Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. 32 hudson
    32 hudson
    Your looking good Ron. Good thinking with using the mat.
  2. sloppy jalopies
    sloppy jalopies
    IMO...
    WD 37 .... at the wiring party maybe run an extra, fused, [isolated] 12v on or acc wire all the way out to the front... another one to the rear... tape them off and mark them...
    if you start blowing fuses or tripping your circuit breaker... you will have an isolated wire for a head or tail light, fan or distributer so you can tap into them to get home...
    find the prob later...
    Moondog13, Jet96 and bondojunkie like this.
  3. wheeldog57
    wheeldog57
    I have one coiled up under the hood of the Chevy
    Sent from my SM-G900V using The H.A.M.B. mobile app
  4. wheeldog57
    wheeldog57
    The weekend went pretty well. . . Got an ignition wired. My brother Scott the master electrician had it whipped up in no time. The brake line was another story. The wheel cylinders need 7/16 male fitting for the brake line and no oarts stores carry that so my brother Robert mounted the 't' in the back and drilled holes for the line hold downs. I put the rotating ***embly back together 20170507_205312.jpg 20170507_205404.jpg 20170507_205341.jpg
  5. Mikel50
    Mikel50
    wheeldog57 likes this.
  6. wheeldog57
    wheeldog57
    Got out of work a little early today so I torqued and pinned the rods, installed the oil pump cam gear, and water pumps.
    onekoolkat1950 likes this.
  7. wheeldog57
    wheeldog57
  8. wheeldog57
    wheeldog57
    I forgot I don't have a throwout bearing. Getting one after work today then I can slam the motor in for the last time. With any luck we will hear this very soon!
  9. wheeldog57
    wheeldog57
  10. Pete
    Pete
    Make it happen Ronnie....there's a spot waiting for you.
    wheeldog57 and onekoolkat1950 like this.
  11. wheeldog57
    wheeldog57
    Thanx for the support, I have been busting ***. I think I have everything. . . Until I need something! This time it's an oil pump screen. Engine install put off until tomorrow AGAIN!
    But it is looking good at least. 20170511_214138.jpg 20170511_214156.jpg Ben, here are some pics of the pedal ***embly. The arms look really close in the pics but there is plenty of room. 20170511_214544.jpg 20170511_214530.jpg 20170511_214337.jpg 20170511_214246.jpg
  12. 32 hudson
    32 hudson
    Looking good Ron you are making it happen !
  13. wheeldog57
    wheeldog57
    The bullet is back in. 20170512_213849.jpg 20170512_213913.jpg Rayco Machine comes through with the pick-up screen 20170512_125811.jpg
  14. Mikel50
    Mikel50
    Can't wait to see you running this thing on the sand !
    Doing great Ronnie !
  15. wheeldog57
    wheeldog57
    20170513_191956.jpg 20170513_192638.jpg cranked it over a few times. Got spark, but no fire yet. Mothers day lunch then back to it. Happy Mothers Day
  16. wheeldog57
    wheeldog57
    At 7:23pm May 14th 2017 something from nothing runs! I will attempt to send a video 20170514_193216.jpg 20170514_193216.jpg ok no video but here's a sideways smokey pic. SMELLS SO GOOD!
  17. 51box
    51box
    from MA
    Wow that's awesome man, you did one hell of a push to get it ready for the race. Keep it rolling and look forward to the video
  18. Mikel50
    Mikel50
  19. wheeldog57
    wheeldog57
    Didn't get much sleep last nite. . . . Too excited! I am going to toot my own horn now: just over 3 years ago I swapped some ralley wheels&tires plus a little cash for a model a frame from Mike Bowling. I had my families old trailer with a 40ish banjo rear under it. From there I just started collecting model a parts, swapping, selling, borrowing, and yes, stealing. Now this 'thing' runs. Pretty cool.
  20. brEad
    brEad
    Great job - you pretty much did it. Your story is similar to mine. I started with a set of big n little Cragars with tires and through a series of trades i'm up to a Model A frame, 283 motor, T5, Buick rear end, rims, a bunch of sheet metal (some ***embly required) and a handful of other parts. A little more trading and some spare time may see me with a Model A yet. Keep on pushing - you're almost there!
  21. wheeldog57
    wheeldog57
    Talking w/Mike yesterday, he says "come over here I have a box of stuff maybe you can use" I like Mike 20170516_180308.jpg
  22. onekoolkat1950
    onekoolkat1950
    Mike has helped and supplied me with many parts in the time I've known him. He is without a doubt a great guy. Great work Ronnie!
    chryslerfan55 and wheeldog57 like this.
  23. wheeldog57
    wheeldog57
    20170516_004453.jpg quick seat cover. Oooohhhh leather. Oh yeah. . . The car is red red 20170515_234830.jpg
    tb33anda3rd, OLLIN, Tim and 9 others like this.
  24. Mikel50
    Mikel50
  25. 120mm
    120mm
    from Iowa
  26. wheeldog57
    wheeldog57
    I was torn. I didn't want to paint it because it had some neat patina (especially the doors) but a racecar has to be flashy. I was accepted to participate in the race of gentlemen in New Jersey! So it needs to look fast too
  27. wheeldog57
    wheeldog57
    I painted until 1am Monday nite then was junk at work yesterday. Second coat last nite. I am wiped out but it was worth it
  28. onekoolkat1950
    onekoolkat1950
  29. Pete
    Pete
  30. Atwater Mike
    Atwater Mike
    Man... All the way up to paint!
    The for***ude of the members of the HAMB is best witnessed under the pressure of the participation in the Race of Gentlemen. -Perez' Hilton. (?!?)
