyl.---------Don
  16. Russ B
    Russ B
    My banger powered '29 cabriolet has a top loader F150 four speed but it is really a three w/OD, and is perfect for running that car on the interstate.
    The last side shift four speed for me was my '57 bel air Tudor, 327 with a T10 and Hurst linkage, that was 1965-71. For that I kept two rear ends (4.11 and 3.26(?)) to swap out for going home from college or the other for driving locally or at the strip.
  17. My favorite 4 speed I ever drove was a Borgward with 4 on the column.
    OK, that was a lie but it hopefully will keep the thread going a bit longer. ;)
  18. Muttley
    Muttley
    This has a T-10 with a Hurst Comp/Plus....................
  19. Zippi
    Zippi
  20. hotrodtodd1960
    hotrodtodd1960
    M-21 in my willys pick up love rowing the boat !!
    HOTRODPRIMER and Max Gearhead like this.
  21. 270283
    270283
    Clever handle!
  22. Splitbudaba
    Splitbudaba
    IMG_2471.JPG 1980 Super T10 - 3.42 first, with a quick change rear, can cruise or race. Not the strongest but car will be light and about 350 horse.
  23. Ford Freak
    Ford Freak
  24. nutrocker
    nutrocker
    I too run a Volvo M40 gear box but behind a 304ci flatty. Unfortunately it couldn't handle the torque and ripped second gear out. So I've kept the housing and replaced the inards with straight cut close ratio gear sets. Works fine now.
    Pete
  25. Flat Six Fix
    Flat Six Fix
    Don't ya mean a 48 Chrysler 4 spd on the column M5 4 spd semi auto with a new fangled fluid drive.
    0 to 60 in 1 hour......LOL
  26. car doctor
    car doctor
    Running a muncie in my g***er with an old hurst ram rod shifter! Still get a thrill banging the gears! 14894512888012045431384.jpg
  27. cavman
    cavman
    Yup. Taken early in the mock-up stage, but going to use it when done in the '53 untitled (3).png . Super T-10.
  28. Max Gearhead
    Max Gearhead
    from Wisconsin
  29. thunderplex
    thunderplex
    All of these have 4-speeds..
    '30 Model A: Muncie
    1961 Safari: Muncie
    1956 Mainline: Borg-Warner
    loudbang, UNSHINED 2 and HOTRODPRIMER like this.
  30. bowie
    bowie
