Hot Rods A catastrophic failure
Discussion in 'The Hokey Ass Message Board' started by deucendude, May 29, 2017.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    I think Stimpy has it figured out. Should have used Ford rods.
    X38 likes this.
  2. Gray Ford
    Gray Ford
    from Illinois
    It might be my imagination, but the residue in the pan, ( not the broken parts), looks awfully "dark" or "dirty" for only having traveled approx 50 miles....As others have asked, was the pan removed prior to the install?? Are there any other signs of contamination in the engine ?
    alanp561, 54vicky, 117harv and 3 others like this.
  3. bobss396
    bobss396
    I saw that too, possibly some coolant got into the pan along with the carnage.
  4. Fordors
    Fordors
    It's a valve lifter, and BTW, that looks like a Ferguson Ardun Enterprises head in the photo. That certainly is not in any way to imply Ferguson was responsible for the failure.
    I recall "crab nuts" on EMD 710 ( cubes per cylinder) locomotive engines that came into the plant with inspection certification from the manufacturer, yet were pulling threads when torqued. Crab nuts clamp power ***emblies (individual cylinders) to the block and take 1600 ft lbs to fasten properly. Inspection checked them with their thread gauges and pronounced them good, so I went to a band saw and cut one in half showing the half formed, jagged threads.
    Along similar lines there was a rash of aluminum top fuel rods 15 or so years ago that had faulty threads, yet they showed good with a thread gauge.
    It can happen, and sometimes does even with thorough inspection procedures.
    loudbang and stillrunners like this.
  5. Rand Man
    Rand Man
    Dark oil is likely overheated oil. Most mechanical failures are lubrication related, either the primary cause, or as a result of "x" the lubricant didn't work. On an engine that sat un-used, I have seen the ***embly lube fade away from some critical parts. Also, priming the engine before first starting is very important.
    On a blown engine. You have to suspect detonation. Didn't sound like much boost. Was that level actually proven, or is that what it "should be" for that combination? Was the camshaft a common blower grind? Maybe it had a bit too much overlap, etc. spark timing and/ too low octane fuel are also killers.
  6. dreracecar
    dreracecar
    from so-cal
    contact Don Ferguson , its not like he has sold 1000's of these head kits and may have a record on who built it , at least then you can start getting answers
    loudbang and kidcampbell71 like this.
  7. Rand Man
    Rand Man
    Also, the static compression ratio is critical on a blown gasoline engine.
  8. squirrel
    I'm curious how all these things about the blower, could have anything to do with the rod bolts coming out? :)
    The37Kid, Montana1 and bobss396 like this.
  9. woodz
    woodz
    Really sorry to see this happen. You seem a lot calmer than I would be if this happened to me.
    If I blow up the pic you posted, I can see the ends on the connecting rod bearings. One end on each bearing half is worn very thin and burned. This says to me that that bearing spun due to a lack of lubrication. JMHO.
    Good luck. Hope you get it sorted out and back on the road soon.
  10. Rand Man
    Rand Man
    Detonation/extreme cylinder pressure does crazy ****. I'm saying the wrong combination in a blown engine can cause it to literally shake itself apart.
    loudbang and PunkAssGearhead88 like this.
  11. Johnboy34
    Johnboy34
    from Seattle,Wa
    For not having it very long, sounds like you did what anyone else would have. Being done quite some time ago you would think it was dependable, maybe the PO treated it a little different than he led on! Good luck on your investigation, please keep us posted on your results as they unfold.
  12. B.A.KING
    B.A.KING
    YEP ROD BOLTS ARE OUT. WE BOUGHT A SBC THAT HAD SET FOR ABOUT 7 YRS, GOT IT RUNNING. IT LASTED ABOUT 10 HRS. WASHED OUT CAM/LIFTER. WHAT WE FIGURED WAS THAT ENGINE BREAK IN OIL/LUBE HAD RAN OFF OF EVERYTHING WHILE ENGINE SAT IN GARAGE.
  13. Muttley
    Muttley
  14. Engine man
    Engine man
    from Wisconsin
    I would look at the threads in the rods. Compare how far in the bolts should go with how deep any threads that pulled out are.
    I suspect that the bolts came loose. The bearings appear to have been pounded from too much clearance. The pounding on the bearings put extra stress on the threads causing the bolts to pull out. Checking thread depth might show if the bolts were loose or there was just too much clearance. It's possible that they were overtorqued and damaged the threads. I like bolts and nuts. It's pretty much impossible to tell if the threads in the rods are compromised. If they are used more than one time it can be a problem.
    loudbang and leadsled like this.
  15. Bruce Lancaster
    Bruce Lancaster
    The odd item you are referring to in post 29 is a lifter...described usually as "bottle type."
    The snout ends in a cup for the bottom of the pushrod. Lifter is very long to get the pushrod to an angle that will get it upstairs without interference. Engine obviously rejected the pushrod, noting it as a foreign object...
    97, loudbang, camer2 and 3 others like this.
  16. woodbutcher
    woodbutcher
    :( Oh Lord.What a mess.Hope those Ardun heads are ok and reusable.
    Good luck.Have fun.Be safe.
    Leo
  17. kb cookout
    kb cookout
    Check and see if the front ( behind the timing gear) or rear oil gallery plugs were left out of the block, if left out they while wipe out the main bearings in less then 100 miles
    later kb
  18. Bleach
    Bleach
    I think I see bits of a grenade...
  19. ronnieroadster
    ronnieroadster
    Import parts rods and crankshaft could be the cause of the failure but only 6 pounds of boost they should have held up to at least that. Good original Ford and Merc parts will withstand at least 10 pounds of boost with an Ardun set up I know from daily experiance.
    Another area of concern is a reground cast cam if that gave out first everything else becomes junk. To me it looks like the cam may have broken then the big parts got in the way of the rods and so on.
    Hendee, loudbang, scruff and 4 others like this.
  20. gimpyshotrods
    gimpyshotrods
    That should buff right out.
    5window and '49 Ford Coupe like this.
  21. flatheadpete
    flatheadpete
    from Burton, MI
    It's like a horrible car crash...you don't want to look but you have to. And then you look even closer to find out what happened. Good luck. I think a little bit of every real hot rodder on the HAMB died when you ARDUN did.
    kiwijeff likes this.
  22. seb fontana
    seb fontana
    from ct
    I thought, "nice rocker arms".
  23. JC Sparks
    JC Sparks
    from Ohio
    There is a rod bolt still in the cap. Boost, detonation and all that other **** had nothing to do with it. It either spun out or the threads were pulled out when it was torqued. You need to check the other rods for correct torque. This problem started at the bolt. JC
    PhredH, slack, loudbang and 1 other person like this.
  24. Ebbsspeed
    Ebbsspeed
    Do I see a coil spring of rod material wrapped around this rod bolt?
  25. woodiewagon46
    woodiewagon46
    from New York
    Ebb, it could be aluminum from the rod. looks like the bolt just pulled out.
  26. hotrodyankee
    hotrodyankee
    Sorry that happened!
  27. seb fontana
    seb fontana
    from ct
    Sure does look like the bolt threads are full of something, rods are steel so maybe not enough thread depth or over torque?
    Unkl Ian likes this.
  28. chiro
    chiro
    I'm sorry for your loss.
    Andy
  29. fordflambe
    fordflambe
    Probably would have been much more enjoyable if you would have been rompin' on it.......
    Flatblack 31 likes this.
  30. seb fontana
    seb fontana
    from ct
    Thats a fact.
