Hot Rods Disc brakes & wide five wheels?
Discussion in 'The Hokey Ass Message Board' started by pete @ occhiolungo, May 22, 2017.
  1. pete @ occhiolungo
    pete @ occhiolungo
    from ca
    Has anybody put wide five wheels and disc brakes onto a 37-48 Ford? How much did it increase the track width of the front end?
  2. gimpyshotrods
    gimpyshotrods
    Who's kit are you using?
  3. gimpyshotrods
    gimpyshotrods
  4. pete @ occhiolungo
    pete @ occhiolungo
    from ca
    I bought the narrowest kit (from Magnum), but it still adds 1/2" of width compared to stock 37-39 drum brakes. Plus the Wide Five adapter is 1/2" so my wheels each moved out 1".
    Has anybody else used disc brakes and Wide Fives? Did you modify the wheels to have more backspacing? Or did you leave them stock, and did that affect the steering performance by having the tires moved outboard?
  5. scrap metal 48
    scrap metal 48
    Part of the beauty of the wide fives is NO hubcaps and the smooth drum showing through...**clic pic for larger image** 100_0245.JPG
  6. pete @ occhiolungo
    pete @ occhiolungo
    from ca
    Agreed S**** Metal 48, they do look good. But I figured that someone before me had used them with front disc brakes? Surely it has been done by somebody?
  7. cvstl
    cvstl
    from StL MO
    What axle? Is it dropped and narrowed, or a narrowed, dropped new axle? If so, your not likely increasing track width much over stock.
  8. pete @ occhiolungo
    pete @ occhiolungo
    from ca
    I'm using all the standard 1937 Ford parts except the new disc brakes. The difference between new disc brake hubs and the old 37 brake hubs is 1/2" per side, plus 1/2" per side for the wide 5 adapters. So the track width increases 2" total.
  9. cvstl
    cvstl
    from StL MO
    20160917_111023.jpg Chris Haggerty.... KingHag on here is running them on his dad's 39, but it's a dropped, narrowed axle.
  10. pete @ occhiolungo
    pete @ occhiolungo
    from ca
    thanks! I'll find him and ask about the steering effort. It seems that it should be a bit harder to steer with the tires moved away from the kingpin. But the narrowed axle does keep the track width ok.
  11. cvstl
    cvstl
    from StL MO
  12. Dino 64
    Dino 64
    from Virginia
    Really nice coupe. Starting to warm up to that unchopped look.[emoji41]
    scrap metal 48 likes this.
  13. 55willys
    55willys
    jimmy six likes this.
  14. koolbeans
    koolbeans
  15. nobby
    nobby
    split screen van wide 5 disc
    afterall, the vw is a 37 ford - runs and hides
    205mm pcd = 8 inches
    will have m14 -1.5 studs
    outer bearings a 3/4 - 19.05
    dont matter on inners as you can fabracobble that
    jim32 likes this.
  16. Work4it
    Work4it
    This is what I did, it is not an answer to your question but I thought I would share. I wanted the complexity of the wide five look but did not want to use the flat adapters and did not want to try and come up with a method for using wide five drums on a modern rear end, (I am sure there is a solution there).
    These are from the second set I had cast at an aircraft part producing foundry in the NW. They are cast out of A-356 aircraft grade aluminum, heat treated and I machined them on a milling center.
    I have had a set of the first casting run on a 31 sedan a friend of mine built for several years. He has put a bunch of miles on them in some of the roughest roads in the NW.
    I designed them to take on the utilitarian look of racing parts from the past, I love the early Halibrand parts. I started of the design thinking I was going to machine them from billet but I kept going back to the cast look, something that is unmistakably traditional. I was going to try and sell some to offset my costs, and there were plenty, but the company I worked for shut my division down and I had to start a new career, so the project got back burnered.
    I almost did not post this because it does not really help you, but maybe there is some interest in an offering like this.
  17. Work4it
    Work4it
  18. Work4it
    Work4it
