Technical What does this symbol mean
Discussion in 'The Hokey Ass Message Board' started by itsonsucka, May 18, 2017.
  1. itsonsucka
    itsonsucka
    Thanks
  2. itsonsucka
    itsonsucka
    Help if I post pic lol[​IMG]
    Sent from my SM-G925W8 using Tapatalk
    deadbeat likes this.
  3. Sancho
    Sancho
    Not sure about the coil in the circle but the lines in a triangle usually represent a ground.
    Phillips likes this.
  4. steinauge
    steinauge
    from 1960
    If you are talking about the 3 lines they indicate a ground.
    chasey32 likes this.
  5. F1Jim64
    F1Jim64
    Heater element then ground? Block heater maybe?
    Sent from my SM-G920V using Tapatalk
  6. stuart in mn
    stuart in mn
    It's a light bulb.
    39cdan, deadbeat, metlmunchr and 12 others like this.
  7. onetrickpony
    onetrickpony
    from Texas
    The curl in the circle is a light bulb, like Stuart said.
  8. GMBOWTYE
    GMBOWTYE
    from Ames IA
    lite bulb in a circuit. junction of wire. lite bulb &ground
  9. ChucksCrib
    ChucksCrib
    from Uranus
    Clearly its a worm wearing a Devo helmet
  10. squirrel
    that's not a helmet, that's an Energy Dome™.
    mgtstumpy, deadbeat, Jet96 and 2 others like this.
  11. jimmy six
    jimmy six
    The rectangle is a joining spot for 2 wires. Like above ^^^^ its a light bulb and I'd guess a dash light..
    Alonzo "Lon" Wilson likes this.
  12. Slopok
    Slopok
    International sign for Transgender!:eek:
  13. flatheadpete
    flatheadpete
    from Burton, MI
    I think it means you should install the hot plate right there.
  14. Mike51Merc
    Mike51Merc
    Yes, it's a light bulb.
    Must be about 20 of them on your schematic.
    oj and 54vicky like this.
  15. AVater
    AVater
  16. seb fontana
    seb fontana
    from ct
    Good one...:D
    AVater likes this.
  17. Gray Ford
    Gray Ford
    from Illinois
    Only if it has FE power ....
    deadbeat and AVater like this.
  18. Is it a schematic for an accessory boiler and plumbing for a steam engine lost from another thread?
  19. itsonsucka
    itsonsucka
    It is lightbulb or where two wires met and create a light thanks guys
  20. Bleach
    Bleach
    If it's from a Lucas wiring diagram, it's where the smoke comes from.
  21. KRB52
    KRB52
    from Conneticut
    Is that also known as a "short"?
  22. it's the international symbol for "start troubleshooting here"......
  23. Heat food here
  24. Engine man
    Engine man
    from Wisconsin
    Smoke comes from anywhere in a Lucas system.
    Bomb and deadbeat like this.
  25. RMONTY
    RMONTY
    Wow.... Mr. Kerbel my senior year instructor in general electricity cl*** would be proud. I recognized the light bulb symbol immediately. That was 40 yrs ago...damn!
  26. 325w
    325w
    Dang even I knew that! They taught it both years I was a senior.
    King ford and RMONTY like this.
  27. lippy
    lippy
    from Ks
    In Ks it's mandatory to take 6 years of high school. :) I took 8 and still flunked.
  28. tb33anda3rd
    tb33anda3rd
    mgtstumpy and Jerrybigbird like this.
  29. Jerrybigbird
    Jerrybigbird
    from Montana
    tb33anda3rd likes this.
  30. butch27
    butch27
    "I've had a vasectamy " ??
