Technical Ford F-100 1955 grill into a 1954 F-100
Discussion in 'Traditional Hot Rods' started by 1955 F-100 guy, Jun 2, 2017.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Looking for someone who put a 1955 F-100 grill into a 1954 F-100, what problems are there--- Thanks
  2. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    There are no problems with doing that.
  3. Nailhead Jason
    Nailhead Jason
    bolts right in, I like the 54 grille cause you see less of them.
  4. You may have to fill some holes where the fangs of the '54 grille meet the lower pan, other than that, any of the '53-'56 truck grilles should be a bolt-in swap.
  5. Having had a '53 grille in my F100 I can honestly say that they are a direct swap
  6. no55mad
    no55mad
    Saw a nice 55 grill for sale recently at a local swap. Looks new, chrome, $400 with hood emblems. If anyone is interested I can get you in touch with the owner.
  7. My panel has a 55 grille, it's just the grille and lower panel and then you choose what turn light housings you want to run (I went with the 55).
  8. Ralphies54
    Ralphies54
    56 not so easy in the earlier trucks,special radiator panel needed.
