Projects Henry J Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Jan 16, 2016.
  1. Higgy's Henry
    Higgy's Henry
    Love the steering column!! That's gotta be the lightest one I've seen yet! I'll give ya a shout when I can.
    Uncledirty616 and loudbang like this.
  2. Uncledirty616
    Uncledirty616
    Got my driveshaft back, its all finished up, and the drums. I im gonna have to throw them up in my brake lathe now and cut some of the fins back so they will clear my backing plates. Its worth it to run these somewhat rare aluminum drums.. driveshaft front.jpg driveshaft back half.jpg brake drum.jpg
  3. Uncledirty616
    Uncledirty616
  4. Uncledirty616
    Uncledirty616
    Did a bunch with the car today. Finished welding the brake pedal then reamed it so it would still slide on the shaft. Then finished up making the linkage for the brake and clutch. 18622850_10209272492273779_15730303_n.jpg 18643820_10209272492953796_1736086384_n.jpg
  5. Uncledirty616
    Uncledirty616
    18622694_10209272496073874_2043549207_n.jpg Had to test fit to make sure i fit with the steering wheel and could still hit the pedals. this took a ton of tries due to my knees hitting the steering wheel
    mad mikey, loudbang and Dog_Patch like this.
  6. Uncledirty616
    Uncledirty616
    Then once i was happy with it, welded in another bar and added a pad for the all important Tachyometer ;) 18678903_10209272496113875_559055711_n.jpg 18622886_10209272496193877_1023204092_n.jpg
  7. D.N.D.
    D.N.D.
    Hi Guys
    I lost my number for Quain , do you have his shop phone number ?
    Thanks, DND
  8. Uncledirty616
    Uncledirty616
  9. D.N.D.
    D.N.D.
    Thanks Uncle for the number, DND
  10. southcross2631
    southcross2631
    One note. From the photo with your hand on the shifter, I hope that was third gear. With your belts pulled down tight you may have trouble reaching third if the shifter was in neutral.
    Just a thought.
    mad mikey, Dog_Patch and loudbang like this.
  11. Uncledirty616
    Uncledirty616
    I will probably have to make a bend in the handle. =(
  12. Uncledirty616
    Uncledirty616
    Pulled the front end apart today to finish welding a few of the things i couldnt get to with it together. figured while i had it apart i would do some painting painting.jpg straight axle paint.jpg radius rod paint.jpg
  13. catdad49
    catdad49
    You find Old Henry's axles in some of the strangest places! Met Higgy and his wife at the Steel in Motion show and shared my love of Henry J's with him. Didn't realize that he was from Canada, quite a haul to go racing. He made to the finals and it was fun to watch that H-BOMB going down the track. Keep buildin', a fellow "J" fan.
  14. Uncledirty616
    Uncledirty616
    Makin a steady pace. Made and installed the tabs for the seat belts, and painted all the seat and driveshaft structure so that i could go into the floor construction. and then just got started with the frame work of the floor. floor driv side.jpg floor pas side.jpg
  15. Uncledirty616
    Uncledirty616
  16. mad mikey
    mad mikey
    Lookin GOOD! Real GOOD!:cool:
    Dog_Patch, Uncledirty616 and loudbang like this.
  17. Uncledirty616
    Uncledirty616
    Decided to change the angle the floor connected with the back half of the car. This will give me more clearance for the seats, and HOPEFULLY be easier to tin in. floor change.jpg
  18. Clik
    Clik
    I hope to be tinning my HJ soon too so I'm following. Keep the detailed pics coming.:)
    Dog_Patch, loudbang and Uncledirty616 like this.
  19. Uncledirty616
    Uncledirty616
    Got my firewall and floor templates finished up to the backside of the seats. I feel this is a huge accomplishment. I know its just card board, but i have been avoiding this step.. I'm not sure why. I work tomorrow, so basically i plan to finish the rest of the way back in cardboard tomorrow, and spend Sunday doing the tin. floor.jpg pas side view.jpg driverside cb.jpg
  20. Clik
    Clik
    I can do frame and ch***is work all day long but I have been putting off all the sheet metal stuff too. I hate thin stuff.
    loudbang, Dog_Patch and Uncledirty616 like this.
  21. Uncledirty616
    Uncledirty616
    also picked up my gaskets and hiding in the peanuts is my new oil pan....motor coming soon! =) oil pan peanust.jpg mtf.jpg
  22. Uncledirty616
    Uncledirty616
    I dont know why it had me so worked up, but it did. Glad i finally dived in though
    saltflats and loudbang like this.
  23. Higgy's Henry
    Higgy's Henry
  24. Uncledirty616
    Uncledirty616
    Can't wait to get this one together
  25. Uncledirty616
    Uncledirty616
    So , now from Cardboard, we move to the real thing. I cut the aluminum with just an electric shear. I don't own much in sheet metal tooling so im firewall glove 1st pick.jpg working primitive.
  26. Uncledirty616
    Uncledirty616
    The wife actually got involved today. It was pretty awesome. She helped with the sheet metal and she started working on some body stuff that was driving her bonkers lol trish sanding.jpg sanding roof.jpg
  27. Uncledirty616
    Uncledirty616
    Getting the firewall cut was easy, getting it to fit...well thats another story. I had to recut the firewall area forward of the firewall...if that makes sense, i should have taken a pic. Anyway, it did eventually fit
  28. Uncledirty616
    Uncledirty616
    The floor pans were much easier. and doesnt the cutouts for the pedals and master cylinder make a face...maybe its just me. rawr pan.jpg rawr.jpg
  29. Uncledirty616
    Uncledirty616
    And here is what the front section will look like. I have the back cut out, but not shaped yet. completed, last.jpg
  30. saltflats
    saltflats
    from Missouri
    Big progress.....Looks Great!!!!
