dudes! i was on one of the other sites and came accross some limited in on using a "reversed gear" astro van power steering box on 49'-54' chevy cars. they were talking 85'-95' box and i fail to see how they could reverse one. anybody that owns one of these car would love power steering so chime in. thanks
Just came across this on Chevtalk. Astro/Safari van power steering on a 49-54 Chev. There are two different boxes on a Astro/Safari Van so you need to check the direction of the pitman arm according to the post. The box needed is the reverse direction, so when the steering shaft is turned clockwise the pitman arm goes counter clockwise. http://www.chevytalk.org/fusionbb/showtopic.php?tid/273586/ http://www.chevytalk.org/fusionbb/showtopic.php?tid/261018/post/2164982/hl//fromsearch/1/#2164982 PS - You don't need to reverse the box, GM has one all ready reversed. It sounds like the 2wd box not the AWD box is prefered but check to make sure.
With a rebuilt front suspension/center link mine steers great.. And you not putting ****py Astro van parts on a cl***ic !
Basically have to position it the same way the stock one was, the bracket has to be fairly heavy duty. Someone makes an aftermarket one, but I guess it's kind of wimpy.
What pitman arm did you use, the Safari van one is straight or did you bend it to move the box further away from the exhaust?
The pictures on the ChevyTalk links are mine. Hope they help. I don't know what the pitman arm is from. It is offset and it looks like the end has been drilled and a 1" ball bolted in for the drag-link to snap on.
