28 Coupe Build
Discussion in 'Traditional Hot Rods' started by 51box, Jan 16, 2016.
  1. Nailhead A-V8
    Nailhead A-V8
    Wow nice work tucking that exhaust up in the frame! I see the dashboard waterfall from time to time on ebay but what's really hard to find is the V8 ashtray. I once looked at a car for sale at the side of the road that had 2 ! sitting loose in it I contacted the seller of the car and went back the next day but they were gone :(
    jbon64 likes this.
  2. 51box
    51box
    from MA
    Thanks man, appreaciate that. I'm really happy with how they came out.
  3. 51box
    51box
    from MA
    Thank you, I actually found a waterfall and chrome ashtray for it so it should look cool on the black dash
    brEad and Nailhead A-V8 like this.
  4. 51box
    51box
    from MA
    IMG_1083.JPG So I've been keeping up on this estate near me and I finally got word they were cleaning out the property. I didn't want all of it but it was a all or nothing deal. So if anyone local needs a cowl/chassis let me know I'll be selling them cheap cause they are crunchy IMG_1084.JPG IMG_1085.JPG IMG_1087.JPG IMG_1088.JPG IMG_1090.JPG
  5. 51box
    51box
    from MA
    Still picking away at the exhaust, just getting her welded up solid then onto brake plumbing and battery. IMG_1091.JPG IMG_1094.JPG
    kidcampbell71, gonzo, Stogy and 3 others like this.
  6. sloppy jalopies
    sloppy jalopies
    sent a pick to a buddy that wants a '29 closed car...
    closed car cowl with steering wheel on a chassis is an early '30...
    oval speedometer
  7. fiftyv8
    fiftyv8
    from CO & WA
    Honestly, you would think somebody would stamp some of these roof pieces out.
    They are not that large and I am sure would be well received by hot rodders and restorers alike.
    Great project, keep up the good work.
    kidcampbell71, brEad and greaser like this.
  8. Awesome work , watching this one for sure!
  9. 51box
    51box
    from MA
    Absolutely , I've seen some really solid sport and special coupes lacking the roof for reasonable money. I would gladly have bought a new roof if one was available.
  10. sloppy jalopies
    sloppy jalopies
    I would refer to those [3] panels as "lifesavers"...
    Wyocattech and 30 AV8 like this.
  11. 51box
    51box
    from MA
    Started on the brake lines and man if any of you guys haven't tried NiCopp line, this stuff is amazing. I did most of it just forming by hand not using a bender, I think it looks cool. IMG_1150.JPG IMG_1177.JPG
    I was able to reuse these 40 tabs off that rotted frame I bought in the beginning of this project. IMG_1207.JPG Decided under worked better all around for how everything is set up.
    Have a good portion of my gauges gathered up at this point. Looking for a early 60's tach & speedo if anyone has something they are selling. Thanks
    brEad, kidcampbell71, Stogy and 2 others like this.
  12. 51box
    51box
    from MA
    Couldn't get this to load yesterday but this is the layout I'm thinking IMG_1238.PNG
  13. 51box
    51box
    from MA
    Decided to just reverse this OG 32 spring to get the nose sitting better, I want it more level so once all the weight goes back on it should be close judging by what I had before. IMG_1263.JPG
  14. 51box
    51box
    from MA
  15. fourspd2quad
    fourspd2quad
    Great workmanship! '28's and 29's are my favorite coupes, hell they are my favorite sedans and roadsters too! Thanks for taking the time to post all the pics. You do impressive work!
  16. sloppy jalopies
    sloppy jalopies
    couple local boys told of braking 6 model A main leaves trying to reverse the eyes on 2 mains for their roadsters...
    they bent the eyes on each end... your method is much better... thanks...
  17. 51box
    51box
    from MA
    Thanks for the good words, appreciate that. I like the early coupe as well, that nailhead mounted high with the scoops even with the shell/cowl just looks cool to me.
  18. 51box
    51box
    from MA
    You mean try to roll the eye the opposite direction? Damn that must have been a bear to do.
  19. 51box
    51box
    from MA
    Well all the exhaust except tips, brakes plumbed, all suspension/drivetrain in. So I guess at this point I'll just pile everything on the car that's been done and then make a list of stuff to finish. 51968832107__30DD71BE-A829-4A6F-8C0C-0B614DBCB60A.JPG IMG_1362.JPG IMG_1363.JPG
  20. 51box
    51box
    from MA
    Ended up getting a great deal on this tach, I'm looking for a matching 160mph speedometer if anyone has one to sell. Thanks, Joe IMG_1299.JPG
  21. cmarcus
    cmarcus
    Absolutely bitchin build! Not sure if you ever came up with a solution for your belt line trim. My buddy's starting point was also an A Special, and he simply re-fastened it with stainless button head screws. The end result is actually pretty cool. [​IMG]
  22. waxhead
    waxhead
    from West Oz
  23. FlatJan
    FlatJan
    great build coming out nicely.
    ...Man I wish my progress was that fast..
    kidcampbell71 likes this.
  24. 51box
    51box
    from MA
    Thanks man, I do have the original belt line trim and at this point in thinking of using a panel bonding epoxy to attach it.
    greaser likes this.
  25. 51box
    51box
    from MA
    Thanks waxhead, I'm liking how stuff is coming together. I'm up in the air right now on doing a white firewall and grill insert or keep it all black??
    Thanks man, I bought this car 2 years ago this month and thought I'd be much further along at this point. It would be cool to drive it this year, but I want to finish paint etc cause from past history, I don't finish stuff once it drives.
  26. 51box
    51box
    from MA
    when I bought this Bronco 9" it had a couple passes of crappy stick weld over the original weld on the rear cover. Upon grinding it down there was porosity everywhere (explains the gear oil that kept showing up). So I had to cut the thing completely off to clean it well enough to weld. Sucked. IMG_1420.JPG
    Backing plates are less pitted then I thought after blasting quick. IMG_1467.JPG
    Working on buttoning up the brackets to get this back together. IMG_1472.JPG
  27. 51box
    51box
    from MA
    Added some back straps to the ladder bar brackets to finish it out .
    Shock mounts are the front 5"s cut off a rotted 40's rear wishbone.
    kidcampbell71 and Tim_with_a_T like this.
  28. 51box
    51box
    from MA
    Got some Kaiser tail lights fitted up and made some tail pipes to complete the exhaust. IMG_1680.JPG
    Picked up this cool GM tach drive generator, just need to build a different bracket to make it fit the big Buick.
    Bought this 48"x36" blaster for a great price, needs some work but should greatly speed up getting stuff cleaned & ready to paint. IMG_1897.JPG
    Going to start blowing the car apart this week and finish all the welding. Need to see some paint on this stuff soon for a motivation booster.
    kidcampbell71, brEad, v8paul and 3 others like this.
  29. dirt t
    dirt t
    1. HAMB Old Farts' Club
  30. Mikel50
    Mikel50
    Car is killer !
