Technical how did you paint that? fixtures and taping technics
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 10, 2016.
  1. tb33anda3rd
    tb33anda3rd
    because this car is so big and i would rather not get paint on my pants i decided to paint the roof first. sanded and taped off. DSCF0001.JPG DSCF0002.JPG
    jazz1 and The37Kid like this.
  2. tb33anda3rd
    tb33anda3rd
    i had to use a step stool and "kneel" on the edge of the car to get enough paint in the center. car is deceivingly big!
    tomkelly88, brad2v and The37Kid like this.
  3. The37Kid
    The37Kid
    Like the granite counter top look on the doors and quarters, that might catch on in New Hampshire. Bob
    tb33anda3rd likes this.
  4. tb33anda3rd
    tb33anda3rd
    i hate the way these came out, ****ty chrome flaked right off when i was pepping them. if i didn't blast to the edge the primer flaked off, if i balsted to the edge the chrome flaked off in spots. these will be sent out and chromed again by a competent chrome plater...... DSCF0002.JPG
  5. tb33anda3rd
    tb33anda3rd
    DSCF0002.JPG screwed a strip of angle to the saw horse, then bolted the fender through the running board holes. then held up the front of the fender with a wire to a bracket in the ceiling. DSCF0001.JPG DSCF0002.JPG
    Bowtie Coupe, MP&C, X38 and 1 other person like this.
  6. tb33anda3rd
    tb33anda3rd
    propped the running boards up with spray cans wrapped in paper this keeps the edge of board off the paper. the bottom and edges of these have already ben painted. DSCF0004 2.JPG
    Bowtie Coupe, MP&C and lc1963 like this.
  7. tb33anda3rd
    tb33anda3rd
    DSCF0001.JPG before painting i put a couple strips of tape to isolate the mix ratio i am using. it keeps me from fumbling trying to find the proper scale after the first mix. a quick wipe on the inside, between the tape and i am ready to mix the next cup.
    vtx1800, Peter Nowak, reagen and 15 others like this.
  8. teach'm
    teach'm
    from Tucson, AZ
    That is a damn good idea there! Work smarter, not harder.
    Bowtie Coupe and tb33anda3rd like this.
  9. tb33anda3rd
    tb33anda3rd
    thanks. the older i get, the fuzzier thee numbers are..........
    Bowtie Coupe likes this.
  10. tb33anda3rd
    tb33anda3rd
    super nice fender fixture posted by @nunattax on his thread. 075.JPG 076.JPG
    nunattax and Bowtie Coupe like this.
  11. TagMan
    TagMan
    Very effective, very simple.......why didn't I think of it ? Great idea. :D
  12. The37Kid
    The37Kid
    Why do I see a dog house with a canopy in the photo Doctor?
    clem, Bowtie Coupe and tb33anda3rd like this.
  13. willys36
    willys36
    Tinting the bubble top on my Mysterion clone. I hung it from my paint booth hanging rails and sprayed from underneath.
    I made a kart that I used to make the fibergl*** body pattern then cut it down to scoot the body around while finishing and painting.
    Most of the time I use Harbor Freight steel tubing 'saw horse' type parts holders and/or hang parts from two 1" conduit rails mounted to the ceiling of my paint booth using hanging wires made from welding rod that hook over the conduits. You can see one of the conduits in the Mysterion body picture above.
  14. Bandit Billy
    Bandit Billy
    that pic of the top hanging form the ceiling reminds me of Maxwell Smart's "Cone Of Silence".
  15. willys36
    willys36
    "Missed it by thaaaat much!"
  16. tb33anda3rd
    tb33anda3rd
  17. 1953naegle
    1953naegle
    No pics, but one trick I learned for painting cast parts from working on industrial machinery: if you need to tape off flat machined surfaces (think: manifold bosses on heads, etc.), cover the area in tape, but instead of trying to carve it out with a razor, use a small ball-peen hammer to lightly tap along the edge, shearing the excess tape off. The tape cushions the taping enough that you don't damage the edge, and you are left with perfectly masked castings.
    The second thing has been well illistrated already, which is the painting "philosophy" to always paint the least accessable, least visible areas of a part first.
  18. tb33anda3rd
    tb33anda3rd
    primed a set of fenders for a rpu hot rod today. used a couple pieces of threaded rod, run through some angle iron that was hung by a hook from the ceiling. it was faster to use a couple hose clamps to keep the rods from sliding than to run nuts all the way to the center. the fenders are light enough that i was able to lift the angle iron to get the back end of the fenders. DSCF0001.JPG DSCF0002.JPG DSCF0003.JPG
  19. tb33anda3rd
    tb33anda3rd
    Bowtie Coupe, MP&C and TFoch like this.
  20. tb33anda3rd
    tb33anda3rd
    The37Kid, Bowtie Coupe, MP&C and 3 others like this.
  21. tb33anda3rd
    tb33anda3rd
    this eyelet screwed into this bracket will serve two purposes, to give me a spot to hang it from and to keep paint out of the threads. DSCF0002.JPG
    Leakie, brad2v, TFoch and 4 others like this.
  22. tb33anda3rd
    tb33anda3rd
    taping some wheels for two tone. wheels were sealed with a black sealer, then i shot some black basecoat on the areas that will be black. then using a plastic fine line tape i taped off the edge i wanted to create. DSCF0001.JPG
  23. tb33anda3rd
    tb33anda3rd
    and then some paper to seal out the rest of the area.
    for the out side edge i just used tape, holding it flat with the wheel so it will lay flat. i then pushed it under the edge with the pointed handle of a paint brush, then some paper to cover the out side. note i also taped off the valve stem hole to keep any paint off of the back side, which i already have painted. DSCF0002.JPG
  24. tb33anda3rd
    tb33anda3rd
    once the blue was painted on "the field" i untaped it and clear coated. DSCF0005.JPG
    AHotRod, brad2v, MP&C and 2 others like this.
  25. The37Kid
    The37Kid
    NICE! Now comes the scary part installing the tires and chrome lock ring! I've made a fixture to keep the wheel fixed and off the floor high enough so the back of the tire is off the floor too, then sort of wrap the lock ring in place without it touching the wheel. Have taped tire irons and rubber hammers ready. Don't forget to index the lock ring gap with the valve stem hole, it is a Packard. :) Bob
    Wayne67vert and Bowtie Coupe like this.
  26. LAROKE
    LAROKE
  27. tb33anda3rd
    tb33anda3rd
    first time i have ever sanded and buffed a set of wheels. posting this because i like the crazy reflection. DSCF0004.JPG
  28. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^ REALLY NICE! I can see them getting a wide pinstripe about 3/8 wide with a contrasting stripe on either side normal size. Bob
  29. jakesbackyard
    jakesbackyard
    from ND
    The wheels look great! What are they for? I’ve never seen wheels with 7 lugs.
  30. nunattax
    nunattax
    me neither
