Projects Kustom From Outer Space..France calling.
Discussion in 'Traditional Customs' started by Ratatouille, Sep 3, 2014.
  1. Ratatouille
    Ratatouille
    from France
    Sun is back:).
    I must change pedal angle...cut cut cut......[​IMG]
    Welding, painting......
    It's ok, and it remains approximately a vintage look.....;)
  2. Rickyy
    Rickyy
    from France
  3. OahuEli
    OahuEli
    from Hawaii
  4. Ratatouille
    Ratatouille
    from France
    -Gas pedal and cable (maybe a kit, the old cannot be used)
    -Cutting the old manual gear box steering wheel commande
    -Cutting the old clutch floor command (under the floor)
    -Create a new gearbox tunnel
    -A new carpet
    -Mount the new transmission camshaft
    -Radiator and hoses
    -Exhaust
    -Done all electricity, with electronic dash, new ****ons, changing everything (horn, light bulb...all in 12v, my car is in 6v with no fuses:confused:)
    -Changing tires (real whitewall)
    -New hubcaps
    -Rear bumper
    -New taillights
    -Changing some body modifications
    -New lookin' style with trim and chrome
    -Primer and new paint
    -******** decoration:cool::cool::cool:
    -Various finishes (shifter knob, engine parts like chrome air filter....and more)
    After that, Ratatouille and the girl with the car, travel everywhere in the world drinking beers with new Hamb friends;););):):):):):):):):):)....but first, gas pedalo_O
    Outback, Sancho, timwhit and 10 others like this.
  5. OahuEli
    OahuEli
    from Hawaii
    Sounds like a good plan!:D
    Ratatouille and vetteguy402 like this.
  6. Ratatouille
    Ratatouille
    from France
    **** APPENS!!!!!!!!!!!!!!!!!!!!!
    I'm lost!
    Well, today I recuperated my transmission shaft.
    The job is correct, and the dimensions are ok.
    The part is installed.
    And of course, I'm happy to test the result, and after "my lot of work", **** APPENS:(:(:(:(:(
    I have try to move the car......and.....
    5 REVERSES AND 1 FORWARD!!!!!!
    DAMNED!!!!!!!
    I don't know what I must do. I have check the Pinto sense of rotation, it's the same that the Fregate.
    I'm ****ED:mad::mad::mad::mad::mad::mad::mad:
  7. Ratatouille
    Ratatouille
    from France
    Chrisp, is there a happy end to this story? I need help.:eek:
    I have the first rear end model(1954) counter clockwise, and I think the Hypoide rear end (1957) is clockwise......If someone can confirm me that this 2 models of Fregate rear end have different rotation senses.....?????.....it's maybe my solution......o_O
  8. Bandit Billy
    Bandit Billy
    Talk about 1 step forward and 2 steps back...this is 5 steps back! :eek:
    Good luck on the fix, wish I knew how to ***ist.
    Ratatouille likes this.
  9. Katuna
    Katuna
    from Clovis,Ca.
    Can you flip the rear axle over and move the spring pads? Do t know how well that would work on 60 year old gears that are used to turning one direction at highway speed.
  10. Rocket Man 57
    Rocket Man 57
    Put the drivers seat in backwards and swap the tail lights for the headlights. There may be hope yet! I have a buddy that is familiar with older Renault cars, not quite as old as yours. He suggested on some of the differentials it is possible to remove the center section and flip it around. Possibly done from an engineering standpoint to make it fit more applications. He's seen it done before by accident during a rebuild causing the problem you have now. So maybe that's your fix. Best of luck. Too late to give up on it now.
    Bandit Billy, OahuEli and Ratatouille like this.
  11. rgdavid
    rgdavid
    Oh big big zut,
    Did that with a renault 4 gearbox,
    How is your axle held on,
    Can you put photos up please,
    Ive got a sierra back end if you want it,
    Hope the girl consoled you well,
    Quelle merde !
  12. 1964countrysedan
    1964countrysedan
    from Texas
    I bet 3rd to 4th, looking over your shoulder is tough.
    Hang in there pal.
  13. 1964countrysedan
    1964countrysedan
    from Texas
    Salt in wound...xoxox.
  14. sailingadventure
    sailingadventure
    Hang in there, you`ll figure it out!
  15. 1936dodge
    1936dodge
    Been following from the beginning.Great work.I know you will get the latest problem fixed.
    Sent from my XT1254 using The H.A.M.B. mobile app
  16. Rickyy
    Rickyy
    from France
    I understand better your remark on my blog.
    You must find an hypoïd fregate rear end (after 1957), with all the support that is different.
    It's the "pleasure" of customization :D
    Surfcityrocker and Ratatouille like this.
  17. Ratatouille
    Ratatouille
    from France
    Resume......
    Thanks to everyone for your ideas and messages
    The Fregate is not equipped with a standard rear wheel positraction, it's an independent suspension, like Jaguar, no leaf spring. (pics soon, it's raining:mad:)
    The tips to upside down or flip the old Renault parts it's only when differential and gearbox are all in 1. The same thing on VW bettle and camper or Corvair or Dauphine (rear engine cars...or somes front wheel drive Renault cars). The Fregate is not like that cars.
    All Fregate engines rotate Clockwise, like the Pinto.
    I have check my old Renault gearbox, model 277, and when I turn the front axle, the rear turn opposite. In fact, when you use 277 gearbox, you must use Type 6 differential only, it's an inseparable combo. Counter Clockwise rotation. What I have on my Fregate.
    The second generation use 295 Gearbox, use with Type 350 differential, Clockwise rotation. (more "standard" and "modern";), I'm a lucky guy:p)
    For the motor swap, I have only check the rotation of both engines, not what kind of differential type I was equipped....my unknown mistake.
    The good news is that is possible to have 5 speed and one reverse with the Type 350 Renault differential and my Ford Engine/Gearbox combo.
    Now, I must find all the parts......o_O
    Outback, brEad and OahuEli like this.
  18. Peanut 1959
    Peanut 1959
    At least there is a feasible solution. As has been said here, before, your perseverance is inspiring! Keep at it. This is one of my favorite HAMB build threads.
    vetteguy402 and Ratatouille like this.
  19. OahuEli
    OahuEli
    from Hawaii
    I gotta say even though you really run in to some ****py situations you are always able to find a solution. That's one of the main reasons I enjoy your adventure.
    Remember the 3 P's. "Patience, Perseverance and Profanity!". It has served me well.:D
  20. mrquickwhip
    mrquickwhip
    Have you thought about going back to the breakers where you got the engine and gearbox and use the Sierra rear axle/suspension. If you can get the Sierra rear axle and copy or use the brackets from the fregate rear axle you should be able to bolt the Sierra axle straight on to the fregate ch***is brackets. Obviously you will need to use four stud ford wheels.
  21. woodbutcher
    woodbutcher
    :D Hi Mr Rat.Things are looking good.As the old saying goes"Into every life a little rain must fall".However,it sometimes feels like a monsoon.
    Good luck.Have fun.Be safe.
    Leo
  22. chrisp
    chrisp
    I have a center section that I'm not using from a '58. But I'm in Normandy.
  23. rgdavid
    rgdavid
    Would the centre section from the sierra work?
    If so you can have the thing for the price of post,
    lowcoe and Ratatouille like this.
  24. rgdavid
    rgdavid
    Does the frigate original gearbox output turn the other way ?
    Counter clockwise ?
  25. Ratatouille
    Ratatouille
    from France
    Thanks guys for your propose.
    rgdavid, i prefer first to swap the old 1954 differential by the 1958. Because it's more "plug and play" ;-).
    Yes of course the Sierra differential is a good option, and similar, but there is too much work, and adaptations. But thanks again for your great proposition.
    Yes, the original 1951/1956 gearbox (model 277) turn counter clockwise.
    Chrisp, you've got a message ;-)
  26. Ratatouille
    Ratatouille
    from France
    The problem is that I should do it again the transmission shaft, and also 2 propshaft....and it's too expensive for me. I cannot do the job with my limited tools.....If one day I modify the rear end, I will put an entire IRS Jaguar rear end with disk brake.
    But you right, Sierra differential is the second logical option, but not for now.
    It is difficult to work in the street, on the ground, in safe conditions (neighbors, cars park across my car, and other personal reasons....), leave the car without rear wheels, up on jack is not feasible. The car must look like functional every time i doesn't work on it.....(I must clean all the place everyday...).:confused:
    chryslerfan55 and Outback like this.
  27. Woogeroo
    Woogeroo
    from USA
    You have to work with what you have. There is no shame in that.
    Build the car that you can, that you can love.
    -W
    Ratatouille, OahuEli and vetteguy402 like this.
  28. Ratatouille
    Ratatouille
    from France
    No time for the rear end today, because I must move the car. I have install gas pedal (cheaper s**** :-(...china made, I have modify all the parts, nothing was adjust, wrong parts in the packet, well, Chinese parts)....that not working perfectly, but I'm in rush to move the car.
    Mission complete, it move!, bye bye the wall, I'm in center place. I can see again the Fregate front. Still a lot of work to drive it correctly, but I'm happy to move the car again.
    Now, I can work on kool things. I'm boring about heavy charges, I need for my mental to work on small details;)
    My licence plate smack the ground! I need original uncut front springs. :confused:
  29. rramjet
    rramjet
    I'll bet if I looked up the word perseverance in the dictionary there would be a picture of you and your car. Great work
  30. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Keep at it rat, youre getting there once again!
