Hot Rods 39 Ford Coupe 430 MEL Start Up
Discussion in 'The Hokey Ass Message Board' started by GasserKid, May 12, 2017.
  1. GasserKid
    GasserKid
    She woke up tonight
    First Start Up
  2. Spooky
    Spooky
    GAWDAMN this is kewl!
    kidcampbell71 likes this.
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. Jalopy Joker
    Jalopy Joker
  5. The 39 guy
    The 39 guy
    Sweet Nostalgia!
  6. hotrodyankee
    hotrodyankee
  7. 61cad
    61cad
    Congrats..... Sounds great!
    lothiandon1940 likes this.
  8. lothiandon1940
    lothiandon1940
  9. Jet96
    Jet96
    from WY
    Lookin' (and sounding). Good!
    GasserKid and lothiandon1940 like this.
  10. lothianwilly71
    lothianwilly71
    That sounds Bad ***!!!! Drive it like you own it...
  11. bobss396
    bobss396
    Awesome... but 6 carbs to adjust... nice job!
  12. okiedokie
    okiedokie
    from Ok
  13. Fitnessguy
    Fitnessguy
  14. flamedabone
    flamedabone
    Beats a Chevvie crate motor any day.
    Nice work, -Abone.
    kadillackid likes this.
  15. GasserKid
    GasserKid
    Thanks guys. Pretty amazing to finally hear it live. Can't wait to row the gears now.
    Engine Specs are
    1959 Lincoln 430 that came out of alcohol injected drag boat.
    Crank has been off set ground to bring it up to around 480 ci.
    Cam is reground Isky solid, as you can hear not a lot duration. But with that many cubic inches it's probably a little more rowdy than we know.
    Heads have been worked over a little but they don't need much in street car.
    Isky 1.5 rockers, pushrods and valve springs.
    Jahns 10.5:1 pistons
    Edelbrock 6x2 intake
    Vertex Magneto
    Toploader 4spd into 9 inch with 3.73 gears.
  16. GasserKid
    GasserKid
  17. vintakes
    vintakes
    the g***er i built is 430 powered did you hook up the rear intake manifold water ports ?? i hope so water flows thru block up rear of heads thru intake [stock] to w/p i ran 5/8 hoses from the rear fittings to a home made collector type box to heater hose fitting on water pump and 3/8 hoses from the front of intake to a tee in the outlet hose from the box to pump note the stock larger intake gasket water holes face the rear and you need to punch 3/8 holes in gasket front offy gaskets have even holes but you need the water to go thru the block to rear ports [also hope you installed the water pump deflecters in the block] my 430 NEVER overheated using mechanical w/p driven fan. great to see another MEL powered car enjoy johnny o
    kidcampbell71, unclescooby and Jet96 like this.
  18. GasserKid
    GasserKid
    Yes in fact we used pics of your Ford to get the cooling system right!
    kidcampbell71 and kadillackid like this.
  19. metalman
    metalman
    Oh, man. That's car ****, WAY cool.
  20. GasserKid
    GasserKid
  21. Tim
    Tim
    from KCMO
    So cool! I can about imagine the dance jack did when that thing lit up!
  22. Jet96
    Jet96
    from WY
    Very cool, it's fun to see more of these beasts wake up! Vintakes is right they have curious water circulation. Mine would start to heat if sitting for 20 min. in TX traffic. Once I got moving it dropped immediately. When I went from 4 blade fan to 6, it absolutely will not get hot.
  23. mongo4u2
    mongo4u2
    from sparta
    Here is my 430 mel in a 56 vickie g***er
  24. unclescooby
    unclescooby
    from indy
    This makes me happy
  25. GasserKid
    GasserKid
    Love your Vickie
  26. wheeltramp brian
    wheeltramp brian
  27. Tim
    Tim
    from KCMO
    Bumping this back to the top. What a cool hot rod.
    that thing cold starts easier with 6 carbs than mine with 1!
