Projects "Pea Green" the '29 Tudor build
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Sep 14, 2014.
  1. '52 F-3
    '52 F-3
    from Central PA
    not the best beginning of the week....... one step forward and two back
    the only thing crazier than my parking brake cables mounting bracket is how I mounted it. I'm pretty sure it'll work fine, backup plan is to mount bracket to bottom of the body. also the paint dried terrible, due to me hurrying to get done.
    but then I was trying to set my pinion angle and found I had an issues. Basically I couldn't lengthen the upper rods and shorten lower because it would bend leaf spring un-naturally. So to rotate pinion up a couple degrees I lengthened upper rods a little bit and lower rods a little more. Well I ran out of adjustment on lower rods, so I cut 1/4 inch off the rod and put tie-rod back in...........
    So it started good but soon got snug, I then used a wrench to turn in (I know, big mistake) when it got too tight I decided to back out, well it got tighter...... after loosening/tightening a couple times I knew I was screwed. I then heated rod with a torch to expand tube and back out tie-rod, yeah.... that didn't work. I heated up more and tried more, then slightly bent end of rod, so I said **** it and torched it off. Finially I called it a night.
    Stogy and loudbang like this.
  2. 340HilbornDuster
    340HilbornDuster
    Hi Gregg
    Parking Break Blues:
    I'm in the same boat as you...
    I'm working on a "Grooved Ball Bearing - Extended Cables Something Something" on my Tub...
    Not really there yet...
    I Also Wish I thought it out B4 I painted it all...
    ...I guess that's called learning?
    Thought?
    Your nice Rubber Bracket Exhaust might move around when you pull the brake handle?..
    Maybe it doesn't matter that much?
    Build Do***entation:
    $#!- Happens when you build stuff (It's not all just Perfect Welds...)
    Thanks for keeping it real and showing the real "Progress"!
    Keep Pounding Man!
    Tim_with_a_T and loudbang like this.
  3. '52 F-3
    '52 F-3
    from Central PA
    I hear that.....
    got my brake lines finished, fixed leaks and bled, have a pretty hard pedal.....
    finishing adjusting suspension and steering links. plan to final tighten and cotter key soon.
    also painted shocks in my "outdoor booth", plan to do a little pinstripe type painting next.
    Stogy, loudbang and brEad like this.
  4. brEad
    brEad
    Just keeps getting better and better with each post. Thanks for sharing.
    '52 F-3 likes this.
  5. '52 F-3
    '52 F-3
    from Central PA
    Happy Easter............ done little shock decorating
  6. 340HilbornDuster
    340HilbornDuster
    Very Cool!...........Or maybe Shocking!
    Happy Easter to You!
  7. brEad
    brEad
    Nice!
    '52 F-3 likes this.
  8. CURSED GEARS
    CURSED GEARS
    Easter shocks! I like it! They must have looked pretty laying there on the green gr*** in the basket!
    loudbang and '52 F-3 like this.
  9. '52 F-3
    '52 F-3
    from Central PA
    acorn nuts for headlight mounting.
  10. brEad
    brEad
    I can't wait to see those mounted up!
  11. '52 F-3
    '52 F-3
    from Central PA
    Rex wanted to see too, but it was hard for him to get a good look because he's only 1 ft. tall.
    Stogy, kidcampbell71 and loudbang like this.
  12. YJ4000
    YJ4000
    Very nice detail!! I really enjoy your project. Thanks for taking the time to show us.
    Ryan.
  13. brEad
    brEad
    Very nice. Are you now thinking about doing that to the rest of the bolts/nuts?;):)
  14. Dean Lowe
    Dean Lowe
    All that work and you use a common old black washer? ;)
  15. '52 F-3
    '52 F-3
    from Central PA
    I might make a couple more "Acorn" nuts to use in interior or air-cleaners, but done for now.
    Am trying to use as many "Castel" nuts with cotter pins as possible.
    Good eye Dean; I didn't have a stainless lockwasher that size. I just wire wheel'ed a regular one and clear painted it like I do for most nuts and washer.
    thanks for replys/compliments.
    few detail pics of cotter pins.
    20170429_084546.jpg 20170429_085849.jpg 20170429_085938.jpg 20170429_092111.jpg
  16. brEad
    brEad
    Whoa! How did I miss the fluted steering parts post? Another nice detail!
  17. '52 F-3
    '52 F-3
    from Central PA
    swapped around a few parts on a couple 2G Rochester carbs. Looking for some fitting/fuel lines and hoses now. Also considering making an air cleaner ***embly, but might just go with 2 fishmouth scoops.
    juan motime, Stogy, brEad and 2 others like this.
  18. '52 F-3
    '52 F-3
    from Central PA
    finally ****ed it up and bought a nice radiator, also routing on fuel, trans cooler lines and spark plug wires using 55/56 Chevy separators/looms. Also need to get the body back on for firewall clearance checking before going much farther.
    juan motime, brEad, Hotrodmyk and 3 others like this.
  19. '52 F-3
    '52 F-3
    from Central PA
    the fan I planned to use didn't leave enough clearance with new radiator but an 18" semi-flex low profile fan did.......(but there is no way anything blue anodized in going on this car.......)
    So some Oven Cleaner, br*** brush, Scotch Bright pad, buffing wheel/polish, tape and Green paint made it a lot better and now have 7/8"ish fan/radiator clearance.... (will only consider a shroud if I have cooling issues)
    20170614_161606.jpg 20170614_164813.jpg 20170614_171617.jpg 20170614_174634.jpg 20170617_103941.jpg
    Also after hours of think and making air cleaner templates i didn't like, I found these for a great price on ebay........
    Stogy, brEad, Hotrodmyk and 3 others like this.
  20. loudbang
    I'm GREEN with envy LOL :rolleyes:
    '52 F-3 and Just Gary like this.
  21. brEad
    brEad
    Well done!
    '52 F-3 and loudbang like this.
  22. '52 F-3
    '52 F-3
    from Central PA
    with my starter mounting ring adaptor, neither a Powerglide or TH350 torque convertor dust cover fit, so I had to ruin both of them to make one. Not pretty but will work....
    Stogy, brEad, loudbang and 1 other person like this.
  23. brEad
    brEad
    Once you put that "Pea Green" magic touch on it, it will look great.
  24. '52 F-3
    '52 F-3
    from Central PA
    slow progress, but did get flexplate cover finished and am about done routing cooler lines. also verified timing and finished sparkplug wires.... starting to dream about first startup
    brEad, Tim_with_a_T, loudbang and 3 others like this.
  25. 340HilbornDuster
    340HilbornDuster
    The Green & Brown combo [emoji106]
    Paisley drain holes [emoji106]
    Lotso COOL Details [emoji106]
    Almost there [emoji106]
    Sent from my SM-G900V using The H.A.M.B. mobile app
    brEad, '52 F-3 and loudbang like this.
  26. Fabber McGee
    Fabber McGee
    What? No paisley holes in the trans pan? Better paint 'em on, ha,ha. Great job man, I'm loving it.
  27. Fabber McGee
    Fabber McGee
    Seems like GM used to have some little tin clips that snapped over trans cooler lines to hold them 1/4 inch or so apart and keep them from rubbing on each other. Might be a nice little touch to keep them exactly parallel.
  28. Fabber McGee
    Fabber McGee
    Hadn't noticed the green plug wires, really cool detail.
  29. '52 F-3
    '52 F-3
    from Central PA
    that's great idea, thanks.
    I'm going to find some...
  30. '52 F-3
    '52 F-3
    from Central PA
    I was looking for some tubing clamps and remembered what was used years ago when working on helicopters. Phenolic material: it holds up to oil/fuel, non conductive and don't transfer heat. it's the same thing used to make carb spacers and I have some.
    this might be the start to what could become a time consuming idea. I could use in other areas for tubing and wiring securing.
    Drewfus and loudbang like this.
