Projects Me to a T
Discussion in 'Traditional Hot Rods' started by Kume, Jan 25, 2014.
  1. Heck two years and a ride in a blender. Glad you came out on the positive side and making progress.... way cool and looking good.:cool::) JW
    Six Ball and Stogy like this.
  2. bct
    bct
    Right on.
  3. jvpolvere1
    jvpolvere1
  4. RussTee
    RussTee
    Project is looking good I will follow with interest have finally got my Rutherford head on the B motor running in the RPU have a chev conversion on a Tee motor in the roadster
  5. Kume
    Kume
    Made a little progress before xmas. Steering box mount just about sorted and rear hartfords mounted. Also found out Langs adaptor plates for Model T wooden hubs also fit chev hubs. Am using the rear hubs off 1928 chev disk wheel which have the same offset as Model T wire wheel hubs so the rear end is just about sorted. 02-IMG_2766sc.jpg 20161223_100021.jpg 20161223_100400.jpg
    Six Ball, brEad, Stogy and 7 others like this.
  6. The37Kid
    The37Kid
    That looks great! Could post a photo of the back side of the front Hartford shock? I have a set just like them that I plan to put on a T. Best wishes for 2017! Bob
  7. Kume
    Kume
    Thanks Bob
    I will take a pic.
    They are quite a heavy two bolt aluminium casting .
  8. Bigcheese327
    Bigcheese327
    I was planning this exact combo a few years back. I sold it all when I moved to Vermont, though. I'll be interested to see things progress!
  9. Kume
    Kume
    Thanks for the interest Bigcheese. Progress is slow but sorting lots of minor issues. Shortened Model A steering column and keyed to fit early steering wheel. Boxed section of ch***is for steering box. Thats about it but nearly ready to get ch***is certified. Just acquired some original leather seats from a late 30s Hudson that should look good in the ****pit.
    Still to sort headers for three port olds head. Thinking of a torque tube lake pipe if I can make it look right beside radius rods.
    Kume
    Six Ball, Lil'Alb, Outback and 11 others like this.
  10. MrModelT
    MrModelT
    How the HELL did I miss this thread!!????
    That looks FANTASTIC Kume! :D
    Sent from my SM-G900T using The H.A.M.B. mobile app
  11. tfeverfred
    tfeverfred
    I'm just glad to see this build get a "bump".:)
  12. Kume
    Kume
    Thanks Clayton
    Progress is frustratingly slow but hope to have some updates next week.
    Kume
    Six Ball, Stogy and MrModelT like this.
  13. That body looks familiar, did you get it off Trade Me a few years back? JW
  14. Kume
    Kume
    Jw
    I sure as hell didnt find it under a macrocarpa tree.
    Kume
    Sent from my SM-G930F using The H.A.M.B. mobile app
    Six Ball, chryslerfan55 and Stogy like this.
  15. I'd forgotten about this build, so it's nice to get caught up.
    I'll go hit the follow ****on, this is way to cool to miss the updates.
  16. Kume
    Kume
    T
    Thanks Jeff
    Hopefully some updates next week.
  17. Kume
    Kume
    A quick update after a little progress. Front end sorted including newly fabricated tie rod and steering completed (thanks Jodie). Just need to modify shock arm angles. Body on and ready to get ch***is mods certified - cross fingers. First time it has rolled on four wheels and am loving the stance at the mo - may raise rear slightly. Original recipe changed somewhat having ditched the whippet rad and using standard T a**** other changes that will become apparent soon. Rear brakes nearly sorted - using 1928 chev disc wheel drums on the rear to fit model t wires but adapter plate a little thick so some work needed there.
    Looks like a few T builds going on in NZ at the moment. 20170804_121227.jpg 20170804_121301.jpg 20170804_121832.jpg 20170804_121845.jpg
    Six Ball, Lil'Alb, chaddilac and 12 others like this.
  18. Wow! Looks kick***!
  19. Love it lots, that has the look for sure. mmmmmT's in NZ. :cool::cool: JW
  20. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Nice to get rolling. How far are you from having the engine run?
    Have you done anything about narrowing size of the pipes on the T rad?
  21. Kume
    Kume
    Hi Andrew
    I am not sure about radiator yet. My first inclination is to reduce the size of the top tank (take it back flush with the rad core) as the chev has a reasonably efficient water pump and doesn't need the thermo syphon effect so much. Or get a new rad fabricated. Either way pipes will need to match chev motor.
    My motor is ready to go - just need to fab an inlet manifold for the twin SU carbs and headers for the three port olds head.
  22. Kume
    Kume
    I know of at least 4 steel builds going on in North Island at the moment. ***ume lots of plastic ones as well but they dont count do they?
    Six Ball, Outback, Stogy and 2 others like this.
  23. We can be Steel Snobs, the others don't need to count.:rolleyes:o_O JW
  24. Anyone remember the saying, "gl*** is ****, steel is real".?
    There was a time when the only hot rodded Ts were mostly all gl*** down here, and I wished for more steel T bodied hot rods.
    Great to see more getting built.
  25. These cars are simple good fun
    Six Ball, Stogy, Kume and 1 other person like this.
  26. RussTee
    RussTee
    early br*** strongbergs are good carbs two on a homemade manifold like on my tee roadster go well and are about here in nz fitted on a lot of early cars
  27. Kume
    Kume
    Yes I wasn't thinking of Strombergs - remind me of my dads triumph TC.
    I have a Riley 9 with twin SU's and just love the look of them. esp the early br*** body ones.
  28. Kume
    Kume
    So a little progress with the T. Sometime ago I decided to french it. The inspiration is from the Montier Ts. So all accessories will be period french. E.g. Jaeger instruments, Marchal lights etc. Light position still needs some work - they will be closer together and lower I think. Closer look at the three port head shows completely different and more efficient internal inlet shape to chev heads. The rocker shaft pedestals are also much lower so moving them to accommodate 1 - 1.5 rockers should be straight forward. Some work to do on the T radiator top tank to make space for hose is underway. Am now going back through other T build threads to see how screen posts were chopped. I think just using the lower screen frame looks best so thats the next job.
  29. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    I’m looking forward to the rad modification.
    Have you got an exhaust manifold for that head?
  30. Kume
    Kume
    Hard to believe it has been nearly 6 years since I started this thread and 2 years since I last looked at it. A few other projects had pushed this one to the side. Decided on some additional mods to the engine (see chev 4 thread). Also changed rear backing plates and hubs to take 1928 chev brakes and Model A wire wheels. Still deciding on the radiator. wanted something different from the usual model T or whippet look. Am tending towards the one shown in the pic below. rad.jpeg
