Hot Rods 16 inch wire ID
Discussion in 'The Hokey Ass Message Board' started by Mr48chev, Jun 11, 2017.
  1. Mr48chev
    IMG_2801.JPG IMG_2800.JPG I picked this wheel up at a local swap meet today along with a 35 wire the guy had and evidently wasn't paying enough attention to what I was looking at.
  2. swifty
    swifty
    What is the bolt pattern?
  3. 325w
    325w
    Looks sorta like a 17 inch Kelsey.
  4. R Pope
    R Pope
    Ford wheel. Note how each spoke only crosses one other spoke. Kelseys each cross two.
  5. R Pope
    R Pope
    Hmm...Looks to have a smaller bolt pattern than the other one?? Maybe not Ford, but definitely not Kelsey.
  6. Mr48chev
    I didn't think it was a Kelsey, the guy had two wheels at 20.00 each and I looked over the red one pretty good and handed him the money. I'll get the bolt pattern tonight. The one in question doesn't have the nubs to fit a Ford hub and the center doesn't appear to be as deep.
  7. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Possibly mopar. sugar I couldn't get a bigger picture. I know I'm not too hip to these contraptions
  8. 302GMC
    302GMC
    from Idaho
    Somewhat resembles early '30s Chrysler.
  9. 31Dodger
    31Dodger
    Not Ford if it has adjustable spokes. The beige/yellow wheel looks to be a Chrysler wheel.
  10. spooler41
    spooler41
    This is a mismatched set, the yellow wheel ,looks to be an adjustable spoke while the red one is a welded spoke.
    Even the wheel width looks different between the pair.
    ...... Jack
  11. Mr48chev
    I know that they are missmatched, that isn't the issue, I was trying to figure out what that one fit. Blame it on an old fart who was a bit tired not paying enough attention when the seller said 20.00 each. I had checked the red one over pretty close but didn't pay a lot of attention to the cream one.
    They are the same diameter = 16 inch
    The same width at 4 inches
    And when I got my handy dandy bolt circle checker out the bolt pattern is 4-1/2 inches.
    I'd still like to know what year Mopar it fits though.
  12. 31Dodger
    31Dodger
    Looks like 1933 Plymouth, but those take 17" tires, I believe.
  13. Model A Gomez
    Model A Gomez
    International used 16" wires with a 5 0n 4 1/2 pattern.
  14. swifty
    swifty
    Didn't know this so thanks for the info. When I read it I had to go out and check my Kelseys and you're right!
    The OP's wheel definitely looks like a Mopar product based on the large hole for the cap and the 4 1/2" bolt circle.. To run early Ford 32-34 caps on Mopar wires you have to add a ring to reduce the hole diameter.
    I have a set of wires from IHC and they have 4 1/2" bolt circle and take the Ford caps. The spoke layout is same as Kelseys with each spoke crossing 2 others but the center hub construction is different to a Kelsey Ford wheel.
