Technical Looking for 331 Cadillac alternator location ideas
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Dec 26, 2016.
  1. Mike Paul
    Mike Paul
    I have '50 Cadillac 331 that is going into a '30 coupe and I'm going to be running headers. I want to mount a small alternator down low and I'm looking for some visual inspiration. Thanks
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I am running a generator on mine. Up on top because there was no room on the side in my 40[​IMG][​IMG]
  3. Mike Paul
    Mike Paul
    Looks good. I should also have stated that I plan running a u-fab 6x2 intake. How did you change your stock oil fill/fuel pump tube? I see you have a custom chrome one.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I just chromed the stock tube. and put a block off plate where the fuel pump went
    Desoto291Hemi likes this.
  5. javithewrench
    javithewrench
    I'm going to try to run my alternator off the driveshaft. I know it will not charge if I'm stopped but I think it will be enough. I want a simple empty engine compartment.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. jvpolvere1
    jvpolvere1
    I've seen small alternators that can be, or are, machined to fit inside a generator housing. Gives the old school look with
    Upgraded performance. Don't remember where I saw them, but start with Summit to see if they can help.
    Sent from my SM-T377V using The H.A.M.B. mobile app
  8. jvpolvere1
    jvpolvere1
    Moriarity likes this.
  9. clunker
    clunker
    from Boston MA
    Let us know if that works. Cool idea.
    Wouldn't want to get stuck in a traffic jam though.
    Here's a thread on the Hamb about that:
    http://www.jalopyjournal.com/forum/threads/driveshaft-driven-alternators.443232/
    One of the last posts in that old thread is a link to:
    http://www.racemate.com
    Which makes water pump/alternator combos, ( not for Caddies though, yet another reason to run a SBC, I guess)
    I dig the way old generators look myself.
  10. clunker
    clunker
    from Boston MA
    WTF really and Moriarity like this.
  11. Jmountainjr
    Jmountainjr
    Off the rear axle yoke works good if you have low electrical draw. I run a mag, so it's only an issue for me at night. Secret of making it work well is taking the vibration out of the mount. I made a rear mount for the mounting bolt to run through:
    rod1, Hnstray and clunker like this.
  12. DDDenny
    I've commented a couple of times here on people with flathead powered cars wanting to use an alternator but wanted to maintain a traditional looking engine compartment.
    There was a magazine article a few years back where a guy built a mount on the front of his flathead allowing the use of (IIRC) a right angle cable coupler off the crankshaft leading to a hidden alternator underneath the car out of sight. I've attempted to find it a couple of times with no results. I still think it is a great idea for numerous applications.
    Ned Ludd likes this.
  13. Find your local industrial electric motor shop.
    Get a small denso from a forklift. 65 amps and fits anywhere.
    Same as here but should be 1/2 the price http://www.ecae.com/alt1.html
    Member "Loud pedal" built an alternator mount and drive off the bell housing for the green grenade coupe. Pretty slick
  14. warbird1
    warbird1
    I mounted the alternator on the 331 in my '31 roadster very much like Moriarity did on his '40, only place it would fit.
  15. nailed31
    nailed31
    Do you have room around the transmission tail shaft? I'm thinking if you mounted it there, it'd be less vibration and same RPM. Thoughts?
    "Just because you can put tap shoes on an elephant doesn't mean it can dance!"
  16. Mike Paul
    Mike Paul
    I was thinking about that option also.
  17. Mr48chev
    There should be plenty of small readily available alternators that will tuck in where you want to put one and hook up with a simple fabricated bracket. The alternator on my 91 GEO Prism GSI puts out 70 amps and is a little bitty ****** that would be simple to bolt up in most case and only needs a pulley swap.
  19. nailed31
    nailed31
    What was your decision on mounting your alternator?
  20. Mike Paul
    Mike Paul
    I'm going to try to find one small enough to fit down low between the motor mount and the crank pulley. If that doesn't work then it will probably go on the drive shaft somewhere
  21. Mike Paul
    Mike Paul
    Well it’s been six years but I’m finally getting around to fabricating an alternator brackets . Since there is no accessory holes in the front of the block I fabbed a top bracket off the engine mount. The bottom bracket will be bolted to the oil pan bolts. I’m still working on that one.
  22. sdluck
    sdluck
    There was somebody that ran a cable back to their alternator NASCAR used cables to run their fuel pumps for a few years, the small lawn mowers and tractors most of them have Nippon or Mitsubishi alternators that are pretty small
  23. DDDenny
    All righty then, hope Mike doesn't mind a little side track here.
    I sure would like to find that article that I mentioned prior, I'm thinking it was in Street Rodder:eek: and since I recycled 99.9% of my magazines I thought I'd just throw out a request for those that still have their's to keep an eye out, it does go back quite a few years.
    Thanks
    DDD
  24. BJR
    BJR
    Drive shaft driver alternators do not charge enough for almost all situations, other than a cross country drive staying only on freeways.
  25. nochop
    nochop
    from norcal
  26. Mr48chev
    That should work pretty nice when it's done. What alternator did you end up using?
  27. Mike Paul
    Mike Paul
    So here’s what I came up with. EFCB80DF-3609-4520-B9D9-48254A9E9B70.jpeg 8C2591A9-C8C3-480F-89B8-D93FC1E29B41.jpeg 6154B8B8-16E8-42AA-A608-EC43727FAD9E.jpeg 5751B7D8-E8E8-46D3-B923-0A2096A07F75.jpeg 96C8551F-54CD-4502-9724-265996559847.jpeg 134540E5-25A9-4CBB-AB37-CE190D9707EB.jpeg AF465736-9C80-4D12-88FA-0693A58C3E77.jpeg
  28. kadillackid
    kadillackid
    Success ! with plenty of adjustment, nice job.... :rolleyes:
  29. WTF really
    WTF really
    Wow y'all make me feel bad with all these pretty engines. Looks like I'm going to have to step my game up.
  30. Blake 27
    Blake 27
    Another compact alternator to consider is a late 80s 55 amp Chevy Sprint.
    Pictured on a SBC, to illustrate the size and home made brackets. HPIM1724.JPG A-5.JPG
    rod1, nochop and Desoto291Hemi like this.
