Hot Rods Correcting camber on mopar double dip axle after ford spindle conversion
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Dec 30, 2015.
  1. rottenleonard
    rottenleonard
    20151229_135157.jpg 20151229_135150.jpg I have reamed out the kingpin boss on my axle and made some measurement right now I have 5 degrees of posative camber I would like to end up with 1/2-3/4 negative. I have read in other threads where they just took it to their old school alignment shop and had it bent, tried that they said they wouldn't attempt it as thet belive the tube will kink before getting that much movement. Thinking about attempting it myself but thought I would come here first to see what experience the HAMB may offer.
  2. Texas Webb
    Texas Webb
    I'd check with Okie Joe or Sid in Oklahoma or Greg Haynes,California.
    Hnstray likes this.
  3. seb fontana
    seb fontana
    from ct
    You want 0° to 1° positive..No?
  4. rottenleonard
    rottenleonard
    Well...my personal thought is that the tire is almost completely outside of the scrub radius. Going to the negative side on camber should move the effective tire patch inward some to help with the scrub radius issue. I know that the norm is a positive camber spec but I'm not entirely sure the reasoning behind it.
  5. gimpyshotrods
    gimpyshotrods
    Negative.
  6. seb fontana
    seb fontana
    from ct
    Positive is top of tire out..Going negative would move bottom of tire farther away from the center line of scrub, OP said he wants to get closer by moving bottom of tire in..Ford Camber is 0° to 1° positive..
  7. gimpyshotrods
    gimpyshotrods
    If you want 1920's handling....
  8. 38Chevy454
    38Chevy454
    Bending the axle is what is needed to correct the camber, but that will do nothing for the scrub radius. Without modifying the spindle, scrub radius will not change with the camber. That is built into the spindle and wheel offset, not the axle.
  9. Torana68
    Torana68
    from Australia
    what happens if you flip them up the other way? too much negative?
  10. gimpyshotrods
    gimpyshotrods
    Way too much.
  11. Torana68
    Torana68
    from Australia
    time to bend then ....
  12. seb fontana
    seb fontana
    from ct
    You are 100% correct..
  13. Rusty O'Toole
    Rusty O'Toole
    Let's see if I understand... you went to all the trouble of putting Ford spindles on a Chrysler axle THEN began thinking about how to correct the camber???
    May I suggest you put the original spindles back on?
  14. Were you able to correct your camber ?
    and if so , how did you do it ?
    I'm about to attempt this swap .
    Thanks
  15. Turn the spindle over. That should put you close then heat and bend the axle to suit you.
    The reason the old school alignment shop wouldn't attempt it is because the bend the axles cold, you don't bend a tube axle cold, unless you got a tubing bender.
