Projects Not Your Average Coupe Build: ‘37 Chevy Unearthed
Discussion in 'Traditional Customs' started by oneratfink57, Jan 31, 2017.
  1. 1blown57
    1blown57
    from Florida
    LOOKS FANTASTIC!!!! :cool:
    oneratfink57 likes this.
  2. pila38
    pila38
    Looks great! Keep up the good work and pace.
  3. hacknwhack
    hacknwhack
    from mass
    I've enjoyed following along since January.
    I've seen kieths 37 and I completely understand your vision, that car is stunning.
    Keep going. Nice work.
    Sent from my SM-G920P using The H.A.M.B. mobile app
  4. oneratfink57
    oneratfink57
    from Wisconsin
    I was determined to knock out the major floor pans back to the trunk today, and wound up making it in 8 pieces
    One main piece for the transition from the cabin to the trunk
    One main piece for the trunk itself
    And 6 side panels to integrate the step over the frame rails
    Once the floors were done I laid out some simple bead roll designs for rigidity between the floor supports
    The trunk
    The cabin to trunk transition
    Now I've got all of the main floor pans complete! Just need to stretch/ flatten them out.
    The only panels I have left is the tail pan and main portion of the transmission tunnel
    Now before I can actually weld the floors in I've got a pretty big to do list including dropping the motor and trans, so I decided to throw the block on the engine stand so I can tear it down what's left of it and bring it to the machine shop. I'm going to employ my 6 year old daughter to help me though! I'll see if my 4 year old is interested but it's highly unlikely lol
  5. oneratfink57
    oneratfink57
    from Wisconsin
    Today I was in a mad dash. It's not my best, but I feel I hammered out a lot of work today! I was in a rush because i wanted to spend my time with the kids tomorrow hunting for Easter eggs etc!
    I employed the help of the kids to tear down the block I'd use for mock up in the 37 later in the day
    Cut out the wacky motor mounts that were in the car so I could get started
    The plan was to mount the trans crossmember and make front frame adapters for my hurst engine mount.
    Unfortunately all did not go according to plan and I forgot how rotted the bottom of the top hat frame was. So I started by cutting out the dead metal on both frame rails.
    The biggest pain in the rear was grinding down all the spot welds. To be entirely honest, I gave up and left any good metal left on the flanges and just patched over it.
    Then, as true New England cars do, the ch***is gave me a little surprise Chipmunks!
    Used 16 gauge sheet metal to replace the lower steel.
    Overhead flux core on my side. Car was only on dollies but I was determined to squeeze under the car and weld it. The discomfort certainly shows in the weld quality lol. I'll run a better looking p*** over it some other time
    Then it was time to drop the motor and trans. I don't have any pictures of it but I mounted up the transmission cross member and began the work on the motor mounts.
    My original plan was to take the factory 69 Camaro mounts and flip them upside down to use them as pockets inside the frame rail, but I didn't realize the reinforcements for the lower control arms came so far up into the cross member.
    So I had to fab up frame adapters from scratch. This picture shows the first iteration which I changed. I didn't feel like using cardboard today so I cut all my iterations out of steel, mainly because I'm just stubborn!
    You can see by pocketing the frame rail, it allowed me to drop the motor about 2" lower than the factory Camaro location, which brought the motor and trans closer to level
    Dropping the motor and trans
    final iteration of my frame adapter
    And voila!
    Motivation today was brought to you by, the blues brothers
    I hope you all have a wonderful Easter. Thanks for reading
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. 1blown57
    1blown57
    from Florida
  8. oneratfink57
    oneratfink57
    from Wisconsin
    Didn't spend a whole lot of time in the garage today. But I finished my bolt in cross member
    Cut out the old sketchy angle iron one
    Cut my 2" diameter 0.125" wall tube to fit between the rails, minus the space for two 0.25" side plates
    Made two side plates out of 0.25" bar stock, and tacked them to each end. Had to break the tacks, grind tube and repeat a few times to get a perfect fit that I'd be able to get out from under the car if I had to.
    I made some standoff shock mount brackets out of some standard tube shock tabs and sections of the 0.25" thick pipe riser clamps that I used on the trans tunnel earlier in the build.
    Taking care that the shocks were on a 15-25 degree angle as most shock manufacturers recommend, I placed the newly made shock mount brackets accordingly and tacked in place.
    I made the shock mount tabs this way because I knew I'd be tight on space, so I wanted a little more flexibility with installing the shocks and bought some shock mount studs to use on the cross member, and with me using round tube, I had to accommodate rotating the shocks 90 degrees because they wouldn't be vertical.
    Once everything was tacked solid, I removed the cross member and welded everything solid. One of these days I'll upgrade to a 240volt multi process welder. But for now the 120v Lincoln and flux core will have to do
    Now I can cross the cross member off the list of things to do before I weld the floor pans in!
    I also dropped the body for the channel today. Tough to capture in a picture so I didn't bother.
    I did find that I screwed up though! My attempt to align the factory mount locations to the newly built floor (while it was hovering 3" over the frame) didn't turn out so great and I'm about 1/2 hole off on all 4 that I made lol, so I'll have to do a few modifications before I bolt the body to the frame.
  9. oneratfink57
    oneratfink57
    from Wisconsin
    After some maths, 2" lowering blocks are as low as I can go without having to redo what I did today. That comes out to 7" of ground clearance between the fender and the road with a 25" tire
    I figure any lower than that and I'd want adjustable ride height. Remember the body is channeled just under 2" anyways
  10. rusty1
    rusty1
    ...when you bolt that rear shock x-member to the rails, be sure you don't overdo it as the frame will compress or smash together, you real should install heavy wall tubes thru the frame, or try to mount that x-member to the framerail flange.
    kidcampbell71 and oneratfink57 like this.
  11. oneratfink57
    oneratfink57
    from Wisconsin
    Thats a great point, thanks for the input!
    I was concerned about the wall thickness of the frame too. I initially wanted it removable so down the road I could more easily change the rear suspension setup if I wanted to, but now Im almost thinking I just weld the cross member solid to the frame because I just want the car on the road! lol. At this point I cant bolt it to the flange because the side plate thickness is about 1/3 of the flange length, so I wouldnt be able to weld and extension and get a bolt through it.
  12. oneratfink57
    oneratfink57
    from Wisconsin
    I could actually cut some more side plates, and use them on the outside of the rails so it spreads the clamping force out over a larger area. That would help too!
    kidcampbell71 likes this.
  13. Crusty Chevy
    Crusty Chevy
  14. rusty1
    rusty1
    yeah, what Crusty Chevy said, that's my vote too,..that'd be the easiest way to do it and it'd be bolt-in and easily remove-able...
  15. oneratfink57
    oneratfink57
    from Wisconsin
    Ahh yeah I remember looking that up and thinking I didn't have square tube, so I used what I had. You guys are right though. I might have to look into changing it up. Plus it would give me the opportunity to move the shock mounts out so I could drop the car lower if I wanted to.
    Stay tuned, I might just have to pick up some square tube
  16. robber grin
    robber grin
    Great job man!
    I will also be referring to your build when I start my 47 KB floors
  17. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks robber, be sure to post some pics when you get started!
    tomschev2 likes this.
  18. 39 Aaron NZ
    39 Aaron NZ
    WOW! I've just read your whole thread. It's a good looking chop that you started with.
    And your floor is awesome! From the 'technical' white board planning to the great bead rolling! (My daughter still just spreads my tools around work shop)
    It's motorvation to get back into my sedan.
    I like your 'get on with it' at***ude and high standed of work.
    I will watch your build with great interest!
    Thanks Aaron.
    Sent from my SM-G360G using The H.A.M.B. mobile app
  19. I too just got done reading the complete thread, nice job!
  20. rusty1
    rusty1
    ...you can use the round tube you have, just get 2 angles like so, and cut your tube to fit between em, bolt it to the frame flanges...see sketch below...
  21. oneratfink57
    oneratfink57
    from Wisconsin
    Good call, at first I figured I'd go under the frame like ch***is engineering for additional support, but you're right, cross members don't usually do that!
    The bottom plate would have to extend past the original side plates (front to back) in order to capture the flanges on the inside of the frame rail. So I'd actually cut the flange so the side plates can be flush with the bottom of the frame rail, and then could grab 4 bolt holes when I weld the lower plate to my cross member
    Sketched a picture below. The new iphone notes sketch feature is pretty awesome by the way!
    Black=frame rail
    Light green=current crossmember
    Dark green=new lower plate per your suggestion
    Blue=bolts
    The upper picture is the cross section of the frame and the bottom picture is a top view(despite the fact it should of actually been on the top lol)
    Let me know your thoughts!
    Sent from my iPhone using The H.A.M.B. mobile
    kidcampbell71 and Mild Mitch like this.
  22. deathrowdave
    deathrowdave
    from NKy
    I have made many rear shock mounts for early Chebbys , by just using a triangular shaped plate bolted to flange . 2 bolts inside , one outside , with a tab welded on to use the same shock stud/bolt as you are using . Lower was a piece of angle , 4 holes for u bolts and one for center pin of spring , other side of angle trimmed to triangle shape , with shock stud /bolt for lower mount . You will notice when you get deeper into build than rear axle is not centered into fender opening . Using angle lower plate bracket will allow you to drill center pin hole 1 inch to rear to correct wheel spacing in the opening . Try to locate images of OEM , rear axle mount and you can see why installing a later axle changes wheel in fender opening . Remember these early springs where not designed to with stand the torque of a V8 they were just to support body weight and suspension , they had a torque tube to limit torque load on springs . I twisted up a few pairs of OEM 37 springs before I got wise to traction master style bars to stop spring wrap . Good Luck your doing great work and you will enjoy the 37 great cl***ic body style even if it's a Chebby ! Just stirring the pot I owned one for many years and many fun miles
  23. oneratfink57
    oneratfink57
    from Wisconsin
    Something like this? Arrow is pointing toward inside of frame. I kind of like that as long as I can get a short enough shock to accommodate. Stays out of the way of exhaust when I route it
  24. deathrowdave
    deathrowdave
    from NKy
    You got it ! Sorry not smart enough to draw on this thing ! But you got the idea , it works great
  25. oneratfink57
    oneratfink57
    from Wisconsin
    No worries! I wasn't smart enough until yesterday lol
  26. rusty1
    rusty1
    ...I made mine like your last sketch, but like this...which allows for a longer shock....no crossmember from rail to rail, just these mounts
    kidcampbell71 and tb33anda3rd like this.
  27. oneratfink57
    oneratfink57
    from Wisconsin
    Despite the most recent conversations I did not work on the rear shock mount brackets/crossmember today. Although I will revisit that sometime soon
    What I've been getting sick of is shuffling all the floor pans I made around because they're all loose in the car.
    So I decided to weld up what I felt I could without regretting it later ( due to misc projects underneath the car etc)
    Unfortunately I pushed off flattening my potato chips for later so I got to deal with it today!
    Before
    After
    Although it's not perfectly flat accross the panel, I took most of the crown out of it when compared to the first picture, which is all that's really necessary for a floor pan.
    One bit of advice is to be careful not to overstretch the panel, which I did in one spot on the p***enger side! So I'll have to go back and shrink it with a torch before I weld the rear pans in
    Next I drilled 0.25" holes two inches apart around the perimeter of the panel to plug weld to the tube structure.
    I really love these cleco pins! For those of you who have never seen/ used them I highly recommend them when working with sheet metal with any lap joints
    While I was welding the two center panels in, I remembered that I'd need some seat mounting tabs when I go to make or buy a seat. So I threw four front seat mounting tabs in. I made sure to recess them down about 1/16" so that they would be flush with the front floor pans step I rolled into them
    I also received my lokar shifter from one of our fellow HAMBers this week. It's a 23" tall floor mount so it's pretty radical for a traditional custom, but the price was right!
    Shot of the two center pans welded in, and the p***enger front pan pinned in place ready for weld
    Last task of the day was cutting off the p***enger door that has been welded on since I transported it back in November. Now it lets a little more light in the car so I can see what I'm doing lol
  28. kmrumedy
    kmrumedy
    Just read this whole thread. Very cool. Wonderful work. Will follow this one.
    I also came across an ad today where the seller was selling the following: ( Not sure if there is anything you are looking for..... I have no affiliation with seller.)
    Below is a list of various vintage hot rod body parts available for sale:
    1937 and 38 Chevrolet Sedan doors
    1937, 38 and 39 Chevrolet head and tail lights
    1941 - 46 Chevrolet Pickup head lights
    1941 - 47 Studabacher headlights
    1937 and 38 Chevrolet Coupe truck lids
    1937 and 38 Chevrolet Sedan truck lids
    1936 - 39 Chevrolet roofs
    1937 and 38 Chevrolet side gl*** and roll down windows
    1937 and 38 Chevrolet chrome door handles
    1937 and 38 Chevrolet bumpers, nose, grills and hood trims
    1937, 38 and 39 Chevrolet heater boxes
    1937, 38 and 39 Chevrolet Coupe hoods
    1937, 38 and 39 Chevrolet Sedan hoods
    1938 Dodge Coupe doors and front fenders
    For all inquires please call Moe directly at 519-648-3072 (no emails please)
  29. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks for the lead. I could be in the market for a set of doors
    kmrumedy likes this.
  30. rusty1
    rusty1
    kmrumedy,...that guy should have no problem sellin that stuff
