Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Fiddle Picker
    Fiddle Picker
    New weight breaks for you fuelie guys. I'm still waiting to see how Quain is going to settle the old style intake rule. Hope he lets us shed another 50. Or, 100 more would really get the wrenches flying!!
    Dog_Patch and loudbang like this.
  2. Higgy's Henry
    Higgy's Henry
    Now if your at the cl*** minimum...do you still get the weight breaks?!!
  3. Bad Banana
    Bad Banana
    Yes. For example I am 427 cubes. 427 x 8 = 3416. I can weigh 3216 since I am fuel injected. The smaller the engine the more percentage of the total weight it is.
  4. Higgy's Henry
    Higgy's Henry
    What I'm saying is that the cl*** minimum in C/G is 2500lbs. You wouldn't get that 200lbs if the Bad Banana was already at the cl*** minimum, right?
  5. Bad Banana
    Bad Banana
    Ahhh.. I see. My bad. That would be a Quain question but I think you are right.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  6. Fiddle Picker
    Fiddle Picker
    I had that conversation with Quain about mine. You can go below the minimum if your engine size lets you. Example, and this came from Quain, I will be running D/Gas with 306 cubic inches at 10 pounds per cube would be 3060. With iron heads -50 and old style intake -50 my car would be legal at 2960 even though the minimum for D/Gas is 3000 lbs. He admits the rule is a little confusing, no need to double penalize for a small engine.
  7. Dog_Patch
    Dog_Patch
    Ha! I'm 100 lbs heavy right now. That's a tough one finding 100 lbs to cut out. :confused:
    The heads are well oiled and pretty clean
    loudbang, allwilly, Tudor and 3 others like this.
  8. Higgy's Henry
    Higgy's Henry
    Whew!! Lots of work going on between races!! I had to burn the midnight oil myself
    Before....
    And after...
  9. between the bottom two cylinders there seems to be a oil pattern coming from a stud hole. is this possible the cause.
    mad mikey and loudbang like this.
  10. Tudor
    Tudor
    from GA
    I think you are referring to this splotch of oil on the head??
  11. Dog_Patch
    Dog_Patch
    That's oil from my experiment. I removed the rockers and pumped the oil to see how much was coming up through the head. Then removed the head and also pumped it to see if the cam bearing had rotated and blocked the oil p***age. I'm actually surprised at how little oil is coming up there. Its not blocked - the cam just p***es by the hole briefly so there isn't a lot of flow.
  12. dirty old man
    dirty old man
    When you see a piston with carbon in the center and practcally clean around the edges as we see in this engine you can be fairly certain the oil is getting past the rings and washing the edges so heavily that the carbon is in the center and almost none around the edges, just sorta stained.
  13. saltflats
    saltflats
    from Missouri
    The good news is you can hone the cylinders now.
    The Grump found some H/P when he re honed after the engine was run in.
    mad mikey, loudbang and Dog_Patch like this.
  14. Dog_Patch
    Dog_Patch
  15. allwilly
    allwilly
    Dog_Patch, Floater03 and loudbang like this.
  16. Higgy's Henry
    Higgy's Henry
    Looks like a kill room!!! :confused:
    Hatchet, mad mikey, loudbang and 2 others like this.
  17. glrbird
    glrbird
    I think Higgy watched too much Dexter!
  18. Dog_Patch
    Dog_Patch
    Hmmmm this could come in handy ....
    Love that show. Funny the connection never occurred to me though.
    Last night Jack shows up and wants some Hoosier Slicks mounted :rolleyes:
    The press seemed like an easy task - but no it didn't work.
    Motorcycle s****s did the trick.
    After the big hone job, got plenty of help from the crew.
    Hatchet, Floater03, catdad49 and 7 others like this.
  19. Dog_Patch
    Dog_Patch
    Smoke or not ...... thanks Higgy for the illegal smoke :D
    catdad49, brEad, Floater03 and 6 others like this.
  20. Higgy's Henry
    Higgy's Henry
  21. pigfluxer
    pigfluxer
    Balls to for the walls......
  22. enloe
    enloe
    from east , tn.
    loudbang, Dog_Patch and saltflats like this.
  23. Dog_Patch
    Dog_Patch
    Yeah some people we know bought her for Christmas and decided she was too much trouble so like most things without a home, ended up here......
    Hatchet, powrshftr, loudbang and 5 others like this.
  24. dirty old man
    dirty old man
    I don't think Enloe is referring to the pup dog Tony!:)
    Hatchet, loudbang and enloe like this.
  25. Dog_Patch
    Dog_Patch
    Still applies I guess :rolleyes:
    When I met her my friends said "Notice anything weird?" I'm like "She has a freeze dried cat" They said it was a red flag ....... but damn that thing is handy - keeps the birds from nesting in my bolt box.
  26. saltflats
    saltflats
    from Missouri
    Damn Tony....You are just too much.
    You going to be at the Meltdowns..... it would be good to chat again.
  27. So Tony, does that make your home the Island of Misfit Toys?
  28. allwilly
    allwilly
    Moreover a home for strays n wayward animals. ..not to mention the occasional wisconsiner. ..
  29. Dog_Patch
    Dog_Patch
    I hope so - not sure about dragging the car though. Might do a Banzai run up with Gabriel or something.
    That cute blonde vet tech has been sleeping in your bed lately ;)
    loudbang, Gammz, mad mikey and 2 others like this.
