[/URL][/IMG] Well, I got my rear window in today. I ve had this sticker sitting on my desk staring at me for the last five months waiting to go on the car. Finally have a place to stick it
[/URL][/IMG] I got my windshield in today. I am celebrating the small victories these days, not much time to work on the car right now. Working six days a week.
I thought I would share a bit of my little winter project that I have been working on the last few months. I got an idea stuck in my head just after Christmas and decided to see if I was able to make it work. Keep in mind that I have no grand illusions that this is going to add any real horse power to this stock banger. It was just a fun project that I want to tackle. So I removed the stock intake and exhaust and used some 1/2 plate I had and marked out the intake and exhaust holes and drilled them a hole saw.
The idea was to make my own header and intake manifold and use two side draft carbs and have some cool velocity stacks sticking through the hood side. I know its not traditional as anything that someone ever did back in the day but I wanted to try it and do it on the cheap as I didn't want to sink a ton of cash into a project that probably wont be on the car more than a year. I went on the hunt for a couple of Zenith side drafts from early tractors, but they are incredibly expensive to purchase. So I had a set of vintage motorcycle side draft carbs that I decided to use instead, they were free, so they fit the budget. I wanted twin exhaust pipes, running right from the headers, along the same path as the stock exhaust and exiting in the stock location. So I bought some pre bent 1.5" primary exhaust tubing and started to mock it up.
I didn't take a ton of pics while I was doing this. So here it is with the headers done and the intake built with the carbs mounted. I also added a "speed" cap to the stock distributor and some cloth covered wires to give it a more "racey" feel HAHAHA. I didn't want to use a cable for the throttle linkage so I used the stock gas pedal and linkage hooked to a bell crank that I made and up to the carbs. It worked really well and I like the mechanical look and feel of it.
Looks great!! I love Tudors Where are the plug wires from? I need to replace the ugly modern ones on my car. You may not want to keep the headers wrapped. Initially I had mine wrapped on my speedster, the car never warmed up enough. It was a cold blooded *****! Model A's like a bit of heat in the intake to help aspirate the fuel look at the way your stock intake mates to the exhaust. After removing the wrap it was better, she's still slow to warm up and pops and snorts.
How does it run with those carbs? What are they off? Rejetting or run as is? NielsK [emoji4] Sent from my SM-G930F using The H.A.M.B. mobile app
Thanks guys. Tiny, the wires are just bulk Primary wire I got from the Old Car Center in B.C. as well as the ends and then I cut them to length and crimped the ends on. Works slick, and cuts out enough of the RFI that was coming from the stock copper wires that I can now use my remote for my garage door with the engine running Nielsk, it runs like a top! These carbs have a throttle valve as well as the sliders. So I can open the throttle WOT and the sliders will only open as much air is flowing so it is harder to over carb it. So far I have only driven it around the block a few times, but it really opened it up.
I wanted to put some velocity stacks on it to add to the "racey" look. In the interest of not spending too much money, a friend of mine took some stainless steel tubing and belled the one end and opened the other to fit over the mouth of the carb. I then drilled and taped the bottom for a set screw to hold them in place. These carbs are Mikuni BS off of a vintage 750XS Yamaha- Not old enough for here Sorry. If the carbs are an issue, I will take these posts down if needed. I wanted to use older carbs, but these were free. I have not done any jetting on them yet, just balanced them and set the idle mixture. So far so good, but I haven't driven it far. The weather here has been horrible!
So with the velocity stacks on, there was no way a hood side was going to fit over and close without some modifications. So I had to decide between running without hood sides, or making something. After removing the hood side, I decided that there needed to be something on there. Something about my A sedan without the hood side just made the car look too long to me. I found a good hood side for $20 and started to lay out the plan. I took some 3/8" round stock that I had and bent it into an oval. Then I measured it all up and cut a corresponding hole. I them made a wooden "buck" to matched the curves of the stock louvers and went to town shaping them the best I could. I think it turned out okay. Hoping to get it into paint in the next few weeks. You may notice that the oval is set back a bit. I did that so I could reach in through the hood side and apply the choke. But I think I should have evened it out a bit more by just making the oval a bit longer. Oh well, this is how she will be for now.
Thanks for the answer. I asked because I saw it was CV carbs. I done the same trick earlier with 1.5" SU's. Right now I'm messing around with a pair of Zenith's. But would like to go back to CV's again. Your set up looks "killer" [emoji4][emoji4] I like it a lot Sent from my SM-G930F using The H.A.M.B. mobile app
Thanks Niels. SU are fantastic carbs, I thought about using them, but I couldn't find any. These were sitting in my garage and free [emoji41] so that's the way I went. Sent from my iPhone using The H.A.M.B. mobile app
This is how the tailpipes ended up. I wanted twin pipes exiting exactly how the factory ones were. I am happy with the look of it. A couple weeks ago I got a line on an original "B" Police head for the car. I got it for really cheap. Of course there is always a reason things are cheap. I knew when i bought it so I knew what I was getting. You can see where someone has ground out the crack in it to try and repair it. As well, there are a few ****py cold welds that someone tried to do. I have a friend that has the skills to repair this for me, so he will be going to work on it soon. Hoping it works out so I can use it and give this thing a bit more kick LOL. Even if it is not useable, I got it so cheap, it will still make killer wall art.
Well I got a chance to drive the car yesterday to a local show and put a few miles on it. The carbs work perfectly. Definitely opened it up. And I love the sound of the two carbs ****ing in air as I open her up. [emoji41] Sent from my iPhone using The H.A.M.B. mobile app
Thank you for the compliment. I think if I had to do it again I would have used a thinner round stock. I think it is a little too thick and takes away from the velocity stacks. I used a 3/8" but 1/4" may have made it look less bulky.
I just came across this thread, you do great work and I love your car especially the hood side. Very slick!
Thank you. Been driving the hell out of it every chance I get. Running strong. The "B" Police head isn't going to work out. It cracked in a new place when grinding out the welds. The head is Still cool wall art for the garage. I just realized that I need to fix all the other pics in this thread from earlier. Sent from my iPhone using The H.A.M.B. mobile app
Really like how you set your intake and headers up. Very nice!! Did you have any pics of your intake? Planning on doing a set up with SUs. Thanks for sharing your build and it is great your son had a active part. Great Job!!!
Thanks for the compliment. What pics of the intake would you like? I can take any angle for you and post them. Sent from my iPhone using H.A.M.B.
Thanks .. Did you have any before mounting? The ones you have already posted will be fine.. And thanks again..
I did but I must have deleted them. Here are a few pics I just took for someone else that was also asking about it. The engine is no longer in the car. I went a different route with the Tudor this last winter. Still banger, just a bit different. This drivetrain is now waiting for the start of a Turtle deck T project that I am planning. Sent from my iPhone using H.A.M.B.
I went back after I posted a while back and you posted more pics of the Carb set up.. Thanks I really want to try and add some or one SU and see if I can make it happen.. Thanks for the for the pics. Oh and what did you change on the Tudor??
