Technical 34 Ford rear spreader bar tube diameter
Discussion in 'The Hokey Ass Message Board' started by adam401, Jun 7, 2017.
  1. adam401
    adam401
    Hi. I gotta buy some tubing to fab up a spreader bar and as I don't have anything that looks to be an appropriate size in the old s**** pile I figured I'd buy the correct size. If someone could measure the correct outside diameter for me I'd appreciate it. Thanks
  2. 1 & 1/2 inches O.D. on orig. rear spreader 34 tudor
    adam401 likes this.
  3. flamedabone
    flamedabone
    Mine was a chunk of 1 3/4 roll cage tubing slightly bent to match the contour of the rear panel. Most likely worthless if I ever got tagged, but slightly better than nothing.
    -Abone.
    adam401 likes this.
  4. flamedabone
    flamedabone
    Do you any more pics of your 34? Or a build thread? I hit the search but no luck.
    -Abone.
    adam401 likes this.
  5. adam401
    adam401
    Thank you for the replies guys I really appreciate it. I'll post some pics soon. It's just a jalopy but it should be ok enough. Thank you again
  6. adam401
    adam401
  7. Texas Webb
    Texas Webb
    Nice looking jalopy.
    adam401 likes this.
  8. bobss396
    bobss396
    Me? I'd root through my stock rack and use a piece of solid 304 stainless steel rod. Strong and the weight is a plus on a light in the *** ride.
    adam401 likes this.
