Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Lets keep this great thread on topic.
  2. dirty old man
    dirty old man
    I agree, the Beethoven stuff, in fact any music stuff is off topic, and the moderators will be killing the thread,and although I'm thankful for what the guys did in Vietnam, this isn't the place for it, and even though I'm a retired aircraft machinist and mildly interested, the aircraft stuff is off base also.
    mad mikey likes this.
  3. captmullette
    captmullette
    tony bought an airplane ?
    enloe likes this.
  4. dirty old man
    dirty old man
    Bobby, you need to go back about 1 page or so and read up till now and you'll understand what's being discussed.
  5. captmullette
    captmullette
    just a joke DOM, had to take a break on the car and put on some more bandaids.........
    brEad, Dog_Patch and enloe like this.
  6. dirty old man
    dirty old man
    OK, and I understand, I just picked up another clutch disc and pressure plate plus adjustable hydraulic TO brg shipped to me via 2nd day air from McLeod that my wore out old *** will be installing in BGII over the next couple of days.
    Will hit 80 this year and this ain't getting any easier, I'll tell you that.
  7. agreed.
    Dog_Patch likes this.
  8. Hemi Joel
    Hemi Joel
    from Minnesota
    I don't want to highjack, this will not be a Southeast G***er legal car. But the Hemi is pretty similar to Dogpatches, and I figured the oil control info might be helpful. Ishihara Johnson now has a pattern for the crank s****er, so it should be pretty easy to get one for your Dodge. Mines's a .060 over 392, 4.525 Moldex crank, Milodon steel 4 bolt main caps on 2, 3, & 4; TR Waters main stud girdle, oliver steel rods, 13.:1 diamond pistons. Hot Heads by the esteemed portologist Bossman. It is still a work in progress, the car hasn't run yet. Since it is for street/strip, I'm pumping a lot of oil to the rocker gear so it will survive. I ran it on the dyno last year, with one -8 drain line from each head to the pan. I have a sight gl*** on the pan to monitor oil level with the engine running. On a dyno pull. it was holding 8 quarts in suspension or in the heads! And it smoked. So I am adding another drain line to each head, and adding the crank s****er. I should know the results pretty soon. It's going in a 31 Plymouth coupe, planning to run Drag Week.
  9. Dog_Patch
    Dog_Patch
    Wow that is really similar to my engine. So even with the -8 lines to the pan it was filling the heads? :eek: Its really weird to me that I ran 2 years with no drain and no smoke. I'll get in touch with Ishihara since your pattern probably will work - the stock 392 was way off on the stroker. If my problems continue, I will put a oil restriction in it. I'm not driving that far and in 8 more races, the stuff goes back to Nick to look over anyway.
    loudbang, mad mikey and Fiddle Picker like this.
  10. Hemi Joel
    Hemi Joel
    from Minnesota
    I don't know if it was filling the heads, or in the crank windage or what, but it wasn't in the bottom of the pan. I might have had the returns to the pan too low, but I'm not sure. I raised them up a bit and added two more for the next test.
    loudbang, mad mikey and Dog_Patch like this.
  11. Brand Apart
    Brand Apart
    from Roswell GA
    Drag week, That's a bucket list item for sure. **** I was getting annoyed with OT posts myself now look at me
  12. I will post pics later what oil restrictors will do with missle rockers. its not pretty or recommended. the rockers need 35 lbs minimum oil pressure all the time. the oil needs to be able to get to the intake adjuster screw. if it was me I would be pulling the pistons on that side to check the oil control rings. i have seen the wavy oil ring get over lapped on itself before the other two rings went on. this situation would for sure cause a smoke screen. not having returns is not the only issue here. there is something else going on. a bad oil ring would not show up on a leak down or compression test. I put a number 12 fitting in the back of each valve cover thinking that's were the oil would be under hard accellration. just like a oil pan.positioned in the middle of the head the rear half would have to fill up before it started to work.
    402BOSSMAN, loudbang, ottoman and 2 others like this.
  13. Dog_Patch
    Dog_Patch
    I talked to Gene Adams at length about the drain and he wanted it below the oil line. His reason was that if you pick an arbitrary place about the oil line it could get in a heavy splash zone and that would fight the returning oil. I put the return below the oil line. Hope this is the end of this issue. Nick wants me to cut open the top of an old valve cover and look in there to see what's going on.
    402BOSSMAN and loudbang like this.
  14. saltflats
    saltflats
    from Missouri
    Need to find the magic spot so it works like the header evac system.
    Dog_Patch, loudbang and mad mikey like this.
  15. you wont see a problem at idle. you could run the engine at a idle with the covers off. if the cam journal is grooved that would result in alot more oil getting upstairs.
  16. Nocero
    Nocero
    I love reading all these southeast g***er build threads, and love watching the YouTube videos Is there a website or list of tracks you run and rules?
  17. dirty old man
    dirty old man
    Google Southeast G***er ***ociation and you will find the website with schedule and rules.
  18. Dog_Patch
    Dog_Patch
    Not sure if you do Facebook but the most up to date page is there.
  19. Nocero
    Nocero
  20. Dog_Patch
    Dog_Patch
    Finally got tired of the access hole to the clutch springs - posting so anyone running a RAM cintered iron might save some time if you do this on the bench instead of the car. I used a drill, hole saw and a air powered sawzall .
  21. Hang'emHigh
    Hang'emHigh
    So now you're going to add clutch dust to your crop-dusting runs? Pretty soon you'll get outta the car and look like John Force, all sooty-faced! ;)
  22. Hemi Joel
    Hemi Joel
    from Minnesota
    I probably missed this in the last 113 pages of this thread, but earlier on you had a Hightower trans. Now you have a Jerico. What happened?
  23. allwilly
    allwilly
    loudbang and Dog_Patch like this.
  24. blownhemi48
    blownhemi48
    from Bergen NY
    I had a discussion with Jim Oddy about this very subject at one of the AA/G races in Buffalo. He said you don't need oil drain lines if you have adequate breathers. He said he has never had any problem with oil puddling in his Hemi heads. His blown Hemi (354) Willys g***er regularly turns sub 5 second elapsed times in the 1/8 mile.
  25. dirty old man
    dirty old man
    Tony, not having seen that bell hsg before and that pic being so close up on it when taken, its hard to visualize what you've done, but Hopefully that'll make adjusting an easier job.
  26. Dog_Patch
    Dog_Patch
    Yeah missed 3rd about 50% of the time - then broke the shaft on 3rd because it was gonna go damn it - $700 to fix it and it missed 2nd 2x so I sold it cheap. The Jerico - - knock on wood has never missed. Probably the driver seat position is too high in my car because the 55 Chevy guys shift the hell out of the Hightower.
    Here's a better pic? Just having a hole you can't see in was some of the issue.
    loudbang and Hang'emHigh like this.
  27. allwilly
    allwilly
    Only downside to ur mod is it won't p*** a true nhra tech inspection
    Sent from my SM-G900V using The H.A.M.B. mobile app
  28. Dog_Patch
    Dog_Patch
    No Hot Rods Allowed
    Hatchet, Mtn Goat and loudbang like this.
  29. greybeard360
    greybeard360
    Make a bolt on cover for the hole... Probably p*** then. There are ****tershields made with large removable plates just for adjusting the clutch.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    Dog_Patch and loudbang like this.
  30. pigfluxer
    pigfluxer
    NHRA guys ain't having half the fun the SEG are having ,or putting on half the show.
