Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Dog_Patch
    Dog_Patch
    There is a fawn at the end of the driveway - so I get Kim's camera and take a few pics - she's got a ton of Quick N Dirty stuff on her camera and wasn't going to tell!
  2. Dog_Patch
    Dog_Patch
  3. Dog_Patch
    Dog_Patch
    Frank Taylor posted this on FB it's too cool. Dan lives 100 yards from this place
  4. blownhemi48
    blownhemi48
    from Bergen NY
    Could it be that your " O " rings aren't sunk deep enough into the deck surface. Ed Middlebrook has run blown 354 Hemi's for decades. He says they're supposed to extend .010 above the deck and he has had problems with them lifting the head gasket. So he likes to set them at only .005-.006 above the deck surface.
    mad mikey and loudbang like this.
  5. Hang'emHigh
    Hang'emHigh
    Not a word about the open door! I love it!
  6. savannahDan
    savannahDan
    I've read that Mr. Platt routinely did burnouts while holding the door open with one hand. I wonder if the picture is a burnout or dry hop gone wrong.
  7. glrbird
    glrbird
    Back in those days, match racer put rosin down and would do sever across the line burnouts. they didn't have back up girls and only lap belts, so you held the door open so when you would back up, you could lean out the door to make sure you put the slick in the rosin tracks. most closed the door, some just held it open.
  8. Sox & Martin Gold Dust.
    Dog_Patch and loudbang like this.
  9. Hang'emHigh
    Hang'emHigh
    The anticipation is killing me. Did you test fire it yet? How is the smoking problem?
    loudbang and Tudor like this.
  10. Tudor
    Tudor
    from GA
    I heard he is just waiting to hammer down and drive around some folks this weekend
  11. Dog_Patch
    Dog_Patch
    Woooo just got back. One of the best weekends of racing so far! Wasn't too hot - it was hot but needed a jacket at night - good racing at night. So lets see - got to the track and fired it up and drove around the pits to warm it up - FOG OUT! Like you can't see the other side of the pits.
    So began a long long session of trouble shooting and head scratching. Put on the open valve cover and used ether to see if it was ****ing oil through the valves - no effect - not much oil up there. But enough is there its not dry by any means. Thought it was ****ing through the spark plug threads - put in new plugs and NO tubes and ran around the pit again - folks were not pleased.
    Finally Gabriel said let's go get a diesel truck vacuum pump and see if we can **** the crank pressure low enough to seat the rings.
    So off we go to Advance Auto and came back to make up brackets. We needed a pulley and asked everyone we could find - nothing turned up. Gabriel needed to make some practice runs befor 10:30 track closing so that pretty much ended Friday.
    Saturday - I'm thinking no way are they going to let me run - oil is literally dripping out the header only on the p***enger side. @HEMIBERT shows up about 9am with a crate full of pulleys and belts. Me and Gabriel use "Damn It Bob's" welder - fun guys - they have the Greyhound bus with the chicks on the bus windows - good no BS guys.
    So while hooking up the pump Jimmy calls Gabe and says get 30w Non-Detergent oil. So I called @3dnsouth who was inbound and he searched until he found some at a Shell station
    Sorry for the low picture count
    So we finish the pump and pulley and drain the oil and wait for the new oil.
    Here is the pump - no belt because it slung off after it did its job.
    We put in the new oil and Jimmy Huff gets there. We start it up and it smokes to beat hell. Jimmy says "whack it" I'm like ok. 4,000 rpm , 4,000 rpm - we can't see anything now - he says no WHACK IT - I put my head inside to watch the oil pressure - the Jimmy grabs the injection and the tach goes to 8,000 and back down and then 8,500 and back down and he did this about 6 times. Then we shut it off.
    He says - tow to the start - do a short burnout and run down to the end hard - but only to 3rd gear - then let off the gas and drag it down to the end of the track with the clutch engaged.
    That's it. No more smoke. Pretty much - its a little puffy but its a race car. Now at least I can race - thought it was going to be a zero run weekend. Go check the ladder and I got Gene Cromer 1st round! I know he's gonna take me out if I'm slow on the tree or anything - our cars are the same cubic inch and big giant cars to push at the top end.
    Let me tell ya I could see light blue next to my fender all the way down the track! Words can't describe!
    So next round I got Silver Streak - so I'm gonna be done unless he breaks or red lights. :rolleyes: show time! Wheelie if you can't put em on the trailer as I always say. This is the Gopro but the outside shots must be higher :D
    Really proud of the better half for backing me up - she did great and I don't really need hand signals I can read her face :mad:
    catdad49, powrshftr, brEad and 16 others like this.
  12. Higgy's Henry
    Higgy's Henry
    I need video of you and Gene!!!!!
  13. allwilly
    allwilly
  14. jim snow
    jim snow
    Good stuff. Thanks for the ride. Snowman
  15. saltflats
    saltflats
    from Missouri
    Great news!!! and great job!!
    Your video is way better than mine.
  16. dirty old man
    dirty old man
    Great news and good footage with the Go Pro.
    So if I'm understanding this, the vacuum pump plus the "back down on the engine" in third gear ****ed the rings out against the cylinders enough to seat them! Amazing! I've learned something today for sure:eek:o_O:D
    mad mikey, racer-x, loudbang and 2 others like this.
  17. Gammz
    Gammz
    from Lincoln Ne
    Fugg N A man!
  18. DDDenny
    We're hav'n fun now!
  19. jimdillon
    jimdillon
    Great job. You guys are doing a great job of representing the era for sure.
  20. Dog_Patch
    Dog_Patch
    The Moonlighter vid doesn't show anything because the GoPro isn't pointing directly to the left. It was fender to fender
    Also we got hero cards now! JT wanted me to sign one - new at this so did my best
    Then we held a morning race
    catdad49, brEad, Floater03 and 9 others like this.
  21. Dog_Patch
    Dog_Patch
  22. moparob
    moparob
    Ummm signed lithograph with a **** drawn on it!!!!! Hahaha you did the MCI!![​IMG]
    Seriously I want a lithograph!
    Sent from my SM-G900V using The H.A.M.B. mobile app
    Hatchet and loudbang like this.
  23. Dog_Patch
    Dog_Patch
    Hope the race re-cap video will show how close it was - I should have mounted the camera on the nose of my car pointing left.
    Not a problem - do you want hairs ? Chapter 3.
    Floater03, mad mikey and loudbang like this.
  24. enloe
    enloe
    from east , tn.
    Thanks for the shirt. my buddy Travis texted me today to let me know he got it.
  25. Tyresmoke
    Tyresmoke
    from Norfork
    Great video looks like you couldn't put the power down until it stopped bouncing
    Sent from my SM-T805 using The H.A.M.B. mobile app
  26. Tudor
    Tudor
    from GA
    Bad *** Tony! Kim is great there! She'll be hamming it up in no time - and I could tell got you right in the groove there
    mad mikey and Dog_Patch like this.
  27. Dog_Patch
    Dog_Patch
    Sure thing man! Guess you're heading to Bowling Green?
    Yeah it breaking the tires loose in 2nd - you can kind of hear it sounds like a bog bit the car vibrates and I can tell the tires are breaking loose a little. Need to take a little out of the clutch I think. That was a 5.90 p*** - it was faster than the race with Gene.
    If Quian @Quain Stott checks in, I'm wondering if my MPH of 112 to Gene at 110 with same ET and all means that a gear change might help my car
    enloe likes this.
  28. enloe
    enloe
    from east , tn.
    Heading out Wednesday in the AM
  29. Dog_Patch
    Dog_Patch
    catdad49, Hang'emHigh, brEad and 8 others like this.
  30. Higgy's Henry
    Higgy's Henry
    WHAAAAAT?!!!! Driving around the legend!! At'a boy!!
