History Drag Roadsters............picture thread
Discussion in 'The Hokey Ass Message Board' started by Royalshifter, Jun 7, 2009.
  1. loudbang
    Ray's Sunoco
    Goodie
    High Heaven
  2. loudbang
    Looks like a Pontiac 4 cylinder
    EVL401 and 1947knuck like this.
  3. loudbang
    Jewel "T" note blocked spoke wheel
  4. loudbang
  5. Offset
    Offset
    from Canada
    Loudbang the BB/A could have been in the ownership of Canadian Top Fuel racer Scott Wilson when this picture was taken. Wilson owned the car around 1961. The car was originally built in 1959 by Keith and Doug Ridler who were, I believe were from the London, Ontario Area.
    After Wilson the car was sold to Miller and Gregory in London, Ontario, it won its cl*** at Indy in the early 60's. Miller and Gregory ran it with both front mounted blower and a conventional top mounted set up. They sold the car to the Brothers Browns (there was an altered owned by the Brown Brothers from Detroit and thus the wording) who raced out of the Roadmates Club in Mississauga, Ontario. They removed the motor for their Fiat Altered and sold the roadster to Brooke DeShaw who ran it as a B/altered. Later it become the "Avenger" and then disappeared from racing. I understand that the car was made into a street rod in the Orillia, Ontario area but it has not been found. Apparently the front mounted blower motor is owned by a fellow from the London, Ontario area.
    Thanks for posting that picture, never seen it before.
    The car when DeShaw owned it with Performance Improvement sponsorship.
  6. loudbang
    Good stuff it's great when we can get the whole story about the cars from our members.
    deadbeat, enloe and Offset like this.
  7. loudbang
  8. loudbang
  9. Offset
    Offset
    from Canada
    I really like that pickup roadster.
    t-rod, Hotdoggin DaddyO and loudbang like this.
  10. loudbang
    How about this nice one? Look at those tiny Slicks
    EVL401, 1947knuck and deadbeat like this.
  11. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    This says Rock and Roll to me.
  12. Dean Lowe
    Dean Lowe
  13. loudbang
    Big piecrust slicks, parachute, tonneau cover, and an injected BLOWN HEMI what's not to like A LOT. :)
    Hotdoggin DaddyO likes this.
  14. deadbeat
    deadbeat
    Love this thread and I could listen to Dean and y'all talk about racing back in the day all day long . I don't mean to start a **** fight but a lot of cars ran 4 bar back then. I thought that didn't start until the 70's. On with the show,,cheers
  15. loudbang
    Otie's altered roadster
  16. Dean Lowe
    Dean Lowe
    Pete & Jake took credit for innovating the 4 bar. In fact, Norm Grabowski and Tom Ivo used 4 bar front ends on their T buckets in the mid 50's.
    deadbeat and loudbang like this.
  17. deadbeat
    deadbeat
    cheers Dean
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Lots of early dragsters and altereds used torsion front suspension, with the torsion bar arms being one set of 4-bar elements and an additional bar on each side to fix the caster location being the other set.
    loudbang and deadbeat like this.
  19. loudbang
    Rastetter
    Ron Ellis
    Note the very short exhaust pipes
    Speedmasters
    The Instant "T"
    Warlord
    EDIT: from 64 Dodge 440 it should be WARLOCK
    Willy
  20. 64 DODGE 440
    64 DODGE 440
    from so cal
    Believe it was "Warlock" not "Warlord".
  21. loudbang
    Fixed it
  22. Dean Lowe
    Dean Lowe
    Very early Pure hell before paint.
  23. Dean Lowe
    Dean Lowe
    Not Speedmasters. Glen Way's his Ground Shaker Jr. Probably Gary Reed in the seat.
    EVL401, 1947knuck and loudbang like this.
  24. loudbang
    What's the big pulley for?
    Isky
    Tony Nancy
  25. RichFox
    RichFox
    I'm going to guess injector pump. Maybe oil. Picture of oil pump on '28 Chevy. I have also run the fuel pump off the same drive, at times. To cheap to buy "Race" pulleys. I use cam drive pulleys. These off a Gold Wing. Guy in the picture might be cheap to. DSCN0038.JPG
  26. loudbang
    LOL that is an OLD photo don't think gold wings were out yet LOL. But good guess I was thinking pan evacuation maybe.
  27. RichFox
    RichFox
    I have used FIAT, Pinto, and Jensen-Healey pulleys before. Datsun and Toyota are probably the same. Every one i have looked at was the same. Then I just get a Gates, Dayton or Goodyear belt. A lot less than Summit. Here is an OIL/Fuel pump drive using Jensen-Healey (Lotus 907) pulleys. Whatever you can find at the junkyard. Easy to do. TB Ford.JPG
    270ci, stillrunners and loudbang like this.
  28. Dean Lowe
    Dean Lowe
    It's a Hilborn pump drive. Early ones used a V belt before small timing belts were around. We ran one like that on my RPU until we switched to the mag/pump drive. The V belt would flip over above 6 grand. We even made an idle pulley tensioner that got it up to about 6500 before the belt flipped over.
    cactus1, deadbeat and loudbang like this.
  29. RichFox
    RichFox
    First injector i ever had used a BL pump in the distributor drive. I had an EVM (Ron's Racing) injector that used a V belt drive. Turned plenty of RPMs with that 2 liter Pinto motor. Seemed OK.
  30. loudbang
    Chris Swift "Swifty"
    at dover
