Technical valve retainers, springs, keepers, shims, lash caps, guides,seals-n-guide plates and studs-n-valves
Discussion in 'Traditional Hot Rods' started by henryj1951, Apr 16, 2017.
  1. henryj1951
    henryj1951
    from USA
  2. Fordors
    Fordors
    I wanted screw in studs BITD but didn't want to spend much money (cheapskate) so I did it like this. Take a piece of 1" square bar stock, measure the center to center of two SBC rocker studs and drill the bar stock with one 3/8 hole to pilot on a stud and the other hole 7/16 to guide the tap.
    Place the block on the head and pull a stud using washers, or even old rocker balls to jack it out of the casting. Now turn the block to the 7/16 side and your tap is perfectly aligned to thread the hole. I used to buy Dorman Products studs, the bin number was V-6 and there was another catalog p/n but I don't recall it. The stud had a raised area to lock it down against when it was tightened in the head, no other machining necessary and at .50 cents a piece a lot cheaper than Mr. Gasket studs.
    Place block on new stud, pull next one and repeat until finished. The most important thing is drilling the holes in the block on the proper C-C distance, but this whole thing is probably not important anymore, I don't think Dorman catalogs those studs now. If you do find some old stock somewhere only the black oxide V-6 stud is Grade 8, don't use plain ones.
    henryj1951 likes this.
  3. henryj1951
    henryj1951
    from USA
    Yep ...after the, pin the stud was no longer an option ( still pulled em out ) , if on the engine drilled em at an angle ,if off the engine more at a straight (see pic).
    I / we used that very same method.
    butchcoat1969 likes this.
  4. henryj1951
    henryj1951
    from USA
    Stud pulling tools ----one picture shows that you can still buy them 14bucks.
    The other picture is from the don't use obsolete tool drawer.
    j-jock likes this.
  5. henryj1951
    henryj1951
    from USA
    The reason we do not want or use them, Aluminum retainers, any more, I removed these from a customer's heads and the replacement will be steel..
  6. Torana68
    Torana68
    from Australia
    ok so on the other thread I was asking about the dry film "ceramic coating" for springs , anyone use them and do they work?
  7. henryj1951
    henryj1951
    from USA
    How bout the *liquid nitriding process*....?
  8. Torana68
    Torana68
    from Australia
    That one for springs dunno wont help with heat removal nor the freezing thing they do to stuff
  9. henryj1951
    henryj1951
    from USA
    on valves...anybody use em yet
  10. Schwanke Engines
    Schwanke Engines
    Anything else is just a waste of time. these appear to be 7/16 bottom 3/8 top. I typically prefer to run 7/16-7/16. But these are better than pinning or the cheapo threaded studs that have no real way to tighten them.
    Montana1 and henryj1951 like this.
  11. Larry T
    Larry T
    Crane used to sell the tools to upgrade heads for the home builders. There was a fixture for screw in studs (similar to what's described above). One for cutting down the head for guide plates. Another for shortening valve guides and cutting them for PC seals. And another for cutting spring seats for larger valve springs.
    I used them on quite a few heads and never had any trouble out of the results on any of the heads I worked. The tools are still around here somewhere, but I haven't seen them in a while.
    And while we're talking about valve train stuff, don't forget rev kits and stud girdles.
  12. henryj1951
    henryj1951
    from USA
    Larry , like these ....? not much call for their use , when you can buy heads ready to go.
    Larry T likes this.
  13. Mike VV
    Mike VV
    from SoCal
    Been asked -
    on valves...anybody use em yet ?
    The best people to find answers like this are the ones that see the most action...
    That is the guys that make the valves..! Manley, Comp Cams, etc.
    Call them for a realistic answer.
    Mike
  14. henryj1951
    henryj1951
    from USA
    ^ Sure ask the salesman of Florida Swampland, think he'll steer ya WRONG.
    Sure i agree ask, the makers, but because we can , this is no more than a place to hold CONVERSATIONS ,on subjects that elude MOST people. Do you have ANY (1)st hand knowledge on that process...?
    Please share your use and experience.
    LQQKing forward to your input.
    EDIT: spelling what a maroon(i am)
  15. henryj1951
    henryj1951
    from USA
    Well anything in the 180/200 treated range, but those 3/8's still break off.
    New
    Some of you fellas need to use the report ****on... rather than acting like little girls.
    Ol' Wascal likes this.
  16. Larry T
    Larry T
    These help with that.
    Opinions - 2 piece girdle or 1 piece/u bolt girdle?
  17. henryj1951
    henryj1951
    from USA
    Yes they do.... but have you ever noticed , on most broken studs , it is the top part...
    EDIT: And its usually the 3/8th's ones, i haven't seen ANY 7/16th's broken ones YET...
    here are some Ro-7 nascar heads
  18. butchcoat1969
    butchcoat1969
    Pins are ok but I've seen them pulled right out so screw studs are really the way to go imo
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  19. henryj1951
    henryj1951
    from USA
    Exactly.... and that why, myself and other builders haven't used that OLD method since , around 1969. For certain we installed the LT-1 , GM studs from chevy, and as better strength rocker studs came available we up graded to those.
    EDIT: well they were ok , at the time, (the pinning of studs)when we had NO other way.
  20. henryj1951
    henryj1951
    from USA
    Well for me the, (1)pc u bolt bar (was not the first type i ever used) did not hold PERFECTLY , sometimes and only sometimes the adjustment needed to be re-adjusted...
    then came along the (2) bar.
    Larry ya didn't say what one YOU like...
  21. henryj1951
    henryj1951
    from USA
    Screw in studs---->
  22. henryj1951
    henryj1951
    from USA
    How about the bars that have them springs in them, i like em. ----See Pic's
  23. Larry T
    Larry T
    I have both sitting here for my Anglia engine, but I think I'll probably run the u bolt girdle (if it will work on the AFR heads). I really haven't seen much difference in lash changing after the valves are adjusted, and the u bolt girdle seems a little easier to adjust for me.
    But, I'm always looking for others opinions on stuff.
    Never used the spring loaded girdles. Looks like it might make things a little easier to adjust.
  24. Larry T
    Larry T
    As long as we're talking tools, how about pushrod length checkers. I've had pretty good luck with this one from Manley.
    Stock pushrod was .200+ short for this set up. (Dart heads/.100 overstock valves/Bullet cam).
    Also in the picture, 7/16 rocker arm studs. Cam is .540 lift, solid lifter cam, and he didn't want a girdle. Since it's a street engine and doesn't have a really radical cam with roller cam valve springs, I figured we'd use the bigger studs, matching 1.5 roller rockers and call it good.
    And while standard guide plates worked on most of the cylinders, I had to use adjustable plates on a couple of them for geometry and clearance problems.
  25. henryj1951
    henryj1951
    from USA
    Yes two stud sizes ... and lets not forget those, COMP Cams Hi-Tech pushrod length checking tools see pic--->
  26. henryj1951
    henryj1951
    from USA
    What is everybody using these days to CHECK valve spring pressures?
    The HAMB loves its pictures---post em if ya got em.
  27. henryj1951
    henryj1951
    from USA
    Ok ... we all done here or is there any more fun left to chat about...?
  28. Torana68
    Torana68
    from Australia
    probably not a huge amount of guys "building" engines, seems to be a lot of crate or nearly stock rebuilds, Id have thought race engine building at home was as traditional as you could get?
  29. Baumi
    Baumi
    I have been looking for a valve spring pressure tester for quite a while, but it seems like there are none availible around here, at least not used ones. It would also make it easier to decide, if used springs are still usable or already too weak...My friend Damir scored a valve spring tester on ebay USA but they seem to be scarce in Europe. It wasn´t cheap either. I willsee if I can borrow his when I build my next souped up engine. The last few times I went with what the cam mfg´s recommended for my application. May not be perfect, but certainly better than what I would end up with picking springs cluelessly without exact measurements...
  30. kma4444
    kma4444
    Ahhhh, problem solved ;) [​IMG]
    270ci, Baumi, Larry T and 1 other person like this.
