Projects new member. watch me section my Desoto.
Discussion in 'The Hokey Ass Message Board' started by rytang, Jun 29, 2016.
  1. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I think cragars will look just fine on it. Im always a fan of a 5 point star rim
  2. rytang
    rytang
    from Arizona
    Cragar SS and the Astro Supreme first came out in 1964. Seems perfect for a early 60s styled car to me.
  3. Slopok
    Slopok
    You obviously see things differently than the rest of us with a vision only you must have as to how you want your car to turn out, that doesn't mean it's wrong, just different! If you would have told us your plan to do what you were about to do to a 4 door 54 Desoto I believe that there would've been many sceptics that would think that's nuts, :eek: but look at the outcome so far.:cool:
    I enjoy watching what you do, I mean hell you even customized your English wheel!;) Go man go!
    RockinRivi, Russ B, BradinNC and 6 others like this.
  4. Slopok sums it up absolutely correct and, man, you have shown us your skill and the right at***ude of " I will do this and it will look damn good " so, yeah, I love those S/S Cragars too and with the right tyres, will be awesome.
  5. Slopok
    Slopok
    Don't listen to anyones opinion about wheel choices. o_O
    Heck can you believe that there are some people here that don't even like RED RIMS?:rolleyes:;):):D
  6. tb33anda3rd
    tb33anda3rd
    haha. what do i know? i would put hubcaps on it.;):cool:
    TFoch, Stogy, rytang and 2 others like this.
  7. Slopok
    Slopok
    This kid aint like the rest of us but he sure fits in! Gota admire his vision.:cool:
  8. Early Ironman
    Early Ironman
    Aren't we all a little odd on here?
    I know I am!
  9. rytang
    rytang
    from Arizona
    Thank you!
    Russ B, 62hotcat and Ray C's son like this.
  10. COCONUTS
    COCONUTS
    I am waiting for a side view picture with you sitting in the driver's seat with your head over the top of the windshield. Better lower those seats. Excellent job so far.
  11. rockin562
    rockin562
    Man you are doing a killer job! Love the craftsmanship. Waiting for some update!
    rytang likes this.
  12. raidmagic
    raidmagic
    Still in love with it, keep going!
  13. Tim
    Tim
    from KCMO
    Good example of the difference between hot rod guys and custom guys.
    The hot rod guys see cragars and think white letter tires, muscle cars and mullets
    The customs guys see cragars and think thin whites, low riders and bellflower customs
    mikeyyeah, RockinRivi, drdave and 8 others like this.
  14. Sancho
    Sancho
    Sums it up perfectly.
    RockinRivi and rytang like this.
  15. Spex84
    Spex84
    from Canada
    I always check in on this thread because it's glorious to watch this car evolve. The Cragars look traditional enough (squint a little and they could be Astros) and the lowrider vibe contributes to the overall punk at***ude of the car. Cool stuff.
    brEad and rytang like this.
  16. rytang
    rytang
    from Arizona
    Update* I'm still working on getting these wheels on correctly. I'm not happy with the studs my friend made, they weren't straight enough for me to trust. Now I'm trying to use press in studs like a few of you mentioned. I took the front 2 to a local shop to work on. But now another problem....... I can not get the 2 rear hubs off! Ugggghhh! This damn car! 20170426_184138.jpg
  17. greybeard360
    greybeard360
    Put tension on the hub with the puller, then smack the puller on the side of the round part.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    tb33anda3rd likes this.
  18. rytang
    rytang
    from Arizona
    I have been all day. Won't budge. Breaks castle nuts pretty easy tho.
  19. greybeard360
    greybeard360
    Try the old trick of heating the hub and putting some wax on the threads. I have had some of those not want to budge. I made a hub puller I can strike violently if needed [emoji16]
  20. You are aware, of course, that the judges will knock off points because you don't have the correct acceptable wheels. I caught some **** because I liked the "out of vogue" centerlines on my '34. Remember what Ricky Nelson said......
  21. greybeard360
    greybeard360
    Ummmm. Cragars have been around since 64 making them HAMB friendly. [emoji16]
  22. I was being sarcastic.
  23. greybeard360
    greybeard360
  24. DIYGUY
    DIYGUY
    from West, TX
    First always apply liberal amount of penetrant.
    Last step is to use a cutting torch.
    Many steps in between to be determined by level of frustration and availability of spare parts.:mad:
    RockinRivi and Slow down like this.
  25. 1964countrysedan
    1964countrysedan
    from Texas
    Pros won't like this, but I would be "tappin" on diameter of the drum at 11 and 2 o'clock with the puller tight, around the outboard edge. I use a 2 pound hammer and hit it hard enough to make some noise.
    If you are worried about marks, hold a 12" piece of 2x4 against it.
    Not responsible for broken parts or fingers.
  26. gimpyshotrods
    gimpyshotrods
    Grind the head off of a rivet. Knock the remainder in. Tap the hole for a ****on head allen screw. Put one in. Repeat until all of the rivets have been replaced with ****on head allen screws.
    Then you have a removable drum.
  27. rytang
    rytang
    from Arizona
    Which rivets are you talking about?
    Caprice89 likes this.
  28. gimpyshotrods
    gimpyshotrods
    The ones that hold the drum on the hub.
    rytang likes this.
  29. gimpyshotrods
    gimpyshotrods
    I did this on the last Plymouth that I worked on, and then put in grade-8 bolts, from behind. A drop of red Loc***e kept them in there.
    That was 7-years-ago. Still going strong.
    rytang, BradinNC and Early Ironman like this.
  30. DIYGUY
    DIYGUY
    from West, TX
    Isn't the hub/drum splined to the axle? Is the axle nut loose on the axle? I see the nut still there but backwards? Looks like you would hammer on the hub while under pressure. Seems like I worked on a 8n tractor with this set up. Only thing holding together was the axle nut.
    rytang likes this.
