Technical Shoebox glass questions
Discussion in 'Traditional Customs' started by Tom. C, May 6, 2017.
  1. Tom. C
    Tom. C
    1. what gaskets do I need to put chopped car front gl*** back in?
    2. I ***ume it is possible to omit front and rear wing windows on a four door and go with one piece window?
    3. What do I need to make it work without w/windows besides gl***?
    any prior links or any ***istance would be greatly appreciated
  2. Jalopy Joker
    Jalopy Joker
    post some pics of what you are working on - what year? - did you cut the front gl*** already? - don't ***ume anything
  3. '49 Ford Coupe
    '49 Ford Coupe
  4. Rusty O'Toole
    Rusty O'Toole
    For gaskets use a stock gasket cut down and glued together with krazy glue. You can eliminate the center post by making the gl*** a little wider so it ****s together, and seal the seam with clear sealer. This is an old Kustom trick from the fifties.
    For the doors you will have to relocate the front channel that the gl*** slides in, and make suitable gl***.
  5. Tom. C
    Tom. C
    The car is a 1950 four dour. And my post is 50 more door comments questions complaints. All the pictures are on their. Thanks for help! the post should be on pg. 1 as I just posted pictures a couple days ago.
  6. '49 Ford Coupe
    '49 Ford Coupe
  7. Tom. C
    Tom. C
    1950 four door. No I have got to that point of gl*** work yet but I would like to know what to do when I am their. Thanks I have been really sweating this part and the body work.
  8. '49 Ford Coupe
    '49 Ford Coupe
    Talk to Carson. .at..http://www.streetrodgl***.com..he cut my gl*** for everything I needed....looks like you are a LONG way from needing gl***
    4rod likes this.
  9. ahshoe
    ahshoe
    I just spent the last few weeks installing all the chopped gl*** in my '50. Just last week we did the front windshield. I made a cardboard template leaving 1/8" in the center to fill with black 3M bedding compound. The back window was laid as stock into the new chop angle. I made template for the rear side 1/4 gl***, door gl*** and the wing windows. I can provide pics of specifics if necessary .For now I have in my file the windshield pics. Also a pic of the vertical center rubber I cut out from the stock weatherstripping.
  10. the-rodster
    the-rodster
