Hot Rods SBC overheating...yes I've tried almost everything!
Discussion in 'The Hokey Ass Message Board' started by 55panelwagon, Apr 28, 2017.
  1. Caddy-O
    Caddy-O
    Sounds like timing or you have an air pocket in the cooling system.
    1. Take the thermostat housing and thermostat off/ out of the intake manifold.
    2. Observe the level of coolant/ water.
    3. Top off the coolant/ water level until it overflows onto the intake manifold.
    4. Re- ***emble and test
    Gr8laker likes this.
  2. texasred
    texasred
    from Houston
    I would bet "your" left nut you have air trapped in the block..
  3. 325w
    325w
    Your saying it has a flex fan. If it's a standard flex it's blowing air instead of pulling the air. You said the water pump is stock. That's reverse flow. If it's reverse the fan must also be reverse.
  4. Montana1
    Montana1
    Did you plug the pump and manifold fittings or did you run a loop of hose to them? I've had some goofy things happen when they were plugged and not allowed to byp***.
    Gr8laker and squirrel like this.
  5. squirrel
    I'm still waiting for the picture, which would show the "straight" fan blade and reverse rotation belt setup :)
  6. 55panelwagon
    55panelwagon
    It's an aluminum flex fan, 6 blade. I was add a picture after while.
  7. 55panelwagon
    55panelwagon
    I will do this and see. So you're saying add the water to the intake and not in through the radiator, correct?
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    as Squirrel said, a picture is worth a thousand words
  9. 55panelwagon
    55panelwagon
  10. 55panelwagon
    55panelwagon
    Here are some pics, guys. I included one of the carb to show the vacuum advance hook up location.
  11. Gman0046
    Gman0046
    Electric fan in front of an engine driven fan? Whats with that? I'd ditch both of them and install a 6 blade steel engine driven fan.
    Gary
    belair likes this.
  12. Rex_A_Lott
    Rex_A_Lott
    I'm only surprised it don't run hot all the time
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    you have a reverse rotation water pump and a normal rotation fan. those two things will not work together. the elec fan and mech one are fighting each other.
  14. 55panelwagon
    55panelwagon
    So this fan will not work regardless of how it's mounted? Also, the electric fan should be mounted as a puller I thought? Aren't they more efficient that way? I really do appreciate all the help guys. Please don't be harsh on me, here.
  15. squirrel
    buy a reverse rotation fan blade. Remove the electric fan.
  16. BJR
    BJR
    So for a test, pull off the engine driven fan and use the electric puller and see if it overheats. If it doesn't overheat get the correct engine driven fan and ditch the electric.
    Engine man and jackalope like this.
  17. 55panelwagon
    55panelwagon
  18. squirrel
    That one might be a bit too agressive, I'd get a flex fan, or a clutch fan.
  19. squirrel
    Or remove the mechanical fan, use only the electric fan, see how it does.
    BradinNC, Engine man and BJR like this.
  20. Ebbsspeed
    Ebbsspeed
    I'm surprised the fan blades haven't laid back at high RPM and hit anything. The blades on those fans are supposed to bend into a flatter airfoil at high RPM, but since yours is spinning backwards the blades are actually biting bigger chunks of air and pushing it towards the radiator. You put the right rotation fan on it, it's gonna be quieter and probably give you back a couple horsepower.
  21. 55panelwagon
    55panelwagon
    So I'm guessing the flex fan I have know is normal rotation?
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    yes
  23. harpo1313
    harpo1313
    from wareham,ma
    Correct ,and time it with a light.
  24. 55panelwagon
    55panelwagon
    Okay guys. I can't thank you enough. I've (believe it or not) ran into this problem a few years back on a 50s Chevy pickup I was building. It completely slipped my mind that the water pump on these newer models were reverse. You guys are lifesavers! Thank you again! I will find a different fan and check back in!
  25. pprather
    pprather
    I think I have a reverse rotation GM fan in my garage, waiting for the s**** man. Let me check when I get home tomorrow afternoon. Phil
    Sent from my Nexus 7 using The H.A.M.B. mobile app
    harpo1313 likes this.
  26. 55panelwagon
    55panelwagon
    That would be amazing!!
  27. Hatchet
    Hatchet
    Don't forget a 16# cap
  28. 55panelwagon
    55panelwagon
    I will be sure to change that as well!
    Hatchet likes this.
  29. junior 1957
    junior 1957
    you changed the intake manifold right? did you use the intake gasket set for the tbi engine? if so they could be on backwards, the stock tbi gaskets have blocked off rear coolant p***ages with very small bleed holes in them, flipped to the front coolant p***age, severely restricts the coolant flow
    Mike's Garage, Joshweber and Mdbtyhtr like this.
  30. 55panelwagon
    55panelwagon
    I used gaskets for the older style SBC.
    dirtcop likes this.
