Hot Rods Or Original Cars Milwaukee Ford Plant
Discussion in 'The Hokey Ass Message Board' started by reggiedog, Apr 16, 2017.
  1. reggiedog
    reggiedog
    from wisconsin
    HI:
    I'm Looking for people that have a Mid to Late 1930's Car. And here's what I'm looking for I'm doing research on the Milwaukee Ford plant. And I think I found what the Letter Code was for that Plant.
    But I need your Help to prove it as it was actually the Letter "R".
    So what I need you guy's to do is to look at your Ford Body Plate and see if it starts with a "R" Letter and if it does get a hold of me. As you might have a Car that was made in the Milwaukee Ford Plant.
    But your Car has to have the do***entation in other words you need the history of the Car. And there's several ways that you can do that you can do that if you need to know and how to do that.
    Get a hold of me and I will tell you what you will need to have to get it do***ented so you can get it added to the List I have. Reason being I need to have at least 25+ Cars with the "R" Stamped in there car or on the Body Plate.
    So I can prove that the Letter "R" is actully the Letter Code for the Milwaukee Ford Plant as No one knows what it is. Or ever has known what it was and now maybe I have found it once and for all.
    And it would be nice to get the Letter code for the Milwaukee Plant for everyone to know what it is.
    Let me know Reggiedog
  2. rusty rocket
    rusty rocket
    And why are you doing this?
  3. Bird man
    Bird man
    from Milwaukee
    Can you tell us where the plant was or for how many years it was in operation? Just a body plant?
  4. Phillips
    Phillips
    I can't help with your question, but the building is still there, it's been well taken care of over the years, 2185 N. Prospect.
    banjeaux bob likes this.
  5. reggiedog
    reggiedog
    from wisconsin
    I'm Researching the Milwaukee Ford Plant have been for the past 2 years and still going on
  6. reggiedog
    reggiedog
    from wisconsin
    I know as the colllage owns it now as it's apartments now
  7. banjeaux bob
    banjeaux bob
    from alaska
    My grandfather worked as a machinist in the building when it belonged to GM. He called it AC Sparkplug as it had a big AC Sparkplug painted on the south side of the building overlooking the railroad tracks.They were doing government contract work there.
  8. John Stimac
    John Stimac
    Production finalized at the Milwaukee plant in 1932
    bobwop likes this.
  9. Bird man
    Bird man
    from Milwaukee
    Good info, I knew it as an AC building, not knowing about AO Smith & Ford. Best wishes on your search.
  10. John Stimac
    John Stimac
    I should have said,"Ford production ceased in 1932"
  11. reggiedog
    reggiedog
    from wisconsin
    Yes, John That was for the Model A's Only as that Plant was open until 1942 as that's the year that it changed hands and they made cars and Trucks in there as I have been told tell 1939 or 1940. But I think that went longer then that but that's what I'm trying to find out now.
  12. alchemy
    alchemy
    The only Ford marking which might indicate which plant a car was ***embled at in the late 20's to 1932 was a letter on the front sub rail, right in front of the seat. My 32 sedan has DM 180 on it's sub rail crossmember, meaning it was the 180th tudor sedan built in Des Moines that year.
    There is no "plate" with any of these type of production numbers except for Murray built bodies like 3 windows. And those bodies came from another location.
    I've got a 40 sedan, and it also doesn't have any plate indicating where it was built. But it's floor was rusty so I can't tell you if it had an ***embly plant initial stamped into the bare floor.
  13. reggiedog
    reggiedog
    from wisconsin
    yes, GM Still owns the A.C. Delco Spark Plugs yet today but now there NOT made in Wisconsin anymore
  14. reggiedog
    reggiedog
    from wisconsin
    Sorry I can't give that information out at this time
  15. reggiedog
    reggiedog
    from wisconsin
    Thanks sounds like I will need it
  16. HOTRODPRIMER
    HOTRODPRIMER
    According to my reference book the "R" code refers to Richmond, California – Opened in August 1931 and replaced San Francisco.
    Milwaukee,Wisconsin was a ***embly plant and not designated as a manufacturer,therefore no letter designation.
    If any letter designation were used it most likely would be that of the ***embly plant and in this case it would almost have to be WI. HRP
  17. Corn Fed
    Corn Fed
  18. You are asking for information and then you are saying that the information is incorrect because you say that it is incorrect.
    You are confusing ***embly plant with manufacturing plant. To be considered a manufacturing plant the pieces had to be made on site not just ***embled on site.
    H380 likes this.
  19. reggiedog
    reggiedog
    from wisconsin
    No it didn't stop in that year I have do***entation of that
  20. I'll be holding my breath.:rolleyes:
    lurker mick likes this.
  21. Well you would know you are a legend in your own mind.
    VANDENPLAS and H380 like this.
  22. reggiedog
    reggiedog
    from wisconsin
    Do what ever you want as you will have about 2 to 3 year wait as I've been doing this for 2 years already
  23. reggiedog
    reggiedog
    from wisconsin
    To me you could be a researcher yourself and trying to get me to tell you some free info not going to happen
  24. reggiedog
    reggiedog
    from wisconsin
    most of the stuff I said on here could be true or not true at all most of it NOT as I don't give out free info
  25. I am absolutely sure that I don't need you to research anything for me. I went plum through the 6th grade.
    VANDENPLAS likes this.
  26. reggiedog
    reggiedog
    from wisconsin
    I'm DONE WITH YOU I WILL NOT REPLY TO YOU ANYMORE AND I WILL REPORT YOU IF THIS KEEPS GOING ON
  27. H380
    H380
    from Louisiana
    SOOO. You are asking for people to provide you with FREE info so you can sell it?
  28. HOTRODPRIMER
    HOTRODPRIMER
    I got my information from the henry ford archives,but you know everything so I will politely add your name to my ignore list so there is no reason to waste your time asking me for help,it will fall on deaf ears!
    Evidently know everything so I question exactly why the HELL are you asking The Ford Barn and The HAMB for their help and then when do you tell them they are wrong!
    Will your reporting Beeno go ahead and report me too.:mad: HRP
    VANDENPLAS, HEMI32 and redo32 like this.
  29. reggiedog
    reggiedog
    from wisconsin
    Danny, No I'm not that's not it I need the help in trying to find teh letter "R" in the Cars and NO I'm NOT looking for frre info so I can sell it. That's NOT my intention at all.
  30. reggiedog
    reggiedog
    from wisconsin
    That's NOT the case at all
