Hot Rods Softening the ride on a straight axle
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 18, 2017.
  1. Roothawg
    Roothawg
    So, after driving the 35 for 750 miles this past weekend, I noticed a few things.
    One of them was how harsh the ride was on my 35 front suspension.
    Here's the setup.
    Ch***is Engineering 4" dropped axle
    Ch***is Engineering matched shocks
    Split bones the width of the x member
    Posies reversed eye spring
    CE Sway bar
    15" steel front wheels
    It drives out ok as long as the road is smooth, but if there is a break in the concrete or a bump at a bridge or transition, it makes you cringe.
    I thought about replacing the front shocks with Bilsteins to see if that would soften it up a bit.
    Any ideas?
  2. What's your tire pressure? Mine has to be down to 20 psi to ride decent.
    46international likes this.
  3. earlymopar
    earlymopar
    I would also look at tire pressure (easiest and fastest to check), then would look at where you are with suspension travel as relates to your bump stops. - EM
  4. Roothawg
    Roothawg
    I could lower my tire pressure a bit. It's not a bias ply tire. It's a radial.
  5. How about a picture of the spring
  6. Roothawg
    Roothawg
    Of? Me without my pants on? You're not tricking me a third time......
  7. Tim
    Tim
    from KCMO
    Yeah tire pressure will make a difference with that sort of thing, it's finding that balance between easy to steer and rides like **** lol
  8. Roothawg
    Roothawg
  9. Roothawg
    Roothawg
    Good call. The spring appears to have lost all of its arch in 750 miles. Nice. I won't buy another Posies spring.
    28TUDOR likes this.
  10. Jalopy Joker
    Jalopy Joker
    maybe check with Jenny Craig for help with possible cause - Ha!
  11. Roothawg
    Roothawg
    The frustrating part is all of the problems I have had on this build have been manufacturers failures.
  12. olscrounger
    olscrounger
    sent you a pm-lots of leaves! Had a spring like that sag 1 1/2" before the car ever turned a tire. Made mine of a new main leaf and then Ford springs for the rest-8-9 leaves
  13. It's hard to see, but the shackles are ****ed ***backwards wrong in these pics. However ,,, Also the spring should be pulling the shackles at 180* in this set up and there should be no way possible to get them that way unless the spring is too long.
    It appears that it is indeed too long
  14. This is set up right, rides great.
    You can see the shackles are showing a balanced spring rate to load. You also can see the amount of arch and it's not much.
    This spring needs quite a bit of preload flattening to get it mounted.
    olscrounger likes this.
  15. olscrounger
    olscrounger
    X2--if the shackles aren't at a 45 with the car loaded it won't function but sure looks like a lot of leaves.
  16. Roothawg
    Roothawg
    I'll get it up in the lift this weekend. It's hard to see in the dark garage
  17. Roothawg
    Roothawg
    At one point we had them flipped. We unloaded them later. Not sure when those pics were taken. Pre or post.
  18. Need the spring loaded, A 4 post lift would be ok. A 2 post or stands would not get us a good representation.
  19. I know at least one spring manufacture out there has some bad info and measurements and has WAY to much arch in their springs.
  20. That flip is the tell tail sign the spring is too long. The shackles should be pulled horizontal, and when pulled horizontal there is ZERO chance they could ever flip.
  21. Roothawg
    Roothawg
  22. Weedburner 40
    Weedburner 40
    The shackle looks fine. Check the shock length and also, make sure the swaybar isn't hitting the shock mount. You could try removing the shocks and driving it, that would at least eliminate the shocks being the culprit.
    46international and olscrounger like this.
  23. olscrounger
    olscrounger
    X2 above--good info but still alot of leaves to me
  24. Pete Eastwood
    Pete Eastwood
    from california
    I've used original Ford springs on most of the builds I've done over the last 40 years.
    I'm always amazed that people choose to ditch original Ford Parts, that Henry paid smart engineers to develop, and switch them out for some new stuff that some hot rod guy came up with, just because it's new ( but not always better ! )
  25. Roothawg
    Roothawg
    I used a later axle on mine. It was a 35, I added a set of 40 bones and had no factory leaf for a narrowed 46" axle.
    Hutkikz likes this.
  26. Looks damn near vertical to me
    Nailhead Jason and X38 like this.
  27. rusty rocket
    rusty rocket
    When you split the bones did you get the spring hanger bent straight enough? That could cause some binding. Just a thought.
  28. Roothawg
    Roothawg
    Yeah, its good. I think I may build a hybrid spring out of the Posies and the CE.
  29. I used the CE spring with there axel, and it rides good.
