Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Mike Colemire
    Mike Colemire
    I like AC/DC. As far as hard rock that was about it. CCR, Bob Seger, that what I grew up with. The best music is 2 gassers leaving the line, and then hearing them go through the gears.
    loudbang and Bad Banana like this.
  2. saltflats
    saltflats
    from Missouri
    The meltdown drags have old rock music playing.
  3. dirty old man
    dirty old man
    But the Meltdown Drags ain't got the SE Gassers:D
    Dog_Patch, Floater03 and loudbang like this.
  4. saltflats
    saltflats
    from Missouri
    That is true but there will be some there.
    Dog_Patch, loudbang and 91whitestang like this.
  5. the meltdown may not have many se gassers but they can fill the void with nitro. everything goes faster with nitro.
  6. Dog_Patch
    Dog_Patch
    I never bore scoped it because the leakdowns are all about 12% which is where they were before the first start this season. The new lifters are a different shape than last year - they don't have a notch where the oil galley comes in. They are just a straight plug of steel. I don't have a pic. My current theory is the oil that was splashing in the lifter valley before has made the volume to the rockers higher than last year. Literally everything else is the same - same pump same heads etc.
    So - drain hole #1 - will try it out and see if it needs another up front.
    Then to just completely spend a Saturday on fun stuff. I start my kickout oil pan
    Of course I'm proud of my little kickout so I sent a picture to @402BOSSMAN he says BIGGER. Hell I'm all about BIGGER! Let's open this sucker up!
    And after 4 failed water leak tests - I officially hate this more than making headers - or maybe not .......
  7. enloe
    enloe
    from east , tn.
    Tony will "Endeavor to persevere"
    loudbang and Dog_Patch like this.
  8. Dog_Patch
    Dog_Patch
    Love that movie - its hard to sneak up on an Indian. Hey are you going to Paradise on Saturday? I might haul up there and see if the mosquito fogger is fogging less.
  9. enloe
    enloe
    from east , tn.
    I would love to but my Daughters last AAU basketball tournament finishes up Saturday.
  10. Floater03
    Floater03
    from Byron Ga.
    Do a leak test with some anti freeze, that shit will find a void!
    Dog_Patch and loudbang like this.
  11. Dog_Patch
    Dog_Patch
    What a time consuming PITA :confused: had nothing else to do so :D
    I need to get @3dnsouth to put a little TIG on these. Nick made longer stacks out of the left over tube - gonna test some flow theory -
    Since we're quoting songs and movies - CLUTCH - Escape From The Prison Planet - I told Nick - Theories Will Be Tested!
    Parties Are Crashed, Skid Marks Are Measured.
    The Story's In The Paper, You May Read It At Your Leisure.
  12. Just finished the whole thread. Great stuff. I'm sure you'll get it all figured out soon. Best of luck. I'll be following along for sure.
    Hang'emHigh likes this.
  13. Mike Colemire
    Mike Colemire
    You can buy a deal to hook to a smart phone really cheap. They work good and you can always have it with you. Plus you can enlarge stuff if you can't see like me.
  14. Dog_Patch
    Dog_Patch
    Thanks for reading along - maybe someday it can save someone some Hemi Headaches - my latest one :
    There's a guy on Ebay selling 'ready to run' 392 dizzy's - I've had a bunch of trouble with distributors so I got one of these a while back. It got me running at Shady Side - so it did save the day - but it was wobbling like HELL!! So I decided to check it - its not the Small Block Mopar distribuotrs fault - he's got a pinned sleeve that he puts on the end of the shaft.
    Oy Vey! Doesn't anyone check the stuff they sell anymore?
    This is how Hot Heads solves the Mopar shaft length for a Hemi issue and it works :
  15. I have had good luck with the msd ready to run unit. I run it locked out with a crank trigger.
    mad mikey and loudbang like this.
  16. saltflats
    saltflats
    from Missouri
    Do you need a ready to run dist with a crank trigger?
  17. saltflats
    saltflats
    from Missouri
    With a crank trigger you only need a rotor and a cap to to trow the spark.
    If you ever put a timing light on an engine with a crank trigger it looks like the mark is welded to the timing tab on the cover.....not like a pickup or points in the dist.
    That must be why some classes wont let you run them.
    mad mikey, Dog_Patch and loudbang like this.
  18. the msd ready to run can be used without the crank trigger.
    mad mikey likes this.
  19. Dog_Patch
    Dog_Patch
    Do they have a mechanical tach drive version? I didn't see one offered and I ran the last race with no tachometer. :confused:
  20. dirty old man
    dirty old man
    Tony, do the rules require a mech. tach? MSD boxes that I have dealt with have an electrical tach hookup.
  21. dirty old man
    dirty old man
    All I know is I had an electrical tach in my sbc powered '53 Stude in '65 that came outta a '63 Chev. SS. Seemed to work OK for me.
    mad mikey and Dog_Patch like this.
  22. I had a sun electronic tach in my 383 '63 Plymouth. It had a black box sender. Been a long time ago, but it I put it in no later than '65.
    Dog_Patch likes this.
  23. dirty old man
    dirty old man
    There was no black box with the OEM Chev. tach I was using, hooked up straight to the wire between coil and points.
    I do remember the Sun tachs with the black box.
  24. Mike Colemire
    Mike Colemire
    Sun had the one with the black box, they had problems with it. I had one years ago, seen one of the boxes on ebay the other day.
  25. Dog_Patch
    Dog_Patch
    You can run an electric tach in the SEG - I just prefer my mechanical - that pic above is a 440 or 383 dizzy. The rotation of the tach drive is opposite of my magneto - but the mechanical tach doesn't care about the rotation - still works.
    402BOSSMAN and Higgy's Henry like this.
  26. im not aware of a tach drive msd. that does not mean it cant be used with a mechanical tach. there are drives available that work off the fuel pump. there were all kinds of crazy adaptors to run different components. I think it would look cool use one. I prefer mechanical tachs.
  27. Hemi Joel
    Hemi Joel
    from Minnesota
    If you want a crank scraper, Ishahara Johnson can build it. My build is similar to yours, 4.525 crank and Milodon 4 bolt main conversion, and I am currently working on fitting the IJ scraper.
  28. saltflats
    saltflats
    from Missouri
    Like engine porn!!!!
  29. WillyB- great music choices! Beethoven was actually almost completely deaf by the time he wrote his 9th (had lost a great part of it when he composed the 5th). At one point, he had the legs cut off his favorite piano and had it set on the wooden floor to amplify the sound (like an extra resonator), and would lay down with his ear pressed against the floor, hammering on the keys to try to physically hear what he wrote.
    Not too sure about mathematics being applied (a little too structured for his fiery personality and temper), but there are many stories of Beethoven feverishly scribbling down his musical ideas on anything that he could- tablecloths, wall paper, etc the moment they popped into his head- didn't want to lose anything he thought up. Along with the rules of music theory, Beethoven had a tremendous experience and understanding of the tone and timbre of the instruments he wrote for, and used audiation to compose- the ability to hear sound without any sound being physically present. In a nutshell, without singing, think of the song "Happy Birthday"- if you can hear it in your head, that's audiation!
  30. Dog_Patch
    Dog_Patch
    WillyB - its time for you to piss off! I am done hearing about your damn TET shit and what ever other airplane bullshit you used to do - so PISS OFF! And no I have not had my coffee yet.
    Hang'emHigh, ottoman, das858 and 4 others like this.
