Projects 1934 Ford PU Build
Discussion in 'Traditional Hot Rods' started by Jeff34, Jul 27, 2015.
  1. Jeff34
    Jeff34
    dumprat likes this.
  2. Jeff34
    Jeff34
    chop job, Jet96 and Tim_with_a_T like this.
  3. Jeff34
    Jeff34
    I got it lined up with the holes and it's in a good place. Trying to decide if I use as many of the old bolts as I have or just replace them. I also got the new pressure regulator. It's a bit too new for my tastes, so I'd like to hide it. Any ideas appreciated!!!
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    I'd replace with stainless bolts.
    On my 34, I ran the pump, filter and regulator along the frame rail near the tank.
    You rarely need to change adjustment.
    Jeff34 likes this.
  5. Jeff34
    Jeff34
    Dang. O.K. Bed coming back off...found a mounting spot. Need a couple more fittings. At least it will be hidden and the engine bay will look cleaner...
  6. Jeff34
    Jeff34
    Petejoe likes this.
  7. Jeff34
    Jeff34
    I also found and took picture of the serial number on the frame rail (left, near rear wheel) just so I have it. [​IMG]
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    I didn't think those early cars had the serial on the frame. Wow news to
    Me.
    Jeff34 likes this.
  9. Jeff34
    Jeff34
    Yup. Two places. One just forward of the cowl on the driver's side, and the other on the top of the frame under the bed. Not sure if it's the same for cars. This is for trucks...
    I had a hell of a time getting DMV to let me use my black plates. They wanted the VIN, but said that the "1" in the VIN (883I68) was an "I"...what idiots. Don't they know there was no "1", and that a cap I was used for the number 1??? Like a Roman numeral???
    Petejoe likes this.
  10. Great project!
    Jeff34 likes this.
  11. Jeff34
    Jeff34
    So I posted a picture of a bus that one of my neighbors owns...it was pulled. Somebody must have thought it was a joke. Here's the bus. I love the look and wish I had a place to store it. [​IMG]
    kidcampbell71 likes this.
  12. Jeff34
    Jeff34
    Since I replaced all the wiring, it only made sense to pull all the ignition wiring and replace that as well. The cap showed bad deterioration of the contacts, and the plug wires were stiff and brittle. Pulled the dizzy to send off to Bubba for reconditioning. Sending him the coil to test as well. I'll order new inner/outer cap rotor and wires to finish it off. This will likely take longer than I'd like, but I think it's the right thing to do [​IMG][​IMG][​IMG][​IMG]
    kidcampbell71 and Flowmeister like this.
  13. alchemy
    alchemy
    When you have Bubba replace the rotor and cap, have him install '42 parts. They are easier to use than the '48 style cap you currently have.
  14. El Hueso
    El Hueso
    Funny, we were staying in downtown Petaluma all last week visiting family. We went on quite a few walks around town. I must have p***ed that bus 3-4 times! Small world! I'm sure we must've walked by your place a few times. Great build by the way. I've been following along for quite a while.
    Jeff34 likes this.
  15. Jeff34
    Jeff34
    Ha! That's funny. We're a half block up the street from where the bus parks across from the old school. If you're in the area again, let me know...
  16. El Hueso
    El Hueso
    I'll be sure to do that next time! We come to town about 1-2 times a year. We have family over on A street between Keller and Liberty. Just a stones throw away!
  17. Jeff34
    Jeff34
    Here's a couple of shots of the dizzy and the ****ty cap I removed. Can't believe the thing actually ran[​IMG][​IMG][​IMG][​IMG]
  18. Jeff34
    Jeff34
  19. dumprat
    dumprat
    from b.c.
    Yikes is right. A lot of arcing going on.
    Jeff34 likes this.
  20. Jeff34
    Jeff34
    Yeah. Last variable is carburetion. I hope to send out my 97's soon
  21. Jeff34
    Jeff34
    Finally got my distributor back from Bubba's. Looks great! Got it back on last night. Hope to have it all back together and running this weekend. [​IMG][​IMG]
  22. Craig Owens
    Craig Owens
    Looking good! It should be in great running condition for this summer's activities.
  23. Jeff34
    Jeff34
    All back together. Crab style cap would have made this easier, but I like this look [​IMG][​IMG][​IMG][​IMG]
  24. Jeff34
    Jeff34
    Hmmm. So I drove the truck to the swap meet on Sunday...early. The lights worked when I tested them before, but they didn't work for the drive. Turns out the 20A fuse under the dash was blown (scratching head). Not sure why. Any ideas? All new wiring.
  25. Nobey
    Nobey
    You have a three brush generator on there Jeff, you might be over charging. What does your amp
    gauge say?
  26. Jeff34
    Jeff34
    Yup. I do have a 3 brush. Ammeter shows moderate charge when running, slight discharge when idling. Seems pretty normal. I can put an ammeter on it to see what it's actually putting out. Thanks, Nobey.
  27. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes check your generator with a meter.
    I'd guess you have dead short going to your lights.
  28. Jeff34
    Jeff34
    Didn't get a meter on it yet, but when I drove it this weekend I noticed that the fuel gauge would read correct at idle, but went up past full at speed...bad cut out?
  29. Nobey
    Nobey
    The other thing overcharging will do is melt your coil. Check the cut out and the third brush adjustment.
    Hope all goes well Jeff....
    Jeff34 likes this.
  30. Jeff34
    Jeff34
    Sure as hell don't want that. Skip just rebuilt it. What is this third brush adjustment you speak of?
