Hot Rods What do you use for a radiator overflow bottle?
Discussion in 'The Hokey Ass Message Board' started by 29StudeDude, Apr 9, 2017.
  1. PurdueSD
    PurdueSD
  2. mechmitch
    mechmitch
    DSC_8924.JPG Whiskey bottle. There's always plenty of them laying around by the end of a build.
    neilswheels likes this.
  3. johnc451
    johnc451
    RediWhip can after a few minutes with a wire wheel and a shot of clear lacquer. Eat the whip cream first!
    chop job and Crusty Chevy like this.
  4. bskustoms
    bskustoms
    from Aloha, Or.
    I use an old pump style fire extinguisher. Tapped out the squirt nozzle and run a small hose from radiator to extinguisher. Mounted on firewall, not many people realize what I'm using it for.
  5. 29StudeDude
    29StudeDude
    Like this one? I will be using this for my bottle.
    akoutlaw and nunattax like this.
  6. I have a St. Patrick's Day aluminum Bud Light 16 oz. bottle. It's about 5 years old.
    Car and hotrod folks walk past it and pay it no heed. On the other hand, folks that don't know cars spin around, comment, and take pictures of the bottle. Funny to watch all and listen.
    nunattax and 29StudeDude like this.
  7. fleetside66
    fleetside66
    This is a late 1940's "smoothie"maker...spun aluminum.
  8. slddnmatt
    slddnmatt
    Pyrene fire
    xtinguisher
  9. 32 hudson
    32 hudson
    I have a similar fire extinguisher for mine.
  10. GEZSFRK
    GEZSFRK
  11. A 2 B
    A 2 B
    from SW Ontario
    I have considered using this old 40mm artillery shell that was re-purposed as a lamp once already.
    neilswheels and mechmitch like this.
  13. Racer29
    Racer29
    I had posted earlier that I use a CO2 canister from a paintball gun. Finally got a picture. 1495602334011.jpg 1495602345010.jpg
    29StudeDude likes this.
  14. bobss396
    bobss396
    But only if you drive a "rag" top....
  15. gtokid70
    gtokid70
    What about a 60s windshield washer fluid bottle. I think Gm used them. They come with a mounting bracket. 20221103_104639.jpg
  16. 1971BB427
    1971BB427
    from Oregon
    I was tossing some garbage away at work a decade ago when I spotted a small fire extinguisher in the trash. One of those that looks like maybe 20 oz. size, and is aluminum. I grabbed it just because I thought it might be of use somewhere on my car?
    Got it home and after pulling the lever to ensure it had no pressure, I wrapped it in an old innertube and clamped it in my pipe vise to unscrew the top. Once I got the top off I set the bottle aside, and gutted the mechanism to release the agent, and it left a 1/2" hole in the threaded fitting.
    I polished up the outside after removing the label, and then bought a "mineralac" strap for EMT electrical tubing. Mounted it on my radiator support and ran the overflow hoes into it as a catch can. Works great, and looks factory made custom!
    down-the-road likes this.
  17. I use a WWII canteen on my '40.
    I built a Moonshine still looking one for the Jalopy I'm working on. 16884153074036388785956202646635.jpg
    chevy57dude and lothiandon1940 like this.
  18. cs39ford
    cs39ford
    On my 39 a bought SS overflow tank. On the 56 was an aluminum water bottle. IMG_0353.jpeg IMG_2811.jpeg
  19. 57 Fargo
    57 Fargo
    I have one of these in a 61 Chevy parts car I was looking at the other day walking past thinking of this very thing.
    Joe Blow likes this.
  20. Joe Blow
    Joe Blow
    I use the aforementioned windshield washer bottle.;)
  21. AccurateMike
    AccurateMike
  22. nunattax
    nunattax
    1lr can of FAXE danish beer 10%
  23. Jokester
    Jokester
    Home made. Starting at the bottom...aluminum angle for mounting bracket, 2 hose clamps, s**** piece of 2.5" thick wall aluminum pipe, a piece I cut off of an old barstool, a soft plug (core hole plug to you purists), 2 pieces of 1/4" tubing, and some JB weld.
    Works!.
  24. fleetside66
    fleetside66
    Hmmmmm....
    kadillackid likes this.
  25. DDDenny
    I think this was originally an A/C receiver/drier canister, built it many years ago, don't recall the application.
  26. 6sally6
    6sally6
    Woulda been cooler if you had left the Ready Whip logo on it !(IMO)
    6sally6
    deathrowdave likes this.
  27. mitch 36
    mitch 36
    Old stainless water bottle, some JB weld and brake line, been working fine for 12 years now. 20230703_192428.jpg
  28. natrlgas49
    natrlgas49
  29. BamaMav
    BamaMav
    from Berry, AL
    I ended up using another Gatorade bottle. It’s out of sight, and does the job.
  30. nunattax
    nunattax
    none yet but need one .thinking of using a beamish stout can,plenty of those lying around my place!
