Hot Rods Fixing a mangled 33 Chevy coupe body UPDATE 31/10/21
Discussion in 'The Hokey Ass Message Board' started by 66gmc, May 22, 2017.
  1. 66gmc
    66gmc
    I picked up a rough 33 chevy last month and figured I would make a thread to update as I progress on it. I will be doing all the metalwork on the body, replacing the wood with steel, chopping it, channeling it, and doing a few other minor modifications. When I went to pick it up it was below freezing and rain/snowing out. I ended up spending 2 hours laying in the muddy field cutting the fenders and running boards off so it would fit in the back of my half ton. Luckily the seller helped lift it into my truck with a tractor, however when I got home I had to get a little creative unloading it by myself. 141.jpg
    hipster, T-roaster, triman62 and 19 others like this.
  2. 66gmc
    66gmc
    i started by squaring up the frame, then pushing pulling and beating on the body to get it back to where the doors lined up to the bodylines. I screwed the doors shut temporarily and then added some temporary bracing inside the body. Once that was done I channeled the body over the frame. It took a couple trys to get it to sit exactly how i wanted it.
    Next I turned my attention towards the back of the car. At some point in the past a farmer had completely mutilated the back of the car to install a home made truck box.
    hipster, T-roaster, triman62 and 25 others like this.
  3. fordor
    fordor
    from Finland
    Watching.
    I like to follow projekt like this.
    Peter
    hotcoupe likes this.
  4. 66gmc
    66gmc
    I built a subrail ***embly from 2x1 tubing that matches the contour of the frame. Then I beat the remains of the 1/4 panels back into shape so that I could make a pattern. After that I built new rain gutters for the trunk opening. Next I welded the rain gutter ***embly into the upper trunk opening, and added some more temporary bracing.
  5. 66gmc
    66gmc
    I built new upper 1/4 panel sections for both sides yesterday. I build everything with caveman hand tools and a cheap english wheel.
    2Blue2, reagen, -Brent- and 31 others like this.
  6. manyolcars
    manyolcars
    wow! go git'em!
    Stogy likes this.
  7. Wow, great way to kick a new thread off, straight into the guts of it. You'll probably have it done by the time I finish typing this post.
    Nice work, great seeing a good car saved from field life.
    Stogy, hipster, 302GMC and 3 others like this.
  8. The37Kid
    The37Kid
    Nice project, very impressed you did all that in a month. Bob
    Stogy and 66gmc like this.
  9. 66gmc
    66gmc
    Today I spliced the upper 1/4 panel sections into the 1/4 panels and tig welded them in.
    Then I started roughing in the tail pan. I dont like the way the bottom edge of the chevy tail pans and 1/4 panels look cut off when they are fenderless. To solve the problem I will be doing a raised bodyline similar to the back of a 33-34 ford coupe.
    Thanks for looking, I will try to update as progress happens.
    reagen, -Brent-, wraymen and 31 others like this.
  10. scotts52
    scotts52
    Very nice. Considering the wood framing, that car seems to still be pretty solid.
    Stogy likes this.
  11. belair_54
    belair_54
    from australia
    Nice car I regret a little selling my 3 window 1933 chev master coupe it was a beautiful looking car all original. Having also built a 1934 Standard Chev Roadster hotrod I know how muck work is involved in replacing the wood your doing a great job.
    What frontend are you using ? I like the look of the original 2 leafspring I beam
    Stogy and hipster like this.
  12. 56 Dodge Pickup
    56 Dodge Pickup
    Definitely impressive I'm subscribed! Can't wait to follow this build! Hobo Jim
    Stogy likes this.
  13. Elvis100
    Elvis100
    Stogy and choptop40 like this.
  14. southcross2631
    southcross2631
    My first Hot Rod was a 33 Chevy 3 window coupe body that I put on a shortened 49 Chevy frame with a 55 Olds drivetrain. The original motor and frame was used to power a saw mill.
    It was fun until my mom came home from work and caught me doing burnouts in the highway and told me to get rid of it. So I traded for a 50 Ford business coupe and put the olds stuff in it. She was happy because it had fenders and mufflers. I was 16 at the time.
    Stogy, hipster, 302GMC and 1 other person like this.
  15. Chucky
    Chucky
    That photo with it stuffed in the back of your truck! Excellent!
    Stogy, JD69, mgtstumpy and 17 others like this.
  16. aussie57wag
    aussie57wag
    from australia
    Stogy likes this.
  17. Looks good !
    Stogy likes this.
  18. tb33anda3rd
    tb33anda3rd
    nice work. the world needs more chevy coupes!
    Stogy, kidcampbell71, hipster and 8 others like this.
  19. wheeldog57
    wheeldog57
    Stogy likes this.
  20. Król
    Król
    Excellent metal working skills, very impressed. Keep going will be following.
    Stogy likes this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    Nice work,the early termite Chevys make beautiful cars but they make you work hard to see the final beauty,We built one and that's enough for me.
    Stogy, Fern 54 and Atwater Mike like this.
  22. Watching
    Stogy likes this.
  23. 31Dodger
    31Dodger
    Stogy, kidcampbell71, reagen and 10 others like this.
  24. I thought I was the only one Krazzy enough to start with a wadded up Tin Can nailed to a Wood crate. Clearly this isn't your First go at this stuff. Right on, I like your work. I'll tell ya the Biggest lesson I learned while building the steel inner structure on my 34 2d sedan. Over the years these old Chevy's started to List and Sag as the wood aged. A door in the Hole don't mean your good to go. I ended up with a good bit of redo on mine after I learned just how much out of shape it really was. I ended up with adding 3 string lines through the body on center line so I knew where the center of the floor was in relation to center of the Body at the belt line as well as center at the roof line. That made everything come back together. Heck, they may have been built out of Wack.
    This photo was taken the first time it looked like a real car. Still a long ways away from actually being one.
    The Wizzard
    Stogy, vtx1800, reagen and 16 others like this.
  25. The 39 guy
    The 39 guy
    Certainly not a project for the average builder! Hope all continues to go well. I'll be watching.
    Stogy likes this.
  26. 32 hudson
    32 hudson
    I am subscribed, great start on the build.
    Stogy likes this.
  27. Max Gearhead
    Max Gearhead
    from Wisconsin
  28. sololobo
    sololobo
    My avatar shows me at 15 next to my 33 Chevy tu-door, mine was 27k original one owner to start with. You are very skilled and very very brave. Rock on brother, will be watching this cool project.
    Stogy, 302GMC, kiwijeff and 1 other person like this.
  29. Wow! Nice work!
    Stogy likes this.
  30. Bugguts
    Bugguts
    Subscribed!
    Love watching the resurrection of old tin!
    Stogy likes this.
