Technical The big banger and thinking out of the box!
Discussion in 'Traditional Hot Rods' started by volvobrynk, May 18, 2017.
  1. volvobrynk
    volvobrynk
    from Denmark
    Hey
    This may sound totally weird and boarder lining psychotic, but;
    Have you looked at the Fordson F engine for a hot banger? Or the N?
    The most noticeable difference is the 4 inch bore of the F and and 4.125 on the N and 5 inch stroke, for both.
    But it looks a lot like any other ford Banger, but bigger.
    And there is no replacement for displacement.
    It's Smokey-thinking applied for a different era.
    [​IMG][​IMG][​IMG]
    Ideas are welcome, and if it's dead in the water, feel free to shoot it down.
    120mm and Max Gearhead like this.
  2. Gofannon
    Gofannon
    You might want to look into the 9N engine. I wonder if a V8 head would fit?
    https://en.wikipedia.org/wiki/Ford_N-Series_tractor
    "The original 9N engine was a four-cylinder engine and was designed to be powered by distillate fuels. The engine shares the same bore and stroke sizes as one bank of the Ford V8 automobile engines. A few standard Ford auto and truck parts, such as timing gears and valve tappets, were used in this engine.
    The ford 9N engine was a side-valve, four-cylinder engine, with a 3.19-inch (81 mm) bore, 3.75-inch (95 mm) stroke, providing a displacement of 120 cubic inches (2,000 cm3)."
    lothiandon1940 and volvobrynk like this.
  3. studebakerjoe
    studebakerjoe
    It's nice to see Im not the only one who has looked at the Fordson engine for a hopped up banger.
    120mm and volvobrynk like this.
  4. stillrunners
    stillrunners
    from dallas
    have had the 9n/8n tractors along with a B or 40/41 truck motor....just don't see why not !
  5. mohead1
    mohead1
    Interesting
    Sent from my SM-G900V using Tapatalk
    volvobrynk likes this.
  6. volvobrynk
    volvobrynk
    from Denmark
    I'm a little ashamed to say, I completely forgot 8N and 9N, despite my farther had on when I was a kid.
    There is so much more power parts to be had for the Ford A banger, I doubt there is many advantages of going down in displacement?
    The whole Idea was going for higher displacement, and beat a hot banger with a big banger, and have them come over and look at it and scratch there head becaude they look at a Ford casting with an Aluhead, a Volvo Distributor and a Stromberg, just like there own and go "why the F is he that fast", in this case F is the answer [emoji12]
    And if a wanted a good 2 liter, I would have slapped a Volvo B20 in that puppi and never looked back.
  7. volvobrynk
    volvobrynk
    from Denmark
    @Dannerr, do you think this would be something for Craig? [emoji41][emoji2]
    I can't remember is handle.
    I would love to donate a Volvo Distributor, a coil, two SUs and help source a good block.
    And I got a superb idear for some Nimbus style pressurized oiling, I been dreaming to live out.
    I'm a good welder, and I can fabricate.
    Us three lads can make it happen.!
    Imagine this but bigger! [​IMG]
  8. plym_46
    plym_46
    from central NY
    Recently on the local c list, there was a listing for a 40 ford pick up powered by a 4 cylinder engine. The info said it was one of a few produced and noted the engine was based on the tractor engine.
    Dannerr likes this.
  9. sloppy jalopies
    sloppy jalopies
    memory says 8n tractor valve train parts interchange with flatties
  10. Tim
    Tim
    from KCMO
    They bolt v8's into the tractors regularly so I'd ***ume putting the tractor motor in front of car drivetrain wouldn't be super hard
  11. BCCHOPIT
    BCCHOPIT
    You need to look at the ports...
    will they flow and can the cam be ground into something more suitable for racing around town not plowing the Fields.
    Displacement doesn't mean anything if you can't get some RPMs out of it. Then you need to start thinking about compression and if it's anything like a model A head you can't mill much off with out getting into the water jackets
    Not saying it not going to work or it's not cool if it would work out.
    Just giving you something to think about
    Kedde and volvobrynk like this.
  12. 28dreyer
    28dreyer
    from Minnesota
    This was a common engine used in midget race cars starting pre-war and continuing post war. Much speed equipment was available. They were called Ford Fergusons or Fergies but that terminology came from the hydraulics on the tractor and had nothing to do with the engine.
    Babe Stapp was one of the proponents of this engine and built speed equipment including a dry sump system.
    ThompsonFergie2.JPG ThompsonFergie3.JPG ThompsonFergie4.JPG ThompsonFergie7.JPG
  13. Not at the moment, he's going another route (accros the atlantic, to be exact). But I've been thinking about it too, especially since I was by my stepdad weekend before last - he had his '49 gasoline Fergie started up. ;-)
    @28dreyer, which engine is this? Out of the 8n or Fordson?
    Kuul looking either way! :-D
    m&s rodz likes this.
  14. flyin-t
    flyin-t
  15. volvobrynk
    volvobrynk
    from Denmark
    To me, and at first glance, ports look the same as the model A and the Model F and N.
    I have no clue about how much different the internals are, but my knowledge of Mr Ford thinking; the solution was to KISS, all the way for Ford.
    He just made everything bigger, change casting and machine work and then full steam ahead on production.
    And regarding cams, I have no idea if it shares much with the Model A, since it made max power from 1000rpm, and peaked at 1500-1800.
    And regarding head, to bump compression, we could weld the head?
    BCCHOPIT and Dannerr like this.
  16. volvobrynk
    volvobrynk
    from Denmark
    A few pics of another one[​IMG][​IMG][​IMG][​IMG][​IMG]
    He might have changed some items
  17. 28dreyer
    28dreyer
    from Minnesota
    Kuul looking either way! :-D[/QUOTE]
    This is the 122 cu. in as used in the 4N, 8N, and 9N I believe.
    volvobrynk and Dannerr like this.
  18. studebakerjoe
    studebakerjoe
    Volvo up until 1920 that fordson engine was from hercules so it has more in common with other hercules engines than the A. In 1920 Ford started making their own engine but it was only slightly different than the previous Hercules.
  19. volvobrynk
    volvobrynk
    from Denmark
    Okay I have no clue what a Hercules engine is, but the F and N is later then the A and B.
  20. boo
    boo
    from stuart,fl.
    Volvobrynk, funny what you said...few years ago i entered my 29 -A in a hill climb, my buddies talked me into entering, i won my cl***,stock looking eng, a man i beat came over and looked at my car and said ''i don't kno how you beat me because i kno i'm cheating'' HaHa
  21. RichFox
    RichFox
    The distributor location is certainly different from an A-B Ford. Which means the cam is also different.
  22. patmanta
    patmanta
    from Woburn, MA
    I had a flight of fancy down this rabbit hole briefly last year and would love to see it done. I think a little T body or a single seater would be ideal.
    m&s rodz and volvobrynk like this.
  23. treb11
    treb11
  24. RichFox
    RichFox
    It is something I wonder about. There are lots of air cooled engines running around that are OHV. A flathead, such as this, has no or little exhaust heat in it. So why couldn't you make an aluminum head without water jackets? Like the bronze heads made for Ford V8 engines, years ago. It is a lot easier to make a head without water jackets. You could still run water out from around the exhaust valve through the head and help with cooling the head. I know for a fact you can warm an engine to 180 degrees and then make a full throttle p*** 3 miles long with such a set up and no ill effects. Never tried it on the street, but lots of motorcycles do.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
