Technical does anyone have pics of radiator mounts 37-41 ?
Discussion in 'Traditional Hot Rods' started by 1980gold, May 30, 2017.
  1. 1980gold
    1980gold
    I know the mounts vary year to year My 41 ford came with a Chrysler 22" wide flange mounted radiator. I was thinking of putting an aftermarket walker if i can, set up for sbc. I looked all over for pics I see the bottom mounts look to sit on the frame somewhere but I don't know where and not sure what else holds it in place. Any pics are appreciated
  2. Chiss
    Chiss
    from S.C.
  3. hdman6465
    hdman6465
    Standards and deluxes are different and you have to be more specific on the year.
    Sent from my SM-G900P using The H.A.M.B. mobile app
    1980gold likes this.
  4. 1980gold
    1980gold
    its a standard long door 41 coupe
  5. sloppy jalopies
    sloppy jalopies
  6. 1980gold
    1980gold
    thanks for all the pics helps a lot
  7. sloppy jalopies
    sloppy jalopies
  8. treb11
    treb11
    If you dont' have mounts at all, Ch***is Engineering has replacement mounts that weld in.
  9. 1980gold
    1980gold
    they're there, it was just with the oddball radiator in there I wasn't sure how the new one, when it comes would fit
  10. LBCD
    LBCD
    My 41 has a walker rad and an sbc...on the walker rad there are flanges about 3.5" up from the bottom on the side that rest on the frame rails and a longer off set 45 degrees mount on the upper outside rail that mounts onto the inner fender aprons...dont have a pic installed but here is a pic of the rad and you can see the mounts on the right side. [​IMG]
