Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. wojojo
    wojojo
    No pics to post today but Happy Easter everyone !!!
    rc57 and Ron Funkhouser like this.
  2. froghawk
    froghawk
    Still needs license plates but otherwise the '58 Impala ragtop is finally done. Started working on it in 2011! Built from an original 1958 SMP 3-in-1 Customizing Kit.
  3. Jon SSS
    Jon SSS
    The '58 Impala above is the shizzz. Nice work.
  4. 41 coupe
    41 coupe
    from bristol pa
    Froghawk you do some amazing builds
  5. Pinstriper40
    Pinstriper40
    Nice work as usual Froghawk! You've got killer paintjobs down pat! Do you use frisket paper or BMF to mask your designs?
    There's gotta be more progress out there this week! I've got a pile of parts, Kustoms seem to take a bit longer, so I thought I'd build the A roadster on deuce rails. It's a neat kit, just wish it had a chrome banjo rear or quickchange. I'll have to check the parts box. 1492398730566660572324.jpg
  6. Kit Bash
    Kit Bash
    '25 Ford Coupe from the double T kit.
    Cut the roof and visor off.
    Decided to add some kind of wood frame to the bare interior.
    I also changed up the rear window opening.
    The new roof opening got a framework to hold "chicken wire".
    The screen is an RF shield on some cable from work.
    (Electronic/Electrical Tech)
    The trunk is next.
    Have an awesome Sunday, Y'all.
  7. quick85
    quick85
  8. quick85
    quick85
    In the works, this old MPC 56/57 Corvette kit I found recently at a thrift store for $5.00. Unbuilt,
    unpainted, unmolested and best of all, complete.
  9. edcodesign
    edcodesign
    image.jpeg Good Sunday morning. A Vette for the Nationals, from two parts cars.
    themoose, ct1932ford, gonmad and 10 others like this.
  10. quick85
    quick85
    Hey, model builders, post something today, even old cars that are far from perfect.
    I might get an idea or two.
    Kool 'vette, edcodesign.
    lothiandon1940 and edcodesign like this.
  11. edcodesign
    edcodesign
    Thanks, I think the hard part is done.
    lothiandon1940 likes this.
  12. wojojo
    wojojo
    Here's a couple. Don't remember if I posted these before. IMG_4135.JPG 40 Ford Rebuilt.JPG IMG_3160.JPG
  13. Kit Bash
    Kit Bash
    Razor Saw work...
    New cowl vent
    New deck/trunk lid with hinges
    Clearance cuts for rear chassis
    Elongated/stretched chassis to move pie crust slicks back
  14. Kit Bash
    Kit Bash
    Whoops. . .
    Forgot pinned chassis w.i.p. photo.
    Changed up the kit rear end quick change with a Parts Pack Dragster rearend.
    Buick drums from my stash.
  15. gnichols
    gnichols
    from Tampa, FL
    Ok, you asked for it. My 1/8th RM Deuce build is from way back in 2005. Here are some construction shots, from the make-shift frame table to paint and a diorama. These pix are old and from a very low quality digital camera. The Y-block is from a Lindberg T, seats from a RM XKE kit. A small chop on the top. Suicide front end and Z-d frame over the diff. I have a bunch of 1/8th kits stashed away, mostly destined to be rails, gassers, altereds and the occasional dirt car. Who know when I'll get back to them.... so little time. Gary
    DSC03698aW1000.jpg DSC03700aW1000.jpg DSC03530aW1000.jpg DSC04651aW1000.jpg DSC04873aW800.jpg DSC04885.JPG DSC04928a.jpg DSC04994a.jpg DSC04995a.jpg DSC04969a.jpg
  16. edcodesign
    edcodesign
    Wow, great job !!!!
  17. gnichols
    gnichols
    from Tampa, FL
    Thanx... hopefully I can start another one this year!! Gary
    Ron Funkhouser likes this.
  18. rc57
    rc57
    That's awesome Gary.
    You're trying to get me hooked on the big ones too, aren't you.
  19. gnichols
    gnichols
    from Tampa, FL
    Sure, why not. Trouble is, there aren't a lot of kit bodies to choose from, and not much in resin. BTW, there is a 1/8th / large scale thread here and a couple three web sites out there. But I haven't been on the web sites lately. Check that out. Gary
  20. From the 80s
    From the 80s
    Current build. Long way to go. First H.A.M.B. friendly build in awhile. Been awhile since I posted here. I hope this is right...[​IMG][​IMG][​IMG]
    Sent from my SM-N920T using The H.A.M.B. mobile app
    kiwijeff, ct1932ford, LostBoy and 8 others like this.
  21. quick85
    quick85
    Yes, I did and I'm glad. Those are some righteous models.
    From the 80s and lothiandon1940 like this.
  22. quick85
    quick85
    That '55 has a very kool look. That heavy flake takes me back to the late '60s.
  23. Kit Bash
    Kit Bash
  24. edcodesign
    edcodesign
  25. gnichols
    gnichols
    from Tampa, FL
    ^ Thanx for the pix! Gary
    Kit Bash likes this.
  26. Kit Bash
    Kit Bash
    A 'lil update on my '25 Ford Coupe project.
    Chassis work...
    Shorten the rear trailing arms and add a small tube joint.
    Cut out the rear spring perch to lower is some in the rear.
    Dropped the suicide spring perch on the front a sconch (technical term).
    Modified the front hairpins and made some teardrop attachments. Thinned down the Buick finned drums.
    Yada Yada Yada. . .
    Nailhead engine from the '40 Ford delivery is next on the work pile.
  27. wojojo
    wojojo
    Here's a mockup of one I'm working on. It's a resin 2 door post body from Drag City casting. Narrow whitewalls and chrome wheels. Floorpan has been painted proposed body color of Honduras Maroon.
  28. Rindy
    Rindy
    from 43351
    Couldn't believe my eyes when I saw your Fiat "Walt's Puffer" altered! I saw this car in person at the drags in Toledo, Ohio at the old municipal airport back in about '61. What scale is yours & who makes it?
    Nice job!
  29. quick85
    quick85
    Thanks very much, I appreciate it. It's half of AMT's double dragster kit, 1/25th I imagine. It was
    actually the Blueprinter special from the early to mid '90s.
  30. edcodesign
    edcodesign
    image.jpeg image.jpeg Happy Sunday morning to ya, thanks for all the likes. Progress on the Vette.
