Technical T5 IN 32 FRAME
Discussion in 'The Hokey Ass Message Board' started by fatboy tim, May 7, 2017.
  1. fatboy tim
    fatboy tim
    from Edinburgh
    I'm changing the 3 speed in my 32 5 window to an S10 5 speed as that seems the best way to go and use the Cornhusker adaptor. Anyone got any photos showing how they modified the original K member to suit the transmission?
    I think the S10 is the smallest of the T5's and means the K member cutting is as little as possible.
    Thanks for any advice.
    Neighbour Dave
  2. big duece
    big duece
    from kansas
    The frame already had some torch work done when I got it, so it wasn't so bad on the heart to clean it up. It would have been really hard to cut a nice original K member for a T5.
    Pewsplace likes this.
  3. big duece
    big duece
    from kansas
    Ch***is Engineering center mounting kit for '32 ford ES 2132. You will have to cut off the bar on the bottom of the T5 case that the anti chatter rods were fastened to. You will have to cut a fair amount out.
  4. fatboy tim
    fatboy tim
    from Edinburgh
    Thanks for the photos, appreciated and nice workmanship, good job!
    Yes you are right about the K member but the 3 speed is murder to drive as we are 350 miles away from anything so the wee flattie is screaming on the motorway (freeway).
  5. thommoina33
    thommoina33
    Alliance Member
    from australia
  6. fatboy tim
    fatboy tim
    from Edinburgh
    Thanks yes have thought about that, comments seem to be its a finicky thing to operate. Thanks for replying.
  7. swifty
    swifty
    Check out Cory Taulberts thread on the build and update on his 32 5 window. He has just fitted a T5 in his coupe and is planning on detailing the mods necessary to do the job and minimising the "damage" to the frame.
    Tim_with_a_T likes this.
  8. Tim_with_a_T
    Tim_with_a_T
  9. Andy
    Andy
    3.25 rear gear or Columbia.
    trad27 likes this.
  10. fatboy tim
    fatboy tim
    from Edinburgh
    Thanks for the advice, all appreciated.
  11. bct
    bct
    Got a thread ***le? Thanks
  12. Dino 64
    Dino 64
    from Virginia
  13. Pewsplace
    Pewsplace
    Here is another way of mounting the T-5 in a stock ch***is. the builder used two K-members.
  14. Kato Kings
    Kato Kings
    from Minnesota
